Old Apr 14, 2008, 06:37 AM
axelen is offline
Find More Posts by axelen
OpenGL C/C++ programer
axelen's Avatar
Israel
Joined Dec 2006
advice needed - attaching plastic gear to metal shaft
Hi,
I CA'd a small didel gear on a 1mm metal shaft.
The CA just slips after a short time. I'v tried
grooving the shaft a bit with the dremel, so that
some CA would stay inside when I glue the gear on..
But still it slips...
Any secret techniques ?
axelen is offline Find More Posts by axelen
Old Apr 14, 2008, 06:44 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Epoxy, araldit rapid.
SebastianJ is offline Find More Posts by SebastianJ
Old Apr 14, 2008, 07:05 AM
ghostmechanic is offline
Find More Posts by ghostmechanic
1 paycheck away from homeless
ghostmechanic's Avatar
United States, KS
Joined Mar 2006
If it's a tight fit other than just slipping on the shaft a bit, try cleaning the shaft very well with solvent like acetone & then use RED loctite on it. That's worked for me in the past. I would suggest trichloroethylene as a solvent because it's one of the best degreasers there is without leaving a residue but it's a little volotile & most people don't have access to it.
ghostmechanic is offline Find More Posts by ghostmechanic
Old Apr 14, 2008, 07:30 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Will do !
I will scrape the shaft with a knife, so all outer layer
will be off, and clean with alcohol /acetone
Thanks for the tips
Old Apr 14, 2008, 08:29 AM
United States, KS
Joined Mar 2006
You should try cleaning the gear as well because those plastic gears usually will have some mold release on them. But make sure you use something that's not going to attack the plastic. And when you apply loctite, don't use a lot of it. Once you've gotten the loctite in & the gear back on, set it aside for a while to dry.
Old Apr 14, 2008, 08:47 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
welp...
took a new didel gear that is a very tight fit on the
1mm shaft, scraped the shaft (one with the dremel dents)
and cleaned with some wierd purple nail remover
from the missu's drawer + alcohol after...
then dropped a drop of CA into the gear's hole and pressed in
the shaft (i think the shaft went ~75% of the way)
For now it holds...
Cheers!
-RR
Old Nov 17, 2015, 09:19 AM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
Goop
Use Goop (E6000) adhesive.
First use q-tip with a tiny bit of soap to mix with any oil/grease on shaft. Then use water to remove soap. Then dry the shaft.
Put as much Goop on the shaft and sides (not gear part) as you can, tapering it from the side of the gear down to the shaft. Let dry and then build this fillet up with several coats after drying.
If the design allows, let some Goop bleed into the edge of the gear teeth for a better bite.
Is much stronger then just gluing the shaft to the gear.
OwlPic is offline Find More Posts by OwlPic
Link Radio-Controlled Toys, Model Kits, Auto Electric Gun (Plastic Gear and Metal Gear), A weiyi Other Websites 0 May 30, 2007 10:33 PM
Attaching pinion gear to shaft mccrohan Power Systems 3 Sep 24, 2004 07:17 AM
Symetrical foam wing cutting...advice needed mrtim Foamies (Kits) 5 Sep 09, 2001 12:51 AM
Help/Advice needed with ECO construction CruzThs Electric Heli Talk 4 Jul 25, 2001 06:21 PM
Quickie 500 with an Astro 605g....Rock and Roll!!!!!!!!! Advice needed with diet. mrtim Power Systems 3 Jul 24, 2001 07:53 AM
