Old Jan 04, 2016, 07:44 AM
BillyBag2 is offline
Find More Posts by BillyBag2
United Kingdom, Bishops Cleeve
Joined Jan 2016
Question
UK 5.8GHz only 25mW, whats the range?
The UK limit for power at 5.8GHz looks to be 25mw. What sort of range could I expect to get using this power with standard antennas, assuming it is line of site and also away from a built up area. Has anyone any advice about using above 25mW in the UK?
BillyBag2 is offline Find More Posts by BillyBag2
Old Jan 04, 2016, 08:17 AM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Read here:
http://www.truerc.ca/news/rf-link-budget-2
With a good receiver and good omni antennas, I reached 600M with 1mW.
If you use a directional antenna at one end, you will fond that 25mW is plenty.
Approximate range can also be calculated using www.maxmyrange.com
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Jan 04, 2016, 09:01 AM
Joined Jan 2016
Thanks, this is reassuring.
Old Jan 04, 2016, 12:25 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The furthest I have flown with 25mw is about 800M. I have not tried further because my RC radio telemetry starts reporting Low RSSI.
The secret to good range is an high quality receiver and high gain antenna. I have a FR632 receiver and Pepperbox antenna. I get a solid signal at 800M.
RC Man is offline Find More Posts by RC Man
Old Jan 06, 2016, 10:22 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I've gone 2km on 25mW. Of course this was with a directional antenna (Pepperbox - same as HugeOne's X2-air) on the receiver. This is not typical, though. HugeOne and I are professionals on antenna design and theory. However, 1km is certainly sustainable on 25mW.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 06, 2016, 11:35 AM
Joined Jan 2016
Thanks. I have "invested" in a helical antenna too. The same handedness as the TX (I hope). More out of curiosity than anything else.
Hopefully the rest of the kit is in the post. In theory it will fly out of the box.
I'm sure from this thread that flight skills will limit my range to start with. I did not want to be disappointed because the UK legal kit was under powered.
I will try and remember to report back on my experiences from the other end of the FPV spectrum. I have in the back of my mind that a linear antenna with receive a circular signal. Is this correct? I think there may be a linear (looks like a wifi router antenna) or a clover leaf for RX. Was going to compare the two. Is it true the clover leaf is more robust against multi path issues? Also I think it has a greater vertical angle? I'm not sure if the antenna performance will be dominated by quality so I will pick and mix to start and see what happens.
Old Jan 06, 2016, 12:47 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes but with a 3dB loss (40% range reduction)
True if another circular* antenna is at the other end of the link.
*Not all antenna are circular even if they claim to.
-Hugo
Discussion UK FPV 5.8ghz 25mw need help phantomnoobie FPV Talk 2 Nov 05, 2015 12:07 PM
Wanted ImmersionRC - 25mW 5.8GHz A/V Transmitter ImmersionRC - 25mW 5.8GHz A/V Transmitter flywmoi FPV Equipment (FS/W) 2 Dec 09, 2014 07:17 AM
Found 25mw 5.8GHz transmitter (for UK use) brarna FPV Equipment (FS/W) 0 Jul 08, 2013 06:04 PM
Sold ImmersionRC 25mW 5.8GHz Video Tx asifjahmed FPV Equipment (FS/W) 0 Nov 15, 2012 08:26 PM
Discussion 25mw 5.8Ghz VTX in the US Tarro FPV Talk 2 May 19, 2012 04:25 AM
