Old Oct 27, 2013, 12:16 AM
Sundance2013 is offline
Find More Posts by Sundance2013
United States, CA, Suisun City
Joined Sep 2013
dji Phantom compass position
Does the compass have to be in a specific location or orientation? I purchased a set of the helio type landing skids for the phantom but it will not fly right with them installed. As soon as it lifts off it starts drifting sideways and nothing I do corrects this and it only gets worse and I have to cut power to land as it's to out of control to land. I put back on the stock skids and it fly's just fine.
The only thing I can think of that would cause this is the position or orientation of the compass. I trued to put it similar to the way it was on the stock skids. I don't think the composition of the carbon fiber tubes would be a problem but I don't know for sure.
Any one have skids installed and flying successfully or any ideas what might be causing the problem?
Sundance2013 is offline Find More Posts by Sundance2013
Old Oct 27, 2013, 12:24 AM
dotster77 is offline
Find More Posts by dotster77
1000 Islands NY State
dotster77's Avatar
United States, NY, Alexandria Bay
Joined Aug 2013
ya, the compass position is super important.. has to be in a similar position as it was on the stock legs..
even a degree or too off and it will cause flying problems..
dotster77 is offline Find More Posts by dotster77
Old Oct 27, 2013, 12:30 AM
ElGuano is offline
Find More Posts by ElGuano
Joined Sep 2013
Yes it absolutely does. What you experienced is the "toilet bowl effect" or TBE stemming from compass mis-orientation. You can fight it with stick input but it's hard, and within a few seconds it can get away from you.
In short, look at the compass mount on the stock landing gear. IIRC it should be on the back left leg, with the flat metal plate of the compass module facing the back right leg. If you change the position of the compass, or the leg it's mounted to, you MUST replicate the position it's in while stock (square to the ground, cable coming out the top, metal plate facing towards the right).
I switched landing gear and inadvertently put the compass on the back right leg, and it took me a while to realize it was the compass causing the crazy TBE.
ElGuano is offline Find More Posts by ElGuano
Old Oct 27, 2013, 01:16 AM
Joined Sep 2013
Man does it ever ...and being new and inexperienced doesn't help. At least now I know what it is and can deal with it....I hope. I assumed that recalibrating it would compensate for it's new position/orientation ...my mistake.
The configuration of the new legs the way they are it's not possible to get it orientated as it is on the stock legs. So I will need to make some kind of pad that allows me to duplicate the orientation it's in on the stock leg, correct.
Old Oct 27, 2013, 05:26 AM
kenpoprofessor is online now
Find More Posts by kenpoprofessor
Multirotor geek
United States, AZ, Phoenix
Joined Mar 2013
Yea, those landing gear are cool, but they don't provide a buffer to put the compass back in the same spot. It's why I don't put them on
kenpoprofessor is online now Find More Posts by kenpoprofessor
Old Oct 30, 2013, 03:17 PM
PhunkeeQuad is offline
Find More Posts by PhunkeeQuad
Joined Oct 2013
First, thanks to Sundance for asking about the same exact issue I've been having, and thanks to everyone else for clearing it up. I just added an aftermarket landing gear (http://www.heli-world.com/detail.aspx?ID=11420) and lost flight stability almost immediately thereafter. I was also worried that the carbon fiber legs might be causing it, but I see now that even though I'd mounted the compass *close* to the original location, it was still about 2" off horizontally.
After reading this thread and poking around a bit with my phantom, I think I may have a workaround that I'll try later today if I have the time: taking one of the original phantom landing gear and cutting it up so it just forms a post for mounting the compass. I'll post pics if it ends up working
PhunkeeQuad is offline Find More Posts by PhunkeeQuad
Old Oct 30, 2013, 09:44 PM
Joined Sep 2013
I look forward to hearing how this works.
Would be nice if one of these company's selling all the 3D printed stuff for the Phantom would make a little mounting pad for the compass.
Something else that would be nice is if these &^$% selling this stuff would be a little more up-front and honest and say hey you need to modify the compass location to make this thing fly instead of selling it knowing full well your Phantom will not fly unless you do.
Old Oct 31, 2013, 01:10 PM
Joined Oct 2013
Update: repositioning the compass as I described went off without a hitch, pics of the results are below. However, I haven't had a chance yet to do a test flight with the nasty weather today.
It only took 15 min or so with a Dremel to get this to work, including the time spent shortening the rear metal mounting shaft that connects the main landing gear plate with the Phantom. It isn't the prettiest solution, and I'll probably paint the piece black or something to make it less obvious, but it seems like it should accomplish exactly what I need
Old Oct 31, 2013, 01:23 PM
ElGuano is offline
Joined Sep 2013
Many aftermarket landing gear do--the Simensays options all include compass mounts. Other makers do as well. I guess it all depends on whether the gear is custom made for the Phantom or just kind of retrofitted from a generic design.
Old Oct 31, 2013, 01:34 PM
Joined Sep 2013
[QUOTE=PhunkeeQuad;26516754]Update: repositioning the compass
Looks OK to me and I don't see why it wouldn't fly normal.
Just wondering, do the skids show in frame when you do video (assuming you are using
a GoPro)?
Old Oct 31, 2013, 01:53 PM
Joined Oct 2013
Yeah, the one I'm using was originally engineered for the 450/550 and they just added some extra-long screws and shafts in the rear to retrofit it to the Phantom.
I honestly hadn't seen the Simensays gear (and other goodies), thanks for the tip! I haven't given up yet on making the gear I have into everything it should have been, but when I hit that point I'm sure I'll be trying out the folding gear!
Old Oct 31, 2013, 02:10 PM
Joined Oct 2013
a GoPro)?
Hero 3 black edition, and it's pretty easy to keep them out of the frame. Even on wide, I can keep them out if the camera is horizontal. Switching to med gives me a lot of range to tilt down before they appear.
Old Oct 31, 2013, 09:54 PM
Joined Sep 2013
Didn't know about the Simensays ones when I purchased. Wonder if they sell the compass mount by it's self?
Old Oct 31, 2013, 10:22 PM
dotster77's Avatar
Joined Aug 2013
they do not and I don't think the angle would be quite right regardless.. his compass mount is designed for the angle of his legs..
maybe you could make something out of Instamorph or something similar..
http://www.amazon.com/InstaMorph-Mol.../dp/B003QKLJKQ
Old Feb 16, 2014, 02:19 PM
francischie is offline
Find More Posts by francischie
francischie's Avatar
United States, CA, Eastvale
Joined Dec 2013
Compass location
Based on my experience what matters is just the orientation of the compass which must be similar to phantom. The wire should be on the top and it should be facing right.
Here's the video of how stable it is after mounting the compass inside my quadcopter and fixed the toilet bowl effect.
DJI Phantom compass relocation for new custome frame (1 min 8 sec)
I didn't take a video of yawning but still works very good.
francischie is offline Find More Posts by francischie
Discussion DJI Phantom compass error thintz Multirotor Talk 6 Aug 17, 2014 05:31 PM
For Sale DJI Phantom GPS unit and compass RDTague Aircraft - Electric - Multirotor (FS/W) 9 Oct 27, 2013 05:49 PM
Discussion DJI Phantom Compass Calibration ChrisMohrSr Multirotor Talk 1 Oct 24, 2013 02:35 PM
Discussion DJI Phantom/Naza Compass Pinout? The Flying Farmer Multirotor Talk 2 Oct 10, 2013 08:48 PM
Discussion DJI Phantom or DJI F550? ThePhantomMenace Multirotor Talk 4 Apr 14, 2013 07:18 PM
