Joined Dec 2002
![]() ![]() Aren't you going to show the clip from the camera inside the helicopter?? ![]() Thanks for sharing. |
United States, ID, Meridian
Joined Mar 2007
Got my Phantom yesterday,connected it to the Naza assistant to ensure everything was ok and had a couple of excellent flights.Today I tried to connect again to the assistant but nada.Tried different usb ports,computers,and still nothing.Opened up the Phantom to check the usb connection and all seeems ok.When I connect the Phantom nothing happens in the device mgr.
I can open the assistant program but the Phantom does not appear as connected which makes sense since the usb connection has not been recognized.It is still flying well but the ability to connect is crucial for updates and calibration. Any ideas fellas? Thks |
It is very wise to pull the props anytime you are working in the Assistant.
Not likely, but if for somereason it armed, it could be dangerous to you or anyone around. These things spin up and can become flying straight razors.....Better to be safe than sorry...! As long as you are getting the Green Blinking light (No Signal to the Motors) it should be safe, but when you disconnect it with the battery hot you could arm it by hitting the radio by accident, dropping it etc. JMO....... |
I noticed in Assistant that when you turned the TX off and then back on again in GPS Mode, the throttle was at zero. I've seen this also in my Assistant and it worries me that if I didn't bring the throttle back up immediately after turning the TX back on and toggle the the flight control switch S1 back to either GPS ATTI or ATTI, the the Phantom would drop like a rock.
1- Disconnect all. (Phantom - USB / BATTERY Cable ) 2- If Driver already installed, then uninstall it (not the Naza utility) 3- Reboot PC 4- Install Driver (and wait completion... some minutes...) 5- Turn on TX then Phantom... wait test OK. 6- Connect if possible to ANOTHER USB port. 7- Wait for Windows check... search and autoconfigure driver. 8- Run (or install - run) NAZA utility |
Joined Jul 2011
1. turn off the transmitter and wait 5 seconds at least. notice the 5 seconds is the most important thing. 2. pull down your throtle stick and power on transmitter again.If you don't wait more than 5 seconds and turn on transmitter, the phantom will quit from fail-safe. 3. after the transmitter is ready, pull throtle to middle position. 4. If you want regain the control to phantom, switch GPS to ATTI. After that everything are normal. |
Joined Mar 2007
When you connect your Phantom to the computer what appears in your device mgr? Thks |
| Thread Tools | |
| Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA | Lucidity47 | Multirotor Talk | 5 | Jun 07, 2012 12:31 AM |
| Video Multiwii Quadcopter Dji F-450 frame Updated Video | Anda Inc. | Electric Heli Talk | 1 | May 23, 2012 02:51 PM |
| Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters | QuadcoptersUk | Multirotor Talk | 8 | May 14, 2012 01:27 PM |
| Discussion DJI Quadcopter Frame BUILD Thread | Quad_Addict | Multirotor Talk | 77 | Apr 19, 2012 01:26 PM |
