Old Feb 07, 2015, 09:23 AM
Joined Dec 2009
hello guys,
afak, pl8 balancing current is 1A, but i read somewhere it turns into 3A thanks to the "node charging" feature. could someone explain it, please?
is it true that only pl8 has this feature and pl8-duo doesn't?
i also wonder if a bigger balancing current would necessarily mean a smaller balancing time.
thanks.
Can'tFly is offline Find More Posts by Can'tFly
Old Feb 07, 2015, 11:34 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Originally Posted by Can'tFly View Post
hello guys,
Node only charging is limited to 3A due to the size of the balance wire on the battery pack. However balancing current is still 1A. But this is a bypass current. It takes away from the charge current rather than adding to it.
Yes, only the PL8 has a node only charging option.
Yes.
thanks.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Feb 07, 2015, 02:05 PM
Joined Dec 2009
Originally Posted by ggcrandall1 View Post
Glen
Glen,
thanks a lot.
Old Feb 07, 2015, 05:30 PM
Seattle
Joined Sep 2007
thanks.
It really depends on what is actually occurring during the balancing period. Technically the slow stage at the end of the charge is not normally taken up by balancing. The charger starts balancing the at 3.8v per cell and is often done well before the pack reaches 4.2v per call.
The log slow stage (called the constant voltage or CV) stage is taken up by the charger slowly tapering off the current. If you have very long CV stages, the CV termination current may be set too low for the packs and charge rate. Increase the charge rate or raise the CV termination current.
Gregor99 is online now Find More Posts by Gregor99
Old Feb 15, 2015, 11:33 PM
United States, MA, Lowell
Joined May 2004
Originally Posted by everydayflyer View Post
It can be adjusted up to 4.30 per cell max. so close but not 4.35.
Charles
I wonder if this is something that could be fixed in firmware at some point or would it require a hardware change? These 4.35v Lipos might become all the rage and I'd had to have to get rid of my two PL8s.
Neil_SC is offline Find More Posts by Neil_SC
Old Feb 16, 2015, 05:34 AM
USA, GA, Marietta
Joined Aug 2005
Two new presets have been released for the PL8 and PL6.
They are: LiPo HVBlend 427 and LiPo HVBlend 435
As you would expect they are for the new high voltage ( 4.27V and 4.35V) LiPo's.
Glen
Old Feb 16, 2015, 02:24 PM
Joined May 2004
Wow, awesome. Thanks.
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 32 Sep 17, 2014 04:09 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 04:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 06:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 05:43 AM
