Old Sep 23, 2013, 01:04 AM
firehorse 2
firehorse's Avatar
Kilcoy Australia
Joined May 2004
Sharon 4200 motor & prop suggestions
Hi,
Could someone drop some motor names and prop sizes for the Sharon 4.2m electric
I like Hacker & Neu
I've seen MVVS motor 690 but its 700w max may not be sufficient
Sport flying no comps but I do like having enough juice
firehorse is offline Find More Posts by firehorse
Old Sep 23, 2013, 10:15 PM
kilwein's Avatar
Joined Jan 2007
Have used both a 1506 6.7:1 & 1509 6.7:1 with aero cam folder 17x10 to 18x10.CC85 & cc125 with 4cell 3300mah 65C TP pack. ~800 to over 1800 watts. Uses ~ 250-400mah per climb as shown in pic.
Attached a few pics of ~1100-1300 watts on the 1506 6.7:1 17x10 cam folder showing climb rate and current draw on 4 cell pack. It goes vertical, but not super fast.
Your going to like the Sharon.
EDIT
Correction prop is 18x10.
kilwein is offline Find More Posts by kilwein
Last edited by kilwein; Sep 26, 2013 at 08:33 PM. Reason: Correction prop is 18x10
Old Sep 24, 2013, 06:46 AM
firehorse 2
firehorse's Avatar
Kilcoy Australia
Joined May 2004
Hi Kilwein,
Thanks for the info very handy
I read your Sharon build thread looks like fun all the way
Which 1506 Neu model did you use with the 17x10 prop ?
Old Sep 25, 2013, 12:23 PM
320pilot's Avatar
Joined Mar 2009
Here is some E-calc data for the Neu 1509/1.5D/6.7 with a RFM 16X10 prop. Using the older CC Phoenix 125 ESC.
This is the setup I fly with my Nan Alex XXL on 3S. I also ran the numbers for a 17X10 prop on 4S, but haven't tried this yet .
320pilot is offline Find More Posts by 320pilot
Old Sep 25, 2013, 01:41 PM
kilwein's Avatar
Joined Jan 2007
NEO 1506-1.5y-6.7:1
Originally Posted by firehorse View Post
Hi Kilwein,
Old Sep 25, 2013, 04:35 PM
Jebera's Avatar
Brazil, MG, Belo Horizonte
Joined Oct 2006
Sharon Motor
Hello Firehorse,
I have this glider on the top of my wish-list, will get it as soon as the finance allow...
Please let me share a little bit of my experience, successes and frustrations.
An underpowered glider is something really bad and dangerous, specially with a big glider like a Sharon.
I use to own a Big Ceres, little smaller but havier, I salvaged it's power system for my future Sharon, future
First thing is, Don't waste your MONEY $$$$ with something that will not bring you joy.
Second: what you expect from your E-Sharon?
Will you be happy just putting it up in the air? If so you'll spec a small sized motor like the Neu1506 mentioned and 17x10... ( very underpowered to my taste)
Do you want it a little bit hot, I mean a medium size motor like a Neu1509 and a RFM 17x13? (properly powered )
Or you want it a big hotliner? Then a big Neu 1512 RFM 20x13 is the way to go.
Maybe a rocketishh with Neu 1515 and RFM 18x19?
Please let me know what you want and how far you pocket will let you go...
André
Jebera is offline Find More Posts by Jebera
Old Sep 25, 2013, 05:56 PM
Jebera's Avatar
Joined Oct 2006
Both setups are really good for the Alex XXL, they fit very well the size and weight of this plane.
For a good setup you always have to consider the overall mass (inertia) and a appropriate pich for your prop.
Of course the high pich should give you high top speed but in a heavy model the peop will stall too long, nice sound but waste of watts, so a moderate pich like x13 to x15 is good here.
I'd love to check the room for bateries the E-Alex XXL offer, the conversion of an Glider to electric is not an option, except for a very light weight setup.
Could you please advise the maximum size of batteries it fit?
TKS!
André
Old Sep 26, 2013, 09:26 AM
firehorse 2
firehorse's Avatar
Kilcoy Australia
Joined May 2004
I dont care about the cost
I am going to go with Kilweins setup to see if I like it
crazy power is fun but I really don't exactly need it
but then again I could be wrong
I cant tell how well it will climb unless I'm seeing it
I'll fly the 1506 1.5y but what is 1000w surge time, 20sec, 1min ?
Anyways, Kilwein says vertical, so I would prob be happy with a 45-60 degree climb with good speed and what, 50-80km/h ?
I do care that the Sharon has the legs to get up there and with minimal fussing around on the throttle, just punch and go
Plus on a windy day that the Sharon apparently likes, there would need to be enough juice to go upwind
The last thing I want is the Sharon struggling for height
Old Sep 26, 2013, 01:54 PM
kilwein's Avatar
Joined Jan 2007
Let me see if I can get a video this weekend of it on a vertical so you can see it.
