Old Mar 25, 2015, 05:04 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I'm happy to do the maths for you Rodizio:
650MHz means a wavelength of almost half a meter.
A cloverleaf's diameter is a little bit less than two times a quarter wavelength.
So the diameter will be around 25 cm (10").
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Mar 25, 2015, 07:13 PM
Joined Dec 2012
For the following: I am talking about a single lobe, not the big "S"...
Question 1)
According to the original spec, the angle that is 110 should be 114.593 in order to have a standard arc which can be calculated by
S = r * Theta
, where Theta is the angle between the two radii. Note that Theta is in RADIANS...
In my case (trying to make it for 5.845 GHz) which is very close to 5.8 GHz per spec:
S=26.263814 mm
r =13.131737 mm
Theta = 114.593 degrees
Should it not be a standard arc? (ie. bowing out a little due to 110 degree as opposed to calculated 114.593 degree)
Question 2)
I understand that we have to have some "loss" due to bending of the wires cause it is not a perfect bend... Should the arc length still be:
arc length = (length of the wire (ie: 53mm) - (2 * 1/4 wave length) ???
Thank you for your effort.
K
TheKaduu is offline Find More Posts by TheKaduu
Old Mar 25, 2015, 10:12 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Question 1)
S = r * Theta
S=26.263814 mm
r =13.131737 mm
Question 2)
K
I believe you are over-thinking this, but yes you are correct.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Mar 26, 2015, 12:04 AM
Joined Dec 2012
By the way, thank you Alex for putting this for everyone. It is such a service to the community...
"I believe you are over-thinking this"... So, the design is very forgiving then?
Thanks again!
K
Old Mar 26, 2015, 10:33 AM
JulianGoesPro's Avatar
Joined Jun 2014
It's hard to describe but with the Gaits FPV Mini Quad Racing I want to get everything quite in a smal space and a 2.4 vTx could fit a GoPro "inside".... is that a really bad idea or should I be fine for quad racing (so no long range at all)
Thanks!
JulianGoesPro is offline Find More Posts by JulianGoesPro
Old Mar 26, 2015, 12:57 PM
United States, OH, Willoughby
Joined Mar 2014
Alex, can you confirm if the ultras connection 90 degree are touching the CF frame is bad? I had seen some speculate this.
ktmaprilia is offline Find More Posts by ktmaprilia
Old Mar 26, 2015, 01:39 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
"forgiving" is a relative measure. Compared to other antennas the cloverleaf sits somewhere in the middle when talking about bandwidth. But at 5.8GHz it's the small size that makes it hard to get the lengths correct. The angles between the lobes aren't critical. A few degrees less or more doesn't matter.
As for your second question, I don't think it matters much if the bend is not perfect as long as the wire length is correct. A wavelength remains a wavelength, also if there are sub-bends (that change the radiation pattern etc. a little bit).
Just my thoughts. No scientific proof
Martin
Old Mar 26, 2015, 03:46 PM
Joined Dec 2012
-Alex
Well, I already bought the Bluebeam Ultra set from GetFPV.com... I wanted to get it right and at least pay my due for using your specs for other models I may build the antennas for.
I have a question though... I have quadcopter. For that, I also bought 20cm extension to put the Airscrew on top of everything outside the cover for the HK H.A.L. frame I have. Would this extension setup affect the electronics and/or cause loss in the transmitted video signal?
Thank you for your time,
K
Old Mar 26, 2015, 04:55 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thanks again!
K
Indeed it is very forgiving
Old Mar 26, 2015, 04:56 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I have seen many people do this. I don't think it is a problem.
-Alex
Old Mar 26, 2015, 04:57 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
K
Not to any discrenable level. I do this all the time for cleaner installations.
-Alex
Old Mar 26, 2015, 05:08 PM
Joined Dec 2012
-Alex
Fantastic! Thanks again.
Old Mar 29, 2015, 05:52 PM
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
Alex (or anyone else), is there any reason, RF wise, why I can't strip the outer plastic sheath and saturate the outer braid of my RG316 Clover cable to make it solid/semi rigid so that it doesn't flap about on my Bix3?
Tom.
Tommygunn is offline Find More Posts by Tommygunn
Old Mar 30, 2015, 01:46 AM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Tom.
Tom,
In theory the impedance of a coax is defined by the ratio of the inner diameter of the shield versus the outer diameter of the inner concuctor and the material used for insulation between the two, so - again in theory - your aproach would not change this. In fact semi rigid cable is exactly this, the braid is slightly tined to give it more stiffness. However, doing this all over the cable length by hand in a way such as you do not harm the insulation or change the diameter of the braid etc. seems very delicate/difficult.
Why not try a hassle free aproach and use some U-shaped tubing (i.e. use an outer insulation of a power cable or similar that you slit) that you put over the cable and then use some tape to close that U?
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 427 Mar 17, 2015 02:03 AM
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2175 Mar 05, 2015 09:46 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 350 Feb 27, 2015 02:12 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
