Old Sep 25, 2014, 03:08 PM
hangtheman is offline
Find More Posts by hangtheman
Kid at heart..
United States, TX, Houston
Joined Apr 2014
HK Pursuit
Hi all, I just pull the trigger on a HK Pursuit from TFL. I have done much research and have ordered a SeaKing 180 esc to go along with it. i am planning on running all stock hardware for it now and looking to upgrade later. For those that have the pursuit, can you recommend what would be the best up grades for it? Also, any tips or suggestions for the Pursuit is also greatly appreciated..
Dillin
hangtheman is offline Find More Posts by hangtheman
Old Sep 25, 2014, 04:08 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Bulletproof combo of choice has been the Leopard 4074 2200kv on 4s with the T180. It will put you in the high 40's.
scorpion1 is offline Find More Posts by scorpion1
Old Sep 25, 2014, 04:11 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's mine, I later upgraded to a T180.
32" Pursuit Mono with Leopard 4074 (1 min 44 sec)
Old Sep 25, 2014, 04:38 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
The first thing you need to do is strengthen the motor mounts & battery tray.
You'll find that you can wiggle the motor from side to side & see the floor of the hull flexing & twisting. Plus the mount & motor tend to break away from the hull in your first big tumble.
I always add some lengths of 1/4" carbon rod along the mounts & floor of the hull. Makes everything strong & rigid.
Here's a link to a build I did of a Pursuit & a Delta Force Cyberstorm. It may give you a few ideas.
http://www.rcgroups.com/forums/showthread.php?t=2070396
The next upgrade is a welded one piece 3/16" flex shaft if the boat has one of those 2 part drive systems in it. It makes removing & greasing the flex much easier.
Cheers.
Paul.
785boats is online now Find More Posts by 785boats
Old Sep 25, 2014, 05:09 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's my upgrade thread: http://www.rcgroups.com/forums/showthread.php?t=1573031
Old Sep 25, 2014, 06:15 PM
Kid at heart..
Joined Apr 2014
Thank you Paul and Scorpion. Appreciate all the info. Looking forward to this boat.
Old Sep 26, 2014, 05:12 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Here is our version of the Pursuit, running as a limited spec P-Mono using a UL-1 motor on 4S, 90 amp HobbyWing speed controller, and using a CNC 42mm 3 blade prop from Offshore Electric.
Pursuit P-Mono Test Run (0 min 46 sec)
cyberhoops is offline Find More Posts by cyberhoops
Old Apr 02, 2015, 09:47 AM
Capt'n Crash is offline
Find More Posts by Capt'n Crash
Resistance is futile
Capt'n Crash's Avatar
Richmond Hill, Ontario
Joined Oct 2003
Greetings fellow Pursuit owners.
I've just finished building mine and I have a question regarding the stock cooling configuration.
Is there any real advantage to having the motor mount cooling hooked up or would I get more efficient cooling by leaving it out of the loop?
I'll be running a 4s 5000 mah battery with a Leopard 4074 2150 kv vented motor, Seaking 180A and a Grim Racer 42x55 s&b prop.
Capt'n Crash is offline Find More Posts by Capt'n Crash
Old Apr 02, 2015, 10:23 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I never run the mount cooling myself...........could offer minimal cooling if set up. If one is on the edge of having to use that to keep it in a proper temp zone the setup may be too "hot" to start with.
Old Apr 02, 2015, 01:59 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
G'day Capt'n.
I've run them both ways in various boats from monos, hydros & cats etc. I can't tell the difference one way or the other.
Theoretically it should be more efficient without using the cooling plate as the water flow would be slowed down slightly by the extra resistance of two small nipples, the path through the mount & the extra waterlines.
The maximum volume of water travelling as fast as possible through the system leads to optimum cooling.
But they certainly are used when I run outrunner motors in the boats.
Old Apr 04, 2015, 09:33 AM
Joined Oct 2003
Thanks for the replies.
I could see it maybe being beneficial with the stock motor because it's not vented were as the Leopard I'll be running is.
I guess I'll just have to try it out both ways and decide which is best
Discussion Cyberstorm & Pursuit. 785boats Racing Boats - Electric 19 Jan 13, 2014 12:37 AM
Sold Carrera 132 Digital Slot Car Set Hot Pursuit plus Wireless, Track, Pitstop, Case KiTCyclic Non R/C Items (FS/W) 2 Dec 18, 2013 03:33 PM
Discussion HK Pursuit set up advice benckie Racing Boats - Electric 9 Jun 24, 2011 01:41 PM
Discussion HK Pursuit set up advice benckie Dock Talk 0 Jun 24, 2011 10:51 AM
Alert 1 x 33" Pursuit left at HK for $179 + shipping syncronized Racing Boats - Electric 1 Nov 24, 2010 05:47 PM
