Old Mar 17, 2004, 05:32 PM
Joined Feb 2004
Metal Pinion gears
Could someone please tell me where I can buy metal pinion gears for a hornet Every place I looked is plastic
Thanks Hoss
lilhoss is offline Find More Posts by lilhoss
Old Mar 17, 2004, 06:57 PM
mhackney's Avatar
MA - close to Boston
Joined Apr 2003
towerhobbies.com - search for "pinion"
mhackney is offline Find More Posts by mhackney
Old Mar 17, 2004, 09:52 PM
CD-ROM Junkie
Art Newland's Avatar
Camas, Washington, USA
Joined Apr 2001
not sure what a hornet needs? 2mm shaft w/46 pitch? if so allerc.com has a selection starting at 10 tooth.
Art Newland is online now Find More Posts by Art Newland
Old Mar 17, 2004, 10:12 PM
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
64p
Hoverup is offline Find More Posts by Hoverup
Old Mar 18, 2004, 04:31 PM
King of The Moon
ozoneone's Avatar
NYC
Joined Jun 2003
Not positive about the Hornet, but HPI Micro RS4 pinions work well on the Piccolo. They are available in 8 to 13 teeth. Be careful though as the steel can strip your main gear easily. Auto-rotation gear/one-way may help here. Also the shaft on some stock motors will need to be ground smooth to eliminate the splines or the metal pinion will not fit. Then you can't go back to plastic pinions.
The gears are available at most LHSs & towerhobbies.com among many others. Good luck!
ozoneone is offline Find More Posts by ozoneone
Old Mar 18, 2004, 04:42 PM
Joined Feb 2004
After talking to a few people, I think I may stick with plastic gears. I guess I just got a little flustered when I stripped out my 2nd plastic pinion. I'll just watch the gear mesh a little closer
Thanks for the response's
Hoss
Old Mar 18, 2004, 04:47 PM
San Carlos, California, United States
Joined May 2002
The Hornet uses 64 pitch pinions.
I know fxaermodels carries a one or two sizes.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jul 22, 2014, 10:06 AM
Finland, Nilsiš
Joined Jan 2014
WLtoys L202
Hi all. Where to buy metallic double gear? Whats that name? Theres not sold to this car, but if someone find or know where? Wltoys l202 has brushless motor and goes fast. I drive lot of sand and it goes inside to gearbox... I need upgrade to metallic! What is my gear ratio? I have little bigger rear tyres than original. Speed is fine but not matter if has little slower. Thanks
AriRuFIN is offline Find More Posts by AriRuFIN
Need Pinion Gears for LMH...FAST!!! jsc Aircraft - Electric - Airplanes (FS/W) 1 Sep 24, 2001 10:27 PM
Pinion Gears for the ECO CruzThs Electric Heli Talk 6 Aug 03, 2001 01:52 AM
Aveox 1010/2y pinion gears domlou Electric Heli Talk 2 Jun 27, 2001 10:51 PM
AF010 Brushless Motor Pinion Gears Here! Mario Electric Heli Talk 4 Jun 08, 2001 04:05 PM
Pinion gears on gear boxes. sambo Electric Plane Talk 3 May 28, 2001 04:12 PM
