Old Dec 13, 2014, 12:09 AM
c.walker is offline
Find More Posts by c.walker
Joined Jul 2006
Build Log
PW51 plank build
Needing a new plank, and feeling inspired by EdSoars fantastic TigerMoth build, I decided to try a similar project with slightly different materials. Since I've got access to good LZ's, and wanted to have good light wind performance, I'm building a 48" PW 51 plank tightly based on the Moth, but with white foam cores & balsa skins. The planform is close to the Moth, but with a little more chord at the root. Here's the basic idea:
c.walker is offline Find More Posts by c.walker
Old Dec 13, 2014, 12:17 AM
c.walker is offline
Joined Jul 2006
The wings get skinned in two stages. This makes it easier to build in the joiner hardware, and add ribbon spars to stiffen the ailerons. Cores were CNC cut by Eureka Aircraft, balsa is 1/16" contest grade from National Balsa. This is the first time I've used contest grade balsa for anything, and it's amazing how light & consistent the sheeting is; each 3"x48" sheet weighed between 9 & 11 grams. Cores were sheeted with polyurethane glue, no water (ambient humidity is fine), and kept under 5" vacuum for 6 hours.
Old Dec 13, 2014, 12:26 AM
c.walker is offline
Joined Jul 2006
Once the skins are on, it's time to mark out the ailerons, joiner block, and wing hold downs. Since none of this will be visible once the top skin's on, measuring everything accurately first is helpful.
The joiner's a 9/32 brass tube (1/4" ID) with a ply sub rib. The hold down areas get marked out and then diced before sheeting; this makes it easier to clear them out with tweezers later.
Old Dec 13, 2014, 01:04 PM
eric_laermans is offline
Find More Posts by eric_laermans
The Netherlands, OV, Kamperveen
Joined Oct 2011
Wow, great idea and concept. For light-winds, but probably able to fly through big air too. Why did you choose the 51? 75 seems fine for light winds also.
eric_laermans is offline Find More Posts by eric_laermans
Old Dec 13, 2014, 02:01 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
PW 51 would seem to be a better choice for higher wing loadings, but you are building light.
I think it will rip nonetheless!
Good build, thanks for sharing,
Andy
droydx is offline Find More Posts by droydx
Old Dec 13, 2014, 02:12 PM
c.walker is offline
Joined Jul 2006
I played around with the PW98, PW51, and blended variants; I went with the PW51 since it's got a very neutral pitching moment and better inverted performance. The goal here is light air aerobatics with good energy retention.
Old Dec 13, 2014, 04:34 PM
16141 is offline
Find More Posts by 16141
Cliff
16141's Avatar
Australia, QLD, Pacific Paradise
Joined Oct 2011
I use pw51 on my home brew flying wings and find it very good indeed
This is my home brew "Hawk"1200mm epp flying wing at the beach dunes in 16knots 8m/s wind speed
Cliff
rc hawk flying wing (1 min 46 sec)
16141 is offline Find More Posts by 16141
Old Dec 13, 2014, 06:03 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
DT56 is offline Find More Posts by DT56
Old Dec 13, 2014, 11:33 PM
c.walker is offline
Joined Jul 2006
Cliff
https://www.youtube.com/watch?v=jLOV...yer_detailpage
That's some lovely flying, great energy management. Exactly what I'm going for, albeit with a bit more lift. What's the total weight?
Old Dec 14, 2014, 12:23 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Applying the bottom skin first in a separate process is a good idea. As you say, it allows spars and joiners to be placed and sanded down to the top shape before adding the top skin.
I will copy that someday.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Dec 14, 2014, 04:16 PM
c.walker is offline
Joined Jul 2006
With the wings out of the bag, it's time to fill in the hold down blocks and add the root rib. I'd diced the foam in the hold down blocks with a razor before putting on the top skin, so it came out fairly cleanly with tweezers. The root rib is 1/16" ply, epoxied on. I'd glued in the joiner tubes so that about 1/16" stuck out past the core, giving the rib a good mechanical link to the tube.
Old Dec 14, 2014, 06:06 PM
c.walker is offline
Joined Jul 2006
Weight tracking, or everything adds up:
I wasn't sure how light I could build this. I originally wanted the completed plane to be under 16 oz. That's probably not going to happen. While the base components are quite light, here's a few numbers showing the progression:
Blank core: 0.7 oz
Wing skin: 0.5 oz
Wing with one skin bonded, joiner block glued in: 2.1 oz
Same with with top skin bonded: 3.0 oz => glue layer is 0.4 oz, joiner block is 0.5 oz glued in
Wing with hold down blocks filled in, and root rib glued on: 4.5 oz
With shaped tip: 4.9 oz
No single step adds that much weight, but they do add up. Also, it looks like if I had built this as a one piece wing, the total weight for the wing would be about 6 oz instead of 10 oz. That's significant for a 48" wing; with a nominal target weight of 16 oz, a 4 oz difference is 25% of the total. That means you'll need 11% more lift to stay up (though it'll also fly 11% faster ).
Old Dec 14, 2014, 06:56 PM
Mike_ is online now
Find More Posts by Mike_
Random slope flyer
United Kingdom, Scotland, Currie
Joined Feb 2013
I like the idea of doing the top and bottom skins separately. Will try copying this. How do you keep the skins aligned, do you just use tape?
Mike_ is online now Find More Posts by Mike_
Old Dec 14, 2014, 07:12 PM
c.walker is offline
Joined Jul 2006
Here's the alignment process:
1) oversize the skins by 1/8" in each dimension
2) line up the front edge of the core so that the skin just barely protrudes past the foam
3) roll the core back carefully, press down evenly all over
The polyurethane is quite "tacky", so at this point, the skin won't shift out of alignment. You don't need tape. Throw in the bag & cure.
When it's out of the bag, line up a straightedge on the foam TE, and trim off the excess skin at the back. When you repeat the process, this will be your alignment guide to trim off the excess skin from the other side.
This is slower than doing both at the same time, but much less stressful, and you're more likely to get good results. Picked up this trick from the instruction manual for an old CR Aircraft Turbo.
Discussion PW51 has two CoG for planks ? Marcos Quito Slope 3 Sep 24, 2010 05:45 PM
Help! elvevon deflections for PW51 plank? Chris Gough Flying Wings 0 Jun 21, 2010 07:28 AM
Build Log Drive65 PW51 plank (Was: Anhedral/Dihedral and washout in planks) +video! Crashaholic Slope 117 Sep 21, 2008 07:17 AM
Discussion Recommendations Wanted for PW51 Plank Planform screamin' eagle Slope 33 Mar 15, 2007 07:56 PM
Discussion soure for pw51 airfoil for a plank? Ryan Archer Slope 10 Mar 02, 2007 04:17 PM
