Old Feb 07, 2016, 01:04 PM
nadt770 is online now
Find More Posts by nadt770
AMA L68621; WA2LLX
United States, NY, Lake Katrine
Joined Apr 2001
Originally Posted by sink rate View Post
I did not clean the servo, so I'll give that a try. Thanks. I do have the spoiler panel that I will glue in place if I could get the darn flaps to work properly.
Clean first then lightly sand off plastic gloss from gluing area then glue. If you don't want to mark up servo you can use heat shrink tubing around servo case then clean and scuff the heat shrink. I've done it both ways.
John
nadt770 is online now Find More Posts by nadt770
Old Feb 07, 2016, 02:51 PM
sink rate is offline
Find More Posts by sink rate
sink rate's Avatar
United States, GA, Savannah
Joined Aug 2006
Thanks. I'll give that a try. I'll just sand the servo. Thanks again!
Gene
sink rate is offline Find More Posts by sink rate
Old Feb 07, 2016, 03:47 PM
AMA L68621; WA2LLX
Joined Apr 2001
Gene
Gene, make sure you clean the molding residue off plastic first. Otherwise you will mix it into the sanded surface. Probably would not make a difference but better safe than sorry.
John
Old Feb 07, 2016, 07:12 PM
Scale Freak is offline
Find More Posts by Scale Freak
Canada, AB, Edmonton
Joined Jul 2007
Just a little update, I made the flags for just behind the cockpit windows and I redid the cockpit windows as well. They aren't perfect, but better than the stock decals.
Just waiting on electronic components for the lighting and will soon build a test stand for the engines.
Its getting there slowly!
Scale Freak is offline Find More Posts by Scale Freak
Old Feb 08, 2016, 10:28 PM
sink rate's Avatar
Joined Aug 2006
If I was to assume, and we all know how that will go, the wire for the aileron servo will have to go through the a hole that I'll have to cut in the engine pylon?? Is that how everyone has accomplished this task? Thanks
Gene
Old Feb 09, 2016, 01:28 AM
Inline12 is offline
Find More Posts by Inline12
Inline12's Avatar
United States, CA, Pleasanton
Joined Dec 2008
Gene
Yes that is correct. Some have notched and some have drilled a full hole.
Inline12 is offline Find More Posts by Inline12
Old Feb 09, 2016, 04:28 PM
sink rate's Avatar
Joined Aug 2006
Thanks. It's sad to get old. When I was young I wouldn't hesitate to cut into something. Now am afraid. it's nice to have guidance from all of you. Thanks.
Gene
Old Feb 09, 2016, 08:49 PM
Fontaine is offline
Find More Posts by Fontaine
RC Aviation
Fontaine's Avatar
Joined Dec 2014
Thats lookin good there scale
Fontaine is offline Find More Posts by Fontaine
Old Feb 09, 2016, 09:44 PM
sink rate's Avatar
Joined Aug 2006
Are you guys using epoxy to glue the nacelles in place or hot glue? I do have my flap and aileron servo wires going through the nacelle. Had to reroute the one wire because the extension connection would have landed right on the pylon. Please let me know what you think or what you may see that I have messed up. Thanks
Gene
Old Feb 09, 2016, 09:55 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
sink rate
epoxy doesn't stick well to this foam , the nacelle on these
wings are part of the structure - when my wing failed it was
at the nacelle. also hot glue not on structural parts.
Gorilla glue, foam tact, hobby king sells a good glue
http://www.hobbyking.com/hobbyking/s...lue_4_oz_.html
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Feb 10, 2016, 06:19 AM
sink rate's Avatar
Joined Aug 2006
Thank you pulsery! That is good to know. I do have foam tact that I can use.
Old Feb 10, 2016, 05:53 PM
AMA L68621; WA2LLX
Joined Apr 2001
Getting' old sucks!
Gene
Oh man Gene, did you have to remind me, I'd almost forgotten I was getting old. Oh wait I forgot…oh never mind
Old Feb 10, 2016, 09:39 PM
sink rate's Avatar
Joined Aug 2006
Well here is the top of the right wing finished. Getting ready to drill a 4mm hole in the gear to replace the pin.
Old Feb 11, 2016, 01:17 AM
Yeller Aircraft is offline
Find More Posts by Yeller Aircraft
United States, CA, San Diego
Joined Sep 2013
Nice!
I think I'll just go with outboard flaps, too. What did you use for the spoilers? How will you actuate them?
Yeller Aircraft is offline Find More Posts by Yeller Aircraft
Old Feb 11, 2016, 05:19 PM
sink rate's Avatar
Joined Aug 2006
Thanks. This is my first foam/modification I've done in my 30 years of rc, so I went with just the outboards for now, which has been a challenge. The spoilers are glued. Maybe next plane I'll make the spoilers operational with inboard flaps as well. Surprisingly I did a much better job on cutting the other flap so I hope it will go much easier. On the spoilers I used 1/8 inch balsa sealed with baby powder and WBPU
Gene
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
