Old Jun 02, 2014, 03:12 AM
Brett
pmanu's Avatar
Auckland,New Zealand
Joined Jul 2005
Mini-HowTo
Servo Tester Dim those leds
Just a quick one here
Love my HK servo tester but the lights were way to Bright
So i did a mod and added a 10k resister
Cheers
Brett
pmanu is offline Find More Posts by pmanu
Old Jun 09, 2014, 08:06 AM
Ukraine, Kiev
Joined Jan 2009
My firmware for servotester Turnigy http://yadi.sk/d/oO961bkZDqUfn Addon in auto mode change speed
olegtur77 is offline Find More Posts by olegtur77
Old Jun 10, 2014, 04:19 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
I just colored the LEDs with a Sharpie
iskess is offline Find More Posts by iskess
Old Jun 15, 2014, 02:55 AM
Rowlett, TX
Joined Apr 2003
For a cleaner install, you could have also de-soldered the original surface mount resistors (bottom between the LED legs) and reinstalled higher value ones.
Ward is offline Find More Posts by Ward
Old Jun 16, 2014, 10:29 AM
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
That's just what I did with mine when I saw the original post. I used 10k but the LEDs are still quite bright.
A.
AndyOne is offline Find More Posts by AndyOne
Old Jun 26, 2014, 01:04 AM
Brett
pmanu's Avatar
Joined Jul 2005
yep they could nearly do with 15k + resistor's
any way you mod it will be better than it was
Sold Led 4 port servo tester 3drcparts Aircraft - General - Radio Equipment (FS/W) 1 Apr 12, 2013 10:19 PM
Discussion LED Strips (Like UH LED Strips) Dim with Throttle Bohh33 Night Flying 13 Aug 22, 2010 11:07 PM
Discussion LEDs are dimming with throttle in micro-heli problem Danny Troy Night Flying 17 Dec 18, 2007 10:01 PM
Discussion LED dimming circuit? dshuen DIY Electronics 19 Sep 27, 2007 04:04 PM
Dimly lit LED's on apache 2500 + long charging times, is it busted? Peter W Batteries and Chargers 2 Jul 14, 2005 02:32 PM