I do like insane power also. Have one glider that does 5700ft/minute straight vertical.
Old Sep 26, 2013, 08:14 PM
Jebera's Avatar
Joined Oct 2006
Well,
5700ft/min isn't crazy, it starts getting crazy at 9000ft/min , little over 100mph but it's for another forum.
Anyways I really like your Alex XXL setup, That's the perfect sized glider, easy to transport and a big load of fun.
André
Old Sep 26, 2013, 08:30 PM
kilwein's Avatar
Joined Jan 2007
That gives a new meaning to Tim Taylor's MORE POWER!!
The only way I get the Sharon to 100+mph is in a dive and she howls.
I have a correction to the prop size, it is a 18x10 not 17x10.
Here is a link to old video.
http://www.rcgroups.com/forums/showt...9#post22111583
thread #3 has video and ET chart to go with.
Chart shows current, speed, altitude.
Old Sep 26, 2013, 09:13 PM
Jebera's Avatar
Joined Oct 2006
OK,
So cost is not limiting, I just wann say that the Neu1506 is really small for that plane, all motors have a limited run time, time they build up heat and loose efficiency, then you need a loooong rest time before you run it again.
The big problem running a small motor in a big plane is it's always lazy and slow, then you keep pushing the motor and the result is a dead motor, frying either the magnets or the wiring.
Other thing is if you have a small motor in the nose, plus ESC and Batts and you still have to add lead, I hate carrying lead, what a waste!
When you have the correct size motor then you can have the right thrust, enough pich speed and long enough motor run time per battery pack.
I like my warmliners at 1000w/kg, close to 400w/lb , not lazy, not too fast also not too expensive, but watts don't tell all the story, specialy when talking about outrunners...
This website is very interesting, http://www.reisenauer.de , this guy sells some of the most interesting motor setups off the competition scenario.
Here you can check a true bench test with motor/batt/prop, you can figure out what might work for you, no guessing.
I have this PeggyPepper (Skorpion) http://www.reisenauer.de/artikeldetails.php5?aid=1623 in my Pike Perfect, it's pretty good but not perfect, I still need 60g on the nose and a heavy 3000mAh 3s Batt to balance, flying weight is 2400g, ordered this other http://www.reisenauer.de/artikeldetails.php5?aid=1594 , 30g heavier, needs a bigger ESC (a PHX125 is 30g more) , same batt, same prop (18x10 Graupner) will provide twice the thrust --- 3s - 11V - 18x10 G.M32, 7273 rpm, 107 Amp. 1187 Watt, Schub 7004g, Pitch. 111 km/h, Eta 78,7% - 15 Sek. ---
The nice thing is this is a Helicopter motor and is designed for "abuse".
For your application I would suggest this motor http://www.reisenauer.de/artikeldetails.php5?aid=1729 , it's a perfect match .
it's very recommended for planes on the 4-5m range and big props like RF 20x13 or 23x12 , I'm 100% positive.
Check it, it really worth a try!
André
Old Sep 26, 2013, 09:24 PM
Jebera's Avatar
Joined Oct 2006
Nice!
Do you have this video in POV version?
This link the guy uses a Neu-1509 4slipo and 15x10 prop, Still underpowered for my taste.
Sharon Electric 4200 (3 min 46 sec)
André
Old Sep 26, 2013, 09:35 PM
Jebera's Avatar
Joined Oct 2006
Dude,
The surge is just a few seconds like 8 to 10...
You say "punch and go" so it's more likely you need a Neu1512 or 1515 1Y, a good 6s, PHX 200 ESC and a 20x13. You also can go to a HV setup which I like more...
André
Old Sep 27, 2013, 03:00 PM
320pilot's Avatar
Joined Mar 2009
Jebera wrote'
thanks,
I will try and measure the battery compartment, right now I fly it with a TP-3700-3S-45C LiPo
Discussion Valenta Sharon 4200 E, what to stick in it? Spekd'out Electric Sailplanes 40 Mar 02, 2014 02:03 PM
Build Log The New Kid on the Block: Valenta Sharon 4200 yyz Cross Country Soaring 55 Sep 04, 2013 10:01 AM
Question I need some motor suggestions 8" props subaru4wd Scratchbuilt Multirotors 13 Jun 19, 2013 02:37 PM
Question Motor / Prop suggestions? Macattaka Electric Sailplanes 4 Apr 10, 2013 07:15 PM
Sold Himax 2025-4200 brushless motor and Phoenix 25 amp ESC Kyle G. Aircraft - Electric - Power Systems (FS/W) 0 Jan 02, 2013 03:03 PM
