Old May 26, 2016, 06:39 PM
takEon is offline
Find More Posts by takEon
United States, NY, Schroon Lake
Joined Mar 2013
Inverted Engine
While looking at a bunch of old plans, I noticed many have inverted glow engines. I have never had one and been told of issue's, but wondered about experiences from those who have actually tried them. Thoughts anyone?
takEon is offline Find More Posts by takEon
Old May 26, 2016, 06:45 PM
exf3bguy is online now
Find More Posts by exf3bguy
United States, CA, Sacramento
Joined Oct 2011
I've done a few of them and the only ones that I felt were worth the hassle were pump equipped engines. Non pumped installations were either more work then I wanted once at the field or were less the 100% reliable.
exf3bguy is online now Find More Posts by exf3bguy
Reply With Quote  (Disabled)
Old May 26, 2016, 06:54 PM
Tucci is offline
Find More Posts by Tucci
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Apparently something about the fuel putting out the glow plug under certain conditions?
At least from what I've read. I've only had a couple glow planes. Fuel is way too expensive.
Tucci is offline Find More Posts by Tucci
Old May 26, 2016, 06:56 PM
Cbfn1 is offline
Find More Posts by Cbfn1
United States, OH, Strongsville
Joined Jan 2015
I have a super chipmunk with a Saito 82 inverted and it runs just like it did
When installed upright.
It's important when installing inverted to have the centerline of the fuel tank just a touch below the centerline of the spraybar on the carb.if this can't be done then a
Pump might be needed.
I've never mounted a 2 stroke inverted can't help you there
Cbfn1 is offline Find More Posts by Cbfn1
Old May 26, 2016, 07:11 PM
Joined Oct 2011
Yes, the tune had to be right on the money but my issues were more related to fueling/starting. Cbfn1 is correct the center of the tank should be below the carb spray bar otherwise the fuel will siphon and flood the engine. I always put a fuel clamp on the carb line so the fuel could not get to the carb while fueling. Open the clamp and start immediately. Worked well unless you had a dead stick or did not shut the clamp right after shutting down. Then the fuel would flow and could fill the cylinder. If unaware of the cylinder being full of fuel, you could easily damage the engine by hitting it with a starter. It can be done reliably but is more work then an upright install. A pumped engine such as the YS engines does not suffer these issues.
Old May 26, 2016, 07:28 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
Yes, tank position must be right or you can have flooding problems. Like he said tank center line should be it bit lower than spray bar. I have flown many airplanes with inverted engine with no problem. Clarence Lee 's R/C engine book has several answers to this same problem. Once running inverted has no effect. If it did you couldn't fly inverted. Some guys start their inverted engine planes upside down to solve the flooding when starting problem.
datsunguy is offline Find More Posts by datsunguy
Old May 26, 2016, 07:37 PM
Twodor is offline
Find More Posts by Twodor
Dinosaur
Twodor's Avatar
United States, CO, Littleton
Joined Feb 2016
I run most of my engines inverted and the only problems I have are during fueling, getting the fuel line back on the carburetor nipple, and finding the glow plug without standing on my head.
I run 4 stroke engines exclusively, Saito and YS and I usually leave the glow plug battery on until the engine is warm. My engines idle and run fine after that and don't seem to know they're upside down.
I try to center the tanks so the outlet is about the same height at the carb inlet.
Tom
Twodor is offline Find More Posts by Twodor
Old May 26, 2016, 09:07 PM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
If you can tune the high and low speed properly upright, you won't have a problem inverted either. +1 on tank position also!
mike3976 is offline Find More Posts by mike3976
Old May 27, 2016, 02:46 AM
Joined Jun 2011
So true, Mike.
Old May 27, 2016, 07:55 AM
Brutus1967 is online now
Find More Posts by Brutus1967
The Netherlands
Joined Nov 2009
I have run 2 stroke engines in EVERY possible orientation, including vertical shaft, both pointing up and pointing down, and 4-stroke upright, sideways, inverted and vertical shaft down.
Installed properly, a glow engine runs the same, regardless of upright or inverted, sideways left or right, with the possibility of less reliable idle when inverted due to the possibility of oil pooling in the head. But I have never encountered that myself.
But indeed some issues during starting can occur.
The flooding issue that exf mentions (flooding with stopped engine and full fuel tank) is very real on fourstrokes but impossible on normal 2-strokes with a front carb, since the carb is now pointing downwards and the fuel simply flows out of the air intake. It does not first flow upwards all by itself into the induction port.....
Hydrolocks at the first start of the day, due to oil collecting in the combustion chamber during storage is a very nasty and real problem with 2 strokes but should not occur on most 4 strokes due to the valves being in the head.
Brutus1967 is online now Find More Posts by Brutus1967
Old May 27, 2016, 08:14 AM
Jennifer Curtis is offline
Find More Posts by Jennifer Curtis
Joined Jan 2015
What is it that makes one position the upright position?
It can't be the direction that the cylinder points, because
there are flat twins and fours, and radials that have them
pointing at different directions. It can't be the carb, either.
They point different directions for helicopter engines and
flat four engines.
If there was an oil sump, maybe that would tell, but since
aircraft fly in different positions that wouldn't tell much.
The only thing that I can see is the writing on the side,
and that has no effect on anything.
Jenny
Jennifer Curtis is offline Find More Posts by Jennifer Curtis
Old May 27, 2016, 10:06 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
For single cylinder engines the cylinder is pointing up for the upright position.
For a single cylinder engine, the cylinder points down for the inverted position.
For a single cylinder engine, the cylinder points sideways for a horizontal position.
Now you could have the cylinder pointing at a angle, say 45 degrees. Some airplane designs have to position the cylinder at a angle so that the muffler is inside the cowl underneath.
Actually if the engine has the glow plug directly in the top center of the combustion chamber, then angling the engine so that it isn't exactly inverted but at a angle works well. Then the glow plug isn't at the absolute bottom most part of the engine where oil and fuel can accumulate drowning out the glow plug.
earlwb is offline Find More Posts by earlwb
Old May 27, 2016, 10:16 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
An upright RC model engine installation:
An inverted model airplane engine:
Side mounted engine:
Here is an example with the engine mounted at a angle other than striaght up or down, thus the muffler will be directly down under the cowl.
Old May 27, 2016, 11:48 PM
Joined Oct 2011
So......how would you define this install?
Old May 28, 2016, 04:12 AM
The Netherlands
Joined Nov 2009
A horizontal twin, mounted upright....
You can mount it upside down (most likely the exhaust stacks will be pointing upwards then).
It will look silly most likely, should run more or less the same, but might encounter starting problems due to exhaust residue running back from the muffler into the combustion chamber at standstill.
(without precautions for this, glow engines are horrible to start, when mounted with the exhaust port facing up, ask any RC-biker that runs fuel. Probably gas engines are less affected)
New Product Eachine E20 3D Mini Spider Inverted Flight - New Inverted Flyer. Lycan Animal Mini Multirotors 45 Jul 20, 2016 01:45 PM
Found Wanted Bisson Inverted muffler # BIS05517 For MVVS or Evolution Engine Grumpy Monkey Aircraft - Fuel - Engines and Accessories (FS/W) 4 Mar 25, 2016 06:31 PM
New Product The Nihui NH007 Frog - inverted&invertible flier LittleFish Mini Multirotors 10 Mar 25, 2016 01:43 PM
Discussion Why inverted engine mounting? Cjkuehl Engines 26 Jan 02, 2016 03:50 AM
Inverted Engine In-Cowl Muffler prflyer Engines 3 Feb 08, 2004 03:02 PM
