Old Jan 27, 2015, 12:08 PM
"Some do, some don't"
old_coastie's Avatar
United States, MI, Grand Rapids
Joined Jul 2013
Originally Posted by Andrew Radcliffe View Post
Rudder authority is so underrated when you first leave circle flying to 3d. It's a challenge to overcome the reality is that rudder control is only second to throttle control IMHO.
Couldn't agree more, well mostly anyway, but so important that as I went to elevon only planes I still mix in rudder control, because my left thumb is smarter than the brain sometimes...
Mark R.
old_coastie
old_coastie is online now Find More Posts by old_coastie
Old Jan 27, 2015, 01:04 PM
Oklahoma
Joined Sep 2010
Mark R.
old_coastie
I thought the exact same thing when I read his post. I started to post that thought. It leads to some panic for an instant when my flying wing (elevons only) doesn't respond to the left stick.
ombudsman is offline Find More Posts by ombudsman
Old Jan 28, 2015, 02:22 PM
Andrew Radcliffe
Andrew Radcliffe's Avatar
United States, FL, Clearwater
Joined Sep 2011
I don't use a mix on my wings I just pretend it has a rudder it makes it more interesting
Andrew Radcliffe is offline Find More Posts by Andrew Radcliffe
Old Jan 28, 2015, 06:45 PM
Joined Jul 2013
I see your and raise you a
LOL
Mark R.
old_coastie
Old Yesterday, 12:48 AM
Oakridge, Oregon
Joined Jul 2004
I am on my 4th Yak in 6 years and this is by far my go to model for LOS. It can take such a beating. I decided on my new build to lam the entire plane. Did not seem to add much weight and really stiffens up the control surfaces. Only concern is if it will sill be able to take a beating and not crack...
TheDonski is offline Find More Posts by TheDonski
Old Yesterday, 08:32 PM
Joined Nov 2014
Built my first two Yaks! These things are great. My first 3d planes. They fly slow and lazy but will zip as well.
Build #1 (Orange/Yellow/Blue)
18.5" wingspan. 3mm EPP foam. 8.5mm brushed motor running off 1s 250mah batteries. AUW w/batt is 44g. This will barely hover at full throttle. the foam I used for it was a heavier sheet, that I believe was probably 1.9lb. I have since built another frame from lighter foam that weighs half as much. Original frame weight (pictured) is 15g. New frame (not pictured) is 7.5g. Hoping the new frame will pull vertical.
Second build is a "Skinny Yak" from 1.3lb EPP. (Blue/Green. Woo Seahawks. )
1 hxt900 servo
FRSKY 4 channel receiver
Turnigy 2204-14 motor (WOW this thing is so smooth and quiet!)
2s 450mah batteries (32g)
AUW of 165g (133g without battery)
The motor/weight combo seems just fine. Running a 9047 prop, it will pull vertical at just over half throttle (with a 2s battery at 7.4v) It was too dark to fly more with fully charged batteries. Will report back. So far very pleased!
Ben
Bequmi is offline Find More Posts by Bequmi
Old Yesterday, 09:26 PM
Oklahoma
Joined Sep 2010
Very nice lookinv planes, Ben!
You can paint my foamies any time!
Good work.
Dave
Looking
Old Today, 01:08 AM
Joined Nov 2014
Good work.
Dave
Looking
Thanks much! Just getting into it. Having a good time learning to airbrush.
