Old Mar 10, 2013, 12:10 PM
nitrowing is online now
Find More Posts by nitrowing
Joined Jul 2005
36" scale power recomendations
building a berkeley Fairchild 24
WS 36"
May want to go go RC in it, whats a decent power system, something budget from Hobby king
3.5 gram servos?
7-10 amp esc?
500 2S?
OR?
nitrowing is online now Find More Posts by nitrowing
Old Mar 10, 2013, 01:24 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If it helps there is a good thread listing the Guillows small kits -
Guillow's Conversions - The list of conversion threads
If you scroll down to Kit No 701, it the Fairchild 24, but only 25" span.
A little further is Kit No 802 a Cessna Skyhawk 172, with is also 36" span. This one should give you some useful information on what other are using for a similar sized model.
eflightray is offline Find More Posts by eflightray
Old Mar 10, 2013, 03:31 PM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hey nitro,
I built a 36" span Fairchild 24 blown up from Earl Stahl plans for a free-flight model. It has flown well on a Feigao 12mm brushless inrunner in a GWS IPS A gearbox (5.9:1 ratio) on 3s and a GWS 7X6 slowfly prop, but I converted it to a 1300 kv Blue Wonder outrunner on 2s and a GWS 8X6 HD prop which works just as well for much less money. My Fairchild weighs between 10-11 onces depending on which motor/battery combo I use, and your results will vary if your all-up-weight is significantly different.
You can get the Feigao and IPS gearbox at BP Hobbies for around $40, or the Blue Wonder from Hobby King for under $10. Just Google the motor names and the suppliers and you'll find them.
Steve
Steve85 is offline Find More Posts by Steve85
Old Mar 10, 2013, 08:48 PM
Joined Jul 2005
thanks
I am on the right track then. I took alot of dihedral out to make it with ailerons.
I fly 1/4 scale and 50cc planes, this thing is sooo small, hard to work on.
Built the whole thing with 6$ worth of wood...
Old Mar 10, 2013, 10:25 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Not to mention that this not so small Model :-) will not leave a Debris Field on a 'crash' . Gawd Forbid that should occur.
Nor will it need 6 acres of field to fly in.
Small points, that will soon enough.. give pause, as to 'smallness'
Bare is offline Find More Posts by Bare
Old Mar 11, 2013, 11:15 PM
Joined Jul 2005
If I build it right, you will be right. I need to keep it light or it will be a another pocket size scooter, not scalish or even fun to fly.
Ordered my micro set up..
Old Mar 12, 2013, 08:53 AM
Steve85 is offline
Steve85's Avatar
Joined Mar 2004
Actually, the Fairchild 24 configuration, with a high wing and lots of draggy struts between the wing and the landing gear, doesn't like to go too fast, and gets squirrelly when it does. Some guys have theorized that all those struts make for very turbulent air around the tail surfaces at high speed, leading to unstable behaviour. If you can keep the wing loading down to 10 ozs per square foot or less, 50 watts per pound will be more than enough for this bird to fly in a scale-like, easily-controlled manner. My 2 cents, anyway...
Steve
Old Mar 12, 2013, 10:12 AM
Joined Jul 2005
looking forward to it.
If I like it, I may double the plans and modify it where needed.
For Sale Turnigy POWERFUL 36-48 1450kv Motors!!! (4) Hardly used/tested whosthebaddest Aircraft - Electric - Power Systems (FS/W) 2 Feb 09, 2013 09:35 PM
Discussion hobbycity 36-10xl, esc recomendations please BMX Power Systems 1 Oct 14, 2007 10:44 PM
Any recomendations on scales? Crazyrcer Electric Plane Talk 15 Jun 15, 2005 06:18 AM
Tachometer and Scale Recomendations thandley Micro Helis 8 May 22, 2004 04:07 PM
Power for 36-40" Scale Hi-Wingers E-Challenged Scale Kit/Scratch Built 8 Dec 02, 2001 09:25 PM
