Old Dec 29, 2014, 09:54 AM
Unregistered User
Eagle2Nitro's Avatar
United States, LA, St Francisville
Joined Apr 2014
I had to babysit my younger siblings this morning, and it was raining, so I decided to try and hover my MX2 in the living room/kitchen.
My hatcam was mounted at a bad angle, so the video isn't very good.
Fancy Foam Mini MX2-Living Room Hover! (1 min 35 sec)
I accidently hit the counter once.
Eagle2Nitro is online now Find More Posts by Eagle2Nitro
Latest blog entry: Full Scale Aircraft
Old Jan 10, 2015, 11:32 PM
Leawood, KS
Joined Nov 2010
My MX2 is on the way.
sjair is offline Find More Posts by sjair
Old Jan 11, 2015, 08:24 AM
Unregistered User
Joined Apr 2014
What electronics are you planning on using?
Old Jan 13, 2015, 10:00 AM
Leawood, KS
Joined Nov 2010
I'm going to try my old beast motor. I haven't decided on servos, I might go for the more conventional servos out of my old eflite zero, rather than the linear micros from the beast. I hate those servos. I could ues one aileron servo then, like my larger flat foamies.
Old Jan 13, 2015, 10:05 AM
Unregistered User
Joined Apr 2014
I think the MX2 will probably fly better with rotary servos. Is your Beast motor 2300kv or 2500kv? I run the 3000kv/Yak prop, which gives pretty good power. You will barely have enough power to hover with the 2500kv, and just a little bit more with the 2300kv, unless you run 3S.
Old Jan 14, 2015, 11:21 PM
Leawood, KS
Joined Nov 2010
It's the 2300kv motor. I thought there were people on this thread saying that they used the Beast motor and got good performance out of it.
Old Jan 15, 2015, 11:05 AM
Leawood, KS
Joined Nov 2010
Given the Beast equipment is what I have to start with, has anyone tried a different prop, other than the one that came with the beast?
I will be using the 2300KV Beast motor, and the Beast BL6400 brick. The linear servos on the brick will drive the rudder and elevator, I will be using a rotary servo from the Eflite Zero for the ailerons. I see some have used the Beast motor, and been satisfied, we'll see what happens.
Old Jan 15, 2015, 11:14 AM
Unregistered User
Joined Apr 2014
You will have awesome power if you run the Yak prop/2300kv on 3S. Who has used the 2300kv or the 2500kv, and liked it?
Old Jan 15, 2015, 04:38 PM
Leawood, KS
Joined Nov 2010
I don't remember. I thought I saw it in this thead. At any rate, it is what I have. If I don't like, its an easy fix another time. I would consider 3S, but I dont know what the brick can handle.
Old Jan 15, 2015, 05:30 PM
Unregistered User
Joined Apr 2014
Is your Beast brick AS3X? If it is, it can handle 3S.
Old Jan 15, 2015, 10:24 PM
Leawood, KS
Joined Nov 2010
It is not. It is the bl6400.
Old Jan 15, 2015, 10:26 PM
Unregistered User
Joined Apr 2014
Then it probably won't handle 3S.
Sold NEW Fancy Foam Andrew Jesky Blender BIPLANE wolfcbr2003 Aircraft - Electric - Airplanes (FS/W) 11 Mar 14, 2012 07:13 PM
Sold ... cam17 Aircraft - Electric - Airplanes (FS/W) 1 Feb 29, 2012 11:43 PM
Wanted UMX guts for micro beast TMAC4123 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Feb 29, 2012 06:36 PM
Sold SOLD - Fancy Foam Vrolet V1 F3P 3D kit with servos - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 29, 2012 10:28 AM
Question Looking for build for Fancy Foam Sbach 1.3 dan n 3D Foamies 1 Jan 07, 2012 07:09 PM
