United States, GA, Covington
Joined Mar 2011
Im going to go with this one. It looks like the last one ill buy , http://heli-heli.com/items/electroni...ger-detail.htm
I was told it will charge a 6 cell 3300 battery in 12 minutes! Then the power supply will be 70.00 , im a home charger lol But this may have to wait till xmas due to my battery order and new nano which is really fun. Its my 1st to invert at eye level. I gotta try the 450 now! Not! |
United States, OR, Salem
Joined Nov 2009
2618v rx
I installed and flew about 5 battery packs through the hk450 with the 2618V rx and it flew great.
My flight times were averaging 5 min. I thought that was ok,but off the same batteries on the 2614V rx on the 450pro heli my flight times were averaging 8 min. So yesterday i flew the 450 w/2618V and it got 5:25 minutes of flight on it until it lost power than sat it down and took the battery out and put it in my 450pro w/2614V and flew that one for another 3:45 minutes. I then took the tail assy off the hk450 and the 2618V and installed the 2614v rx and brushless tail motor and whammo. I am now getting over 8 min. of flight on it. before I have changed out the tail assy 2 times but it still would only get just over 5 min of flight. The 2618V was stable and the tail held great after piro's but for some reason the 2614v installed in the same heli with nothing changed,but the tail motor and rx was just more stable and easier to fly. I cant put my finger on it but i am keeping the 2614 rx on it with the tail motor and selling the 2618V. |
What about gear mesh? Are there any gears meshed too tightly? Also, is there any friction in the tail assembly? When you put on the brushless motor, you may be merely eliminating a part somewhere that is sucking up power. Just a thought.
Latest blog entry: Creating a plumb line pitch gauge
Sure wasn't happy to hear that since I just reordered a 2618v for my TT tail version 450 HK build. Do you think the 2618v is sucking up the battery? Or just the tail setup? Or could it possibly be the added tail servo needed for the TT setup consumming the battery power. Just some thoughts.... |
Joined Nov 2009
Driving the tail servo and the belt drive could cost more juice than running the brushless tail motor alone. So, that's probably why you saw decreased flight times.
That power supply won't cut the mustard, not for that 1000 Watt charger. The power supply is only a 350 Watt supply, you need a 1000 Watt supply which Heli Heli doesn't sell & is out of stock on the 350 Watt.
I know of a place that sells a 1000 Watt charger & power supply plus gives you the balance/parallel multi charging setup for a total of $300.00 Let me find the link & I'll post it up here. http://epbuddy.com/index.php?main_pa...j5blu1hv3m3m31 Don't foget the power supply 1000 Watts. Quote:
Yea EPBuddy is a good place for s 1000w power supply
I got mine there but I got the celpro 6 charger. You may want to do a comparison. http://epbuddy.com/index.php?main_pa...roducts_id=288 |
HB
I'm using the smaller Voltz charger w/one 350W power supply & charge my 6s 3300 mah batt @ 10a in less than 15 min. Dustin only uses one 350w power supply with the bigger charger with similar results. That charger will work w/2 350W power supplies. It's a good charger. I recommend it. Nice to be able to get IR readings on each cell on your batts. You get a much better idea on the health of your lipos. I posted a pic of my setup on this thread a while back when I first got it. http://heli-heli.com/items/electroni...250-detail.htm Quote:
Joined Mar 2011
I can only run one power supply for now and then upgrade to a second power supply later.
| Thread Tools | |
| For Sale BNF T-Rex 500 ESP Mikado V-Bar | dawhale | Aircraft - Electric - Helis (FS/W) | 2 | Apr 11, 2011 04:16 PM |
| Sold CopterX 250SE NIB COMPLETE T-Rex 250 clone | The Nemesis | Aircraft - Electric - Helis (FS/W) | 0 | Apr 10, 2011 11:11 PM |
| Sold T-Rex 250 Clone W/Align Parts | Dingo7222 | Aircraft - Electric - Helis (FS/W) | 7 | Apr 07, 2011 08:08 PM |
| Sold Loaded T-rex 250 Clone (Perry) | Dingo7222 | Aircraft - Electric - Helis (FS/W) | 7 | Mar 11, 2011 04:21 PM |
| Sold Clone T-Rex 250 BNF W/AR6100E $150 | kevinlamrc | Aircraft - Electric - Helis (FS/W) | 8 | Mar 06, 2011 04:00 PM |
