Old Jan 30, 2014, 04:12 PM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Question
Collet adapter question
I have a collet style adapter in a plane of mine and it will not tighten down sufficiently. First time I've had this happen. Prop actually flew off and broke. Anybody have any tricks they use to help in a case like this? My first though was Loctite thread locker but that may make it near permanent.
Thanks in advance
Alan
GiusedtoBe is online now Find More Posts by GiusedtoBe
Old Jan 30, 2014, 04:39 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
i've used washers between collet and backplate. you can put them in front of backplate too if you wish. that should provide sufficient tightening to keep the assembly on.
cmdl is offline Find More Posts by cmdl
Old Jan 30, 2014, 05:02 PM
Paws to refresh...
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Thanks in advance
Alan
Some collets have two rather than four cut reliefs in the tapered section. You might be able to add a second set of cuts with an X-acto saw or similar to help the grip on the shaft.
gnats82 is offline Find More Posts by gnats82
Old Jan 31, 2014, 06:05 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Thanks for the replies. The collet has four cuts and the washer worked.
Thanks again
Alan
Old Jan 31, 2014, 09:08 AM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
Use sandpaper and roughen up the shaft
Mikemynameis is offline Find More Posts by Mikemynameis
Question 4mm motor shaft collet adapter question for folding prop garrettt04s Power Systems 2 Dec 28, 2012 09:19 AM
Bullet nose collet style Prop Adapter for 4mm? Jim Miller Scale Kit/Scratch Built 6 Aug 13, 2003 03:41 PM
WTT...collet adapters LuckyArmpit Aircraft - Electric - Airplanes (FS/W) 0 Jul 18, 2002 09:55 PM
Collet type adapters & Hacker geared motors Hammer Electric Sailplanes 2 Jul 05, 2002 04:26 AM
Collet Style Prop Adapter or Spinner SteveR Sport Planes 3 Mar 03, 2002 10:03 PM
