Old Jul 19, 2014, 10:13 PM
United States, MD, Hagerstown
Joined Jan 2014
Broke my Turnigy 9X antenna
Anyone know where I can get a replacement part for this? I've tried searching online but all I come up with is antenna mods; just trying to replace what I've got for now as I'm too new to realize I need to mod it
Thanks, all!
Tefl0n is online now Find More Posts by Tefl0n
Old Jul 19, 2014, 10:16 PM
RC Warjet
United States, CA, Jamul
Joined Mar 2013
If the antenna wire is soldered inside the module, you're probably better off getting another module with the antenna attached to it directly.
Warjet1950 is online now Find More Posts by Warjet1950
Old Jul 20, 2014, 01:14 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Where did you get that 9x ?
The 9x normally does not come with 2..4Ghz antenna fitted to the top position. That is usually plugged with a plain button after Turnigy remove the old telescopic FM antenna.
Some one has fitted the 2.4GHz stub antenna there ...
What module are you using in the radio ... the little I see in your photo appears not to be FlySky or FrSky .... because those have the antenna fitted to the module - NOT the Tx case.
To be honest - given the mod to your radio - I would be inclined to tape it back together as a fixed antenna ... that is as long as the internal wire is undamaged.
If the antenna is screw fitted with standard fitting ... then :
http://www.hobbyking.com/hobbyking/s...e_Antenna.html
available in varuous locations .. USA etc.
or this ...
http://www.hobbyking.com/hobbyking/s...nded_Wire.html
Nigel
solentlife is offline Find More Posts by solentlife
Old Jul 20, 2014, 01:32 AM
RC Warjet
Joined Mar 2013
Every 9X I've ordered from HK had the antenna mounted at the top with a wire running down and out of the module cavity into the module itself. The Flysky TH9X has the antenna mounted on the module directly.
Old Jul 20, 2014, 02:23 AM
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Sorry - yes ... I forgot - the Turnigy that had the module fitted had the modified antenna ... shows just how much sleep last few days .. lack of !!
It's the bare bones 9x that had the button ...
Then the antenna I linked to with extended lead should be a good replacement then ...
Nigel
Old Jul 20, 2014, 09:33 AM
Sokol
JureZ's Avatar
United States, CA, Walnut Creek
Joined Jul 2013
Thanks, all!
see the thread below, post 178
http://www.rcgroups.com/forums/showp...&postcount=178
I bought a new wi fi antenna and reverse SMA cable at Fry's.
A hole was drilled on the module for cable entry , then ,
cut and soldered the coax cable directly to the module,
As you may see in the picture, the cable was routed externally.
good luck, Jure Z.
JureZ is online now Find More Posts by JureZ
Discussion Turnigy 9X: How to remove antenna and fix it on the 2.4ghz module teddonald Radios 0 Nov 17, 2013 05:49 AM
Help! broke video TX antenna elbow remvideo FPV Talk 7 Oct 31, 2013 06:39 AM
Discussion Will the Turnigy 9X work with my new Heli? Baddmove Radios 8 Sep 24, 2013 10:26 AM
Help! Turnigy 9x menu button broke Bravedave007 Radios 0 Jun 09, 2012 10:09 PM
Discussion My antenna from dx5e broke off what aftermarket antenna to use? jaas75 Radios 3 Mar 05, 2012 06:42 PM
