Old Oct 05, 2015, 12:08 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Bridi Tercel ?
I had a kit of this years ago. I built fuselage but at that time servos that small were crazy priced. now way different story plus RX's. They had spot for finger to give hand lauch. anybody fly one of these I see them listed once in awhile. I had a few Bridi kits and iron wood quite heavy.
dankar04 is offline Find More Posts by dankar04
Old Oct 05, 2015, 12:49 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
I have Tercel plan's and a Bridi Kastaway kit.
prodjx is offline Find More Posts by prodjx
Old Oct 06, 2015, 07:04 AM
Wind Shadow is offline
Find More Posts by Wind Shadow
Wind Shadow's Avatar
East Coast
Joined Jan 2003
Built a Tercel years ago...all I remember was it was not very impressive....maybe with some of today's light weight equipment it would do better. Even in light condition slope soaring, it would be scratching at the bottom . Would build just about anything else. .....
Wind Shadow is offline Find More Posts by Wind Shadow
Old Oct 06, 2015, 09:01 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Tercel was designed a long time ago. Small wing and sure wing loading was not good at all. Gimic at time was Gernade launch they called it. Slot in fuse to get finger grip to throw bird. Top Flight had a better design called Wristocrat. About 10" bigger wing. DLG Gliders are off charts money wise. Yes vast improvement and state of art composites.
I had a couple small battery packs made for small gliders from cheap batteries packs. I was going to build a Mountain models DL-50.
Maybe improved Tercel with bigger wing/ much lighter gear would fair better.
Old Oct 06, 2015, 10:09 PM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
I also have 2 Wrist-O-Crat's and templates for making the chuck glider that came with the kit. It's a great flyer. I once sloped the berm on the shore of the big lake in Florida for 20min's I have that on video too. The Tercel has alot of fin under the tail and I've wondered if it could be DLGed.
Old Oct 07, 2015, 02:54 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Kind of a shame most woodie small birds are gone from production. Small RC gear is easy to get and good priced. There are many composite small birds and some quite pricey. Guess I arrived to late to party.
Old Oct 07, 2015, 09:57 AM
Kai Thomsen is offline
Find More Posts by Kai Thomsen
Joined May 2013
Hi, nice little bird. A friend of mine flies it since 20 years. Superb little thermiker.
Kai
http://www.vatertagsflieger.de/
Kai Thomsen is offline Find More Posts by Kai Thomsen
Old Oct 08, 2015, 09:56 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Thanks for sharing pictures. Guess I will keep eye out for a kit. Small simple hand lauch glider would be cool. No V-tail/ elevons etc.
Old Oct 08, 2015, 07:30 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
They're good airplanes specially for slope. They penetrate high winds quite well given their weight. We used to roll them as though they had ailerons.
Sailhigh is offline Find More Posts by Sailhigh
Old Oct 09, 2015, 03:40 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I never heard much about Tercel. From posts here sounds like mostly good reviews. Some folks never like anything and happy to bash when given chance. If I find a kit i'll suely copy it to have backup.
Old Oct 11, 2015, 05:19 AM
Joined May 2013
...ok, here is another one. This Tercel's home is Berlin. When weather conditions are good, take a look to the Teufelsberg.
Kai
Old Oct 11, 2015, 12:50 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Nice shot of Tercell doing its thing. With tiny servos available now and tiny Rx's shoukld be good to go. i have a few small battery packs made up by cheap batteries. . one cell up front / three behind for very narrow bodies. Plus a few 4.6g servos. I could use a small glider for local park and pratice.
Old Oct 14, 2015, 08:54 AM
East Coast
Joined Jan 2003
Bashing?
Originally Posted by dankar04 View Post
I . Some folks never like anything and happy to bash when given chance. I
Well, since I am the only one who posted a not so glowing statement on the Tercel, I assume I am the "some folks" alluded to in the above comments...I don't recall having a history of "happy to bash" when I get a chance. Have been building and flying since 1976, mostly sailplanes of all types.
And most of them flew well...you asked for opinions, I gave you mine.
But, I do not appreciate the "happy to bash" when I get a chance statement. The Bridi Tercel did not impress me in any way...You did not ask if it was a good high wind slope soarer. Maybe it was, but I did not build it for that.
Remember, man hole covers will slope soar if the wind is high enough!
Wind Shadow
Old Oct 14, 2015, 12:44 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
My plan is to copy kit and use my own wood. Bridi kits i have had before wood was as heavy as any i have seen in wood models. Covering will be lite econocote types. Servos may options on small size/ plus rx's. I am looking for small practice plane. I don't need a hi-performace and this simple set up should be fine. No elevons etc.
Plus small wingspan might be able to use SAL or DLG ? Might even scale it up 10% on scarch build. I had another small glider that had fold out wing. Once launched outter panels would release to full span. Idea was more height. i do not recall name of glider.
Old Oct 17, 2015, 12:16 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Member on forum sending me a copy of plans. Guess plans don't show tapered smaller ribs. No problem. Make a root rib and tip and carve the ones needed.
Sold Bridi Tercel Grenade-Launch Glider, Mint in box yabe Aircraft - Sailplanes (FS/W) 3 Aug 12, 2015 11:40 PM
Help! Bridi Tercel hlg kit rcbobcat55 Hand Launch 0 Nov 06, 2014 08:03 PM
Found Bridi Tercel glider kit rcbobcat55 Aircraft - Sailplanes (FS/W) 1 Nov 04, 2014 08:49 AM
Sold Bridi Tercel Grenade Launch Glider mewert Aircraft - Sailplanes (FS/W) 2 Nov 01, 2014 07:07 PM
Sold Bridi Tercel sailplane kit CADILLAC200 Aircraft - Sailplanes (FS/W) 5 Feb 18, 2014 02:59 PM
