Old Jun 07, 2015, 12:22 PM
jorjepablo is offline
Find More Posts by jorjepablo
Joined Jun 2015
Hi.
I am from Argentina.
How can I get your product.
Thanks.
jorjepablo is offline Find More Posts by jorjepablo
Old Jun 08, 2015, 03:11 AM
Edwardld is offline
Find More Posts by Edwardld
Joined Apr 2015
Originally Posted by dexter dog View Post
Sorry for jumping in on this thread (little old). But I thought i would pass this on. I just bought the at10. I am currently building a hex. (First one ever. New to the multirotor or flying world). I hav e been reading as much as possible and i have the manual that came with at10. And also downloaded pdf version to phone. After reading them (over and over) to familiarize myself with it. I noticed on pages 13 & 14 the paper version has more info on it then the pdf version. Apparently there are two steps to getting the r10d to work properly. In paper version bottom of p13 it says to bind transmitter power up 3rd channel, red light is solid. push link button for 1 second red light flashes for a few seconds then should turn solid red. (That whole bit IS NOT in the pdf version at all). Then on p14 half way down says to link transmitter. power up tx and besure you have a blue led on front of tx. Solid blue mean the RF signal is being sent. then power up rx and get solid red light on rx, push link button for MORE then 1 sec. Light should flash a couple times then turn green. Good to go.
Now I was able to get it to bind last night. Should be able to link it tonight will post results. Have to finish putting it together. Not sure why the two vesions of manual are different but this may be cause for some not getting theirs to work properly. Being a nooby please correct me if anything is not inline. I will also scan the two pages from paper version and post for all to see.
Bind transmitter power up 3rd channel, push link button for 1 second red light flashes for a few seconds then should turn solid red. It's means success bind.
Edwardld is offline Find More Posts by Edwardld
Old Jun 09, 2015, 10:00 AM
quadlala is offline
Find More Posts by quadlala
Joined May 2015
i manage to bind. But in cleanflight I am not able to get any response from the transmitter.
I set receiver mode to RX_SERIAL (SBUS)
I set serial receiver provider to SBUS
did I do something wrong?
I am on an AT10 with R9D receiver...
help.
quadlala is offline Find More Posts by quadlala
Old Jun 23, 2015, 03:51 PM
twisterek is offline
Find More Posts by twisterek
Joined Jun 2015
problem radiolink at10
Good Morning,
I bought radiolink at 10 , everything was ok until i put it via usb to my computer. It appear like
disc on my computer where was file ISO. After i put off usb cable and turn on again the sreen was
black. There is no signal, only red light is answer. Nothing happened. I cant do nothing, the screen
is black. I try to put it again via usb and after that computer is still recognize it like disc and
see ISO file and two lights red and green are shining alternately.
I will be very grateful for your help.
twisterek is offline Find More Posts by twisterek
Old Jun 25, 2015, 11:01 PM
RadioLink is offline
Find More Posts by RadioLink
Joined Oct 2013
Originally Posted by twisterek View Post
Good Morning,
Hello twisterek,
Sorry for delay the reply.
Thank you for using our product.
Could you please try update again.
AT10 upgrade steps
1. Put your AT10 via USB to your computer, two lights red and green are shining alternately.
2. Turn on your AT10
3. It appear like disc on your computer
4. Format original file
5. Copy upgrade file, just red light on when upgrading
6. When finished upgrade, two lights red and green are shining alternately again.
7. Put off USB cable and turn on again, two lights red and green are shining three times simultaneous and then on means upgrade successful.
Any questions please email me freely.
alice@radiolink.com.cn
Have fun.
