Old Jun 10, 2015, 09:22 PM
stevea3342 is offline
Find More Posts by stevea3342
stevea3342's Avatar
United States, CT, Bridgeport
Joined May 2012
New Product
Fat Shark 5.8GHZ 5G8RX 32ch Race Band Receiver Module for Dominators
Has anyone taken a look at this?
http://www.getfpv.com/fat-shark-5-8g...ominators.html
Just wondering why it's cheaper than the Dominator Alpha and Beta VRX's when this one does the normal channels, plus the racebands plus 2 boscam bands?
stevea3342 is offline Find More Posts by stevea3342
Old Jun 10, 2015, 11:40 PM
TomC is online now
Find More Posts by TomC
Gold Coast Coolangata, Australia
Joined Nov 2003
If you refer to this fpvlab thread;
http://fpvlab.com/forums/showthread....380#post703380
You will see that FS has set a MAP pricing structure on these units. Big win for us, maybe not so for smaller, low volume shops though.
Imho at this price you would be nuts not to buy one of these instead of the regular fs 5.8g module if you are just now buying FS Dom V2 (or FS HD) goggles (which btw have also come down in price ~$50).
For now, since I already have the standard fs/immersion nextwave 5.8g module on my FS Dom V2's, I don't see the need for this. Maybe later, if I get into 250 quad racing and/or want to start using some Boscam vtx's.
TomC is online now Find More Posts by TomC
Old Jun 18, 2015, 04:14 PM
diydrone is offline
Find More Posts by diydrone
Leo
Joined Jan 2014
just ordered one, even though I just received my Alpha just yesterday. Hope the alpha will still come in useful.
Fatshark Dominator V2 Raceband 5.8GHz WWU (6 min 16 sec)
diydrone is offline Find More Posts by diydrone
Old Jun 18, 2015, 05:17 PM
TomC is online now
Joined Nov 2003
Pretty expensive paperweight imho. Maybe ok to have the alpha's as a backup?
Old Jun 18, 2015, 06:41 PM
v2rocketeer is offline
Find More Posts by v2rocketeer
v2rocketeer's Avatar
Australia, NSW, Ingleburn
Joined Mar 2013
Are these essentially the same as the TBS module with the different bands?
v2rocketeer is offline Find More Posts by v2rocketeer
Old Jun 23, 2015, 03:04 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
yes
greedyg76 is offline Find More Posts by greedyg76
Old Jul 07, 2015, 02:45 AM
perimec2 is offline
Find More Posts by perimec2
Joined Mar 2014
Hi Guys,
have you checked if it is working on the dominator V1???? I want to order it but I have red on hk page from a customer that was having trouble using it with V1....
thanks
perimec2 is offline Find More Posts by perimec2
Old Jul 07, 2015, 07:53 AM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
I have used this RX with all Dominator versions, 1 2 and HD. Works fine no issue at all
Old Jul 08, 2015, 06:44 AM
perimec2 is offline
Joined Mar 2014
Are you sure that it is the same RX module?? and you tried it with the fatshark dominator v1?
sorry but I just want to be sure before placing the order...
thansk
Old Jul 08, 2015, 08:50 AM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
Yes I'm sure....
I just said I've used the race band RX with all versions of Dominators. ALL includes V1
Regardless of the version, Dominators all use the same type receiver modules. Besides its only $30, if you don't like it sell it to someone in the classifieds
Old Jul 08, 2015, 08:57 AM
stevea3342's Avatar
Joined May 2012
I've used this module with the normal fatshark bands in Dominator V2's. Works great.
Old Jul 17, 2015, 04:12 PM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
Works great. I'd like to change bands easier though because me and my friends all fly different bands. SO I made this little mod.
Top of the pins is ground so you only need 1 wire to touch both top pins in the new switch. Or .. since it's ground just grab it from the antenna base or even the heat sink will work. But I used the 1 top pin. Then leave the pins off and use the outer one. Test for continuity as you go.
rocketscience is offline Find More Posts by rocketscience
Old Jul 17, 2015, 04:26 PM
TomC is online now
Joined Nov 2003
Good thinking!
Also looks like you could just dremel a little window in the hatch cover. over these pin switches so you can access them with a small screwdriver/plastic rod/toothpick. Should be pretty easy to get to if you are using a standard spironet antenna and it will avoid constantly removing the hatch (which eventually will loosen it) and removing the antenna.
Old Jul 17, 2015, 04:34 PM
stevea3342's Avatar
Joined May 2012
I saw on a site that the regular alpha band dominator modules are only $20 now.
Old Jul 17, 2015, 04:36 PM
Not a six pack
USA, IL, Chicago
Joined Jul 2008
Originally Posted by TomC View Post
Good thinking!
I thought about a hole but I think it would be a pain. The little switches can be pretty stiff and I'd hate to have to force something in there and risk scratching anything, though wood should be safe. With the outer switch you only need to solder 3 places on both ends (squeeze the 2 top pins together on the new switch and solder 1 wire to it since it's ground anyway).
Sold Fat Shark Dominator Alpha Band 5.8 Receiver Module Abzauris FPV Equipment (FS/W) 1 Jun 09, 2015 10:59 PM
Sold NIB Fat Shark Dominator 5.8GHz Receiver Module, Standard Bands RC OUTLAWZ FPV Equipment (FS/W) 3 Mar 08, 2015 02:19 PM
Sold Fat Shark Dominator 5.8GHz Receiver Module, Standard Bands Chad2323 FPV Equipment (FS/W) 1 Jul 22, 2014 07:53 PM
Sold Fat Shark Dominator 5.8GHz Receiver Module, Standard Bands Chad2323 Aircraft - Electric - Multirotor (FS/W) 3 May 25, 2014 09:03 PM
Sold Fat Shark Dominator 5.8GHz Receiver Module, Standard Bands Chad2323 FPV Equipment (FS/W) 0 May 25, 2014 05:29 PM
