Old Sep 02, 2014, 10:13 AM
Joined Dec 2008
Xenon try brushing on a highly thinned layer of epoxy , let it get tacky then stick the cloth to it . Let that set up for a while , then brush on another less thinned layer over it .
pencon is online now Find More Posts by pencon
Old Sep 02, 2014, 04:28 PM
Jet-Set !
xenon20's Avatar
United Kingdom, Clevedon
Joined Dec 2013
Pencon, you think this method is a better option than the spray glue? have you tried both ways? I'm just a little wary about using too much resin (infact wary about using it at all after the last effort)
xenon20 is offline Find More Posts by xenon20
Old Sep 02, 2014, 04:42 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Try a test on a irregular shaped piece of scrap foam.
Which epoxy are you using?
Stupot46 is offline Find More Posts by Stupot46
Old Sep 02, 2014, 04:45 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Be sure to vacuum all dust from the foam. It will delaminate if you dont.
Old Sep 02, 2014, 05:09 PM
Jet-Set !
xenon20's Avatar
Joined Dec 2013
It's the Z-poxy finishing resin. I did dust down the sufrace and wiped with isopropanol before I started.
Old Sep 02, 2014, 11:59 PM
Joined Dec 2008
I've done the 3m77 misting a few times but did notice it letting go once wetted down with epoxy . I haven't tried the other method yet but have read about it and I think it has to work . I'll find out once I get around to doing mine .
Old Sep 03, 2014, 12:27 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
All I've ever used was this::
635 Thin Epoxy Resin System
http://www.uscomposites.com/epoxy.html
4:1 Ratio Fast Epoxy Hardener
Did my F-86F fuse , the Scorpion and now I'll use it for the F-18. I don't get to nuts, the most I ever buy is 1/2 gal at a time.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 03, 2014, 10:27 AM
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
+1 on what Cooler said, I use the same 635 but the medium at 3-1, just to get more working time, I have used it for a number of applications with great success.
Lt599 is offline Find More Posts by Lt599
Old Sep 04, 2014, 08:18 AM
Joined Dec 2008
If you get a couple of bubbles after it's all set up just cut them out and sand over them , the filler will hide them
Old Sep 07, 2014, 03:27 AM
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
Originally Posted by D_FAST View Post
Post pics when you get the chance.
You doing the test flight version i take it?
Started a build log on a Hansson/FliteTest 70mm with pics:
http://www.rcgroups.com/forums/showthread.php?t=2240864
JNJO is online now Find More Posts by JNJO
SAAB VIGGEN KITS or PLANS Sluf7 Fuel Jet Talk 14 Jan 04, 2012 10:30 AM
Saab Viggen 37 Sluf7 Electric Ducted Fan Jet Talk 11 Oct 20, 2008 08:45 AM
Saab J-37 Viggen FoxBAT138 Electric Ducted Fan Jet Talk 42 Nov 30, 2005 11:10 PM
SAAB JAS Gripen & JA 37 Viggen Built up from Plans anywhere Sluf7 Electric Ducted Fan Jet Talk 2 Jun 25, 2004 07:11 AM
Scorpio saab viggen and fantex andrea Electric Ducted Fan Jet Talk 44 Nov 04, 2003 12:55 PM
