Old May 19, 2013, 08:43 AM
Ireland
Joined Apr 2001
lead batteries parallel any disadvantages?
I have a few 12 v lead batteries of different age and condition.
Is there any disadvantage connecting them parallel ?
Doing so would reduce maintenance (only one set to charge) and combine there capacity right?
cmulder is offline Find More Posts by cmulder
Old May 19, 2013, 09:37 AM
tacx's Avatar
United States, MI, Macomb
Joined Apr 2009
Yes you can. Just be aware that if you connect one with a high charge and one with a low charge there will be quick discharge load from the high into the low. If you can, try to discharge a high down closer to the low ones. After that you can connect them without much current sharing.
Also note that your charge time will be much longer.
tacx is offline Find More Posts by tacx
Old May 19, 2013, 03:22 PM
Ireland
Joined Apr 2001
thanks
il get some clamps and get to work
Sold JST-XH Parallel Balance Lead 6S 250mm (2xJST-XH) kayvannouri Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 03, 2013 04:47 PM
Sold JST-XH Parallel Balance Lead 6S 250mm (6xJST-XH) kayvannouri Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 03, 2013 04:45 PM
Sold 4s balance leads, parallel 4s splitters, wheels, UBEC 5A HydroPilot Garage Sale/Large Lot Ads 0 Apr 21, 2013 10:52 PM
Sold 4s balance leads, parallel 4s splitters, wheels, UBEC 5A HydroPilot Aircraft - General - Miscellaneous (FS/W) 0 Apr 21, 2013 10:24 PM
Discussion Parallel Charging Lead Witterings Batteries and Chargers 11 Apr 09, 2013 01:55 AM