RadioLink is offline Find More Posts by RadioLink
Old Jun 28, 2015, 04:59 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
San Pedro,Ca
Joined Sep 2004
Send one to me so i can test it for you in the US
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Jul 06, 2015, 02:37 PM
macomk is offline
Find More Posts by macomk
Joined Oct 2014
RadioLink AT10
I have got your RadioAT10, and I have got little bit of problem arming, throttle calibration etc. I have tested my quad and I changed all of the hardware ESCs motors etc. but still can not get the throttle calibration on. when I do calibration motors go into idle mode (spinning fast). ESCs are Emax. BTW - where is the USB connection you are referring in your update instructions.
macomk is offline Find More Posts by macomk
Old Jul 12, 2015, 10:01 PM
Joined Oct 2013
Hello macomk,
the AT10 update instructions I have reffered is
http://www.rcgroups.com/forums/showthread.php?t=2445685
update steps:
5. Copy upgrade file, just red light on while upgrading
And the upgrade details:
V1.0.0 firmware upgrade specification:
1. USB disc drive upgrade,file BIN is upgrade firmware.
V1.0.2 firmware upgrade specification:
1. Add VRE testing software;
2. Improve EPA algorithm.
V1.0.3 firmware upgrade specification:(2015.3.25)
1.Improve EPA algorithm;
2.Improve THR-CURVE STK data storing failure;
3.Improve PIT-CURVE STK data storing failure.
V1.0.4 firmware upgrade specification:(2015.4.20)
1.Improve the eighth channel not working when changing model type from HELICOPTER H-4/H4X to AIRCRAFT;
2.Improve THR-CURVE STK data cannot be deleted when setting up AIRCRAFT model;
3.Add: the minimum TRIM data 0 instead of 1, that is turn off adjustment when TRIM set up 0;
4.Improve GYRO-SENSE display abnormal;
5.Improve gibberish when setting up ATTITUDE.
V1.0.5 firmware upgrade specification:(2015.5.19)
1.Add: all the three-way switches and VR switches default at the central position when AUX-CH undefined;
2.Improve OFFSET not being at the central position when PROG.MIX NASTER set up CH4.
Old Jul 15, 2015, 05:39 AM
Joined Oct 2013
Please send me your email-box.
Thank you.
Old Jul 20, 2015, 10:47 AM
Munki is offline
Find More Posts by Munki
Joined Jul 2015
At10
Hi, last week i bought a AT10 in Germany. It works good but Display at daytime not possible see something,its dark, contrast is 20. Can somebody help me. Thanks
Munki is offline Find More Posts by Munki
Old Jul 26, 2015, 06:37 AM
spitfiremk12 is offline
Find More Posts by spitfiremk12
Joined Jul 2015
hola me e comprado esta emisora y la verdad es que esta muy bien , pero veo que el producto que venden no es el anunciado , segun radiolink esta emisora se le puede cambiar el color de la pantalla , pue la mia no se puede ni siquiera en igual mi pantalla a la de la foto , me e puesto en contacto con radiolink para ver por que me pasa y todabia no me an contestado , poco serios los de radiolink
spitfiremk12 is offline Find More Posts by spitfiremk12
Old Jul 31, 2015, 07:57 PM
toti1974 is offline
Find More Posts by toti1974
Joined Dec 2007
Radiolink at10 after upgrade
Hello Twisterek, I think we have the same problem. I follow the instructions very well.. Plugged in the radio with USB, copied the file in the SD drive and then turn off radio..
Now when I turn on there is only a red light and no LCD info.
What did you do?
Good Morning,
toti1974 is offline Find More Posts by toti1974
For Sale RMILEC TS4047 10CH 2.5W UHF Module System w/Receiver (JR module) crtek Aircraft - Electric - Multirotor (FS/W) 1 Feb 19, 2014 09:43 PM
For Sale RMILEC TS4047 10CH 2.5W UHF Module System w/Receiver (JR module) crtek Aircraft - Electric - Multirotor (FS/W) 2 Feb 19, 2014 09:42 PM
New Product RadioLink AT10 10CH remote control system RadioLink Product Announcements 1 Feb 19, 2014 08:15 PM
For Sale RMILEC TS4047 10CH 2.5W UHF Module System w/Receiver (JR module) crtek FPV Equipment (FS/W) 0 Oct 31, 2013 05:07 PM
For Sale 2.4GHz 10CH, remote control system Penneywang Aircraft - General - Radio Equipment (FS/W) 3 Oct 30, 2013 12:13 PM
