Old Jan 16, 2014, 04:38 AM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Build Log
Whim Series Fokker D7 by Park Scale Models
Here is my version of a Whim D7. It uses a Spektrum AR6410 BL with two external linear servos, 180 bl 2300kv motor, 5.75x2.25 prop and Turnigy 260mah 2s. AUW is just over 3oz with about a 1:1 thrust ratio. A fresh pack will have it slowly climb vertically, at the halfway point it will just hold a hover. Yep, scale flying at it's finest.
The kit went together easy enough. Hiccups I encountered; the wing rib notches were not long enough, I sanded the rib a little and it fit. The carbon wing struts and LG were about .25in short when cut according to the plan. I used the rods anyway, they are just not fully seated. After that it's up to you to supply all the finishing touches such as pilot, wheels, tail skid and any other features you want to add. I decided to build a fully enclosed fuse,it adds so much to the look of the plane. I added cross braces and covered the bottom. I used balsa sheeting to button up the front. My finishing scheme is a fantasy one based on some aspects of Fokkers that I like. I'm convinced the Germans did not want anyone modeling their fighter planes. Lozenge?? Are you kidding me?! I wanted something a little funky that was reasonably easy to produce.
parts layout
ribs too tall, sand em down
ribs too long, sand em down
parts layout by Blazingstar
forming the front hatch and cowl
not sure where I'm going with the colors yet
so much pain in such small wings. there was a lot of trimming to get the bottom wings to fit. the spar was to short or the fuse too wide. either way notches were enlarged which made me nervous, I didn't want to mess with the alignment of the wings. I ended up gluing the ribs flush with the bottom of the fuse lined up with the spar notch. seems to have been the correct choice. the spar broke so many times trying to test fit that I couldn't rely on it lining anything up.
getting a better idea of where to go with the colors
struts in place. I glued the wing incidence tabs to the wing and taped them to the fuse for assembly. when done I snapped them off. added the front LG strut for a more scale look. LG struts were too short as well. doubled up the rear carbon to extend the length
made balsa caps for the wheels. mpi 1.5in 5 spokes
front detail. you can see the servos just in front of the cockpit, front hatch holds made from scrap balsa and e clips. the lipo sits all the way forward.
fuse striping going on
test flights before final finishing. photos courtesy of Blazingstar
good shot of the bottom covered up
Final detailing
williams brothers vintage 1/12 scale pilot. guns courtesy of Blazingstar
engine detail made from scrap balsa in the kit
radiator sticker and crosses by Callie Graphics
painted the underside of the wings red with acrylic paint. worth the weight penalty, looks so much better in the air.
don't forget the scarf, a wise friend once said
IH8VTEC is offline Find More Posts by IH8VTEC
Old Jan 16, 2014, 10:03 AM
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Really Cute!
Pat Daily is offline Find More Posts by Pat Daily
Latest blog entry: Don Srull's BE-2
Old Jan 16, 2014, 04:16 PM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Originally Posted by Pat Daily View Post
Really Cute!
Thank you.
Old Jan 16, 2014, 04:59 PM
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
I believe the word Fokker roughly translates to "cute" in French.
BlazingStar is offline Find More Posts by BlazingStar
Old Jan 16, 2014, 08:48 PM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Lol. Don't you start. Where is yours?
Old Jan 17, 2014, 05:26 PM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
That's a good looking Fokker you did there.
CapMike is offline Find More Posts by CapMike
Old Jan 17, 2014, 05:57 PM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Thanks, It's a nice flyer too! It's so lite it can just float around nice and slow. It barely balanced with the big 260 2s all the way forward. Adding the stripes actually helped.
Old Jan 25, 2014, 10:04 PM
-=BS=-
Thousand Oaks, CA
Joined Jul 2009
Here's my Whim D7
Vtech and I built these at about the same time with the same gear.
Mine is covered with Esaki and uses a pull-pull system.
The best thing I can say about this kit is that it made me think and ponder during the build process and that it resulted in a flying airplane.
My pilot has earned his Iron Cross! (And a handsome appendage over his lip)
Old Jan 26, 2014, 01:57 AM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Fantastic!
Old Jan 26, 2014, 06:49 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Both D VII's look fantastic.
Old Jan 26, 2014, 11:05 PM
Beam me up Scotty!
Virginian's Avatar
United States, VA
Joined Nov 2012
They both look great!
Eric
Virginian is offline Find More Posts by Virginian
Old Jan 27, 2014, 04:28 AM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Thanks guys. BS is always coming up with new ways to detail a model. I get most ideas and some materials from him. You really have to click his pictures to see just how detail oriented he is.
Old Mar 04, 2014, 01:29 AM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Some pictures from an indoor fly. BS scored a kill!
Poll Park Scale Models "Whim" Indoor/Backyard Flyers zbrubaker Parkflyers 831 Jan 17, 2014 01:05 PM
Sold Park Scale Models Whim SE5a kit Laser Cut Huey N Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 05, 2014 08:07 PM
Found WTB: Mountain Models or Park Scale Models kits turbojoe Aircraft - Electric - Airplanes (FS/W) 3 Sep 23, 2013 07:01 PM
Sold Park Scale Models Whim Piper L-4 zbrubaker Aircraft - Electric - Airplanes (FS/W) 0 Dec 30, 2011 06:45 PM
Sold Zeke's Park Scale Whim series SE5.a with extras fly20 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 19, 2009 11:07 AM
