Brilliant idea to solder the motor leads directly to the frame, saves some gramms?? I can now fly 8-9 min on half throttle. What exactly is the buzzer used for? You can flip a switch to find the model again??
Edit, some pics of my mods ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Any request photos? |
Joined Apr 2009
First the good answer: You don't need your 0402 resistor!
You can just place a solder blob on the two pads, so that they get connected. For a 0402 size land pattern this shouldn't be any problem at all. Just place a blob across for the BX Pin 4, and your module will send on Band "B". For explanation: That the channel selection pins do have some resistors, is as I said earlier probably due to noise rejection reasons. But the 1k resistors directly at the pins 1,3 and 4 are not optimal. A zero Ohm resistor (bridge) would be better. The reason why it wasn't populated like that is very probably, as you don't want just for that to add another part on your PCB. When you design for SMD placement, you always try to have as few different components as possible, even if it isn't optimal. The reason are the setup costs of the SMD placer. As 1k also still works for such a bridge, they probably used these same 1k resistors as for the channel selections pins, also for these pins. Addendum: BTW. I just received notice, that only now, my new RC305 has been shipped. Seems like it didn't make it before chinese new year...so it will be a bit longer... Addendum2: As you know, I use my own made DC/DC regulators (as I have the equipment, and am a weight fanatic, so I made a switcher which is e.g. lighter than the Pololu ones). And as I said, the filtering is sensitive. So up til know, I used quite some ceramic high caps. But the switching+LDO design of the TX5805, which I ranted about, seems to be able to get out with just 3 33uF caps. So I also evaluated a new design, and it is smaller and lighter than my original design, and doesn't need now, such a lot high caps (which are quite costly). So my excuse for this rant about using a switcher+LDO for the design. But my rant, about the terrible big and heavy design still remains. Also the switching voltage of 4.5V is way too high. It just burns too much energy in the LDO. I for example now use a LDO with 0.13V drop voltage (in a 3x3x1mm package). So with some safety margin, I go to 3.6V intermediate voltage. So that in total I only have to burn 0.3V, instead of the 1.2V of the Walkera version. And the good thing is, they intend to soon publish a 2x2mm package version, which would make the total solution still smaller. All in all, one can tell, that the VTX chips are extremely allergic to even small voltage fluctuations. E.g. at about 2mV noise, you start to see it in the picture. At about 5mV you can see it very clearly. And already at about 20-30mV you will have heavy picture distortions. For those interested: I now use a LM3668 as switcher, and then a TPS73733 as LDO. Edit: Quote:
Then I would rather use a standard transmitter and a separate FPV equipment (the F7 has a terrible programming interface...). As I said earlier: IMHO the F7 doesn't really make sense to buy for most people. It is intended as an all in one solution, for people not capable/wanting to solder a bit. But unfortunately it is quite a bad solution, due to the ridiculous VRX-antenna placement, which unnecessarily limits it to very short distances. For anything more, you will have to mod it, as you did, and then you quickly are in a situation, where you needed more work to do, than using a standard separate FPV solution, and you will also have spent more money for that. |
Problem to be solved now... Increase the devo7/ lb transmitter range.... After about 150 m the signal seems to be lost and the lb keeps on flying without me being able to cut the throttle.... Someone knows how to change the fail save settings of the lb? Or how to increase range?? its now at 20-15 transmitter power.
Joined Apr 2009
Unfortunately I have no experience with a Devo7. I got a Devo10 with deviation.
Doesn't the Devo7 lack the additional TX-amplifier? I think so. But first I would try to have a different orientation of your RX-antenna. Like it is in your picture, you will have problems if the LB is pointing it's front or it's back to you. Make the antenna point upwards or downwards so that the donut shaped radiation pattern is properly used. Also always remember that carbon fibers are electrical conductors, so they shouldn't be in the radiation area of your antenna. Also the antenna length on the LB can be wrong. This also happened on a few of my Walkera helis. This will also make the reception worse. You can also add a patch antenna to your TX, this should help a lot, and they are cheap. |
| Thread Tools | |
| Discussion Walkera Mini CP (and Blade 130X) - sub micro FPV setup | Picofly | Micro Helis | 133 | May 11, 2013 10:39 AM |
| Help! Mini Multirotors sub-forum in the Multirotors forum Vote Please! | jesolins | New Forum Requests | 67 | Dec 17, 2012 12:20 PM |
| Discussion Walkera Mini CP sub-micro FPV heli (AUW 54g) | Picofly | Video Piloting (FPV/RPV) | 20 | Dec 15, 2012 06:30 PM |
| Help! New Mini and Micro Multirotor sub-forum to Multirotor forum Please Vote! | jesolins | Micro Helis | 11 | Aug 29, 2012 06:22 PM |
| Discussion Walkera Mini CP tail motor not going | Samw5 | Micro Helis | 4 | May 22, 2012 10:02 PM |
