Old Apr 14, 2016, 10:34 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
Build Log
1:20 RHS 70 Shearwater Hydrofoil scratch build
Finally starting my hydrofoil build. I have been wanting to do one for years but kept getting side tracked. I decided on the RHS 70 because of it's simple, non stepped hull, single shaft arrangement and surface piercing foils. I just pulled the master from the plaster molds and everything came out great.
Here are the specs for now:
1:20
43" long
9" hull beam
single outrunner
2" 3 blade prop
twin rudders
polyester hull
Sintra deck and cabin
CaptDH is offline Find More Posts by CaptDH
Old Apr 14, 2016, 10:59 PM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Cool .
Mark
the goon is offline Find More Posts by the goon
Old Apr 14, 2016, 11:00 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Looking forward to seeing how this is done. I have a 32nd parallel German WW II hydrofoil kit. It does not have the running hardware but it uses the same type of foil. I would like to one day have it running.
Gravman is online now Find More Posts by Gravman
Old Apr 15, 2016, 12:36 AM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Off to a great start Dennis.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Apr 15, 2016, 10:48 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Plaster mold? So simple, of course!
Any special kind of plaster? I guess I'd be worried about the surface strength... but patching and even new molds should be a cinch!
Ever try a split mold (L/R) in plaster?
patmat2350 is offline Find More Posts by patmat2350
Old Apr 15, 2016, 11:13 AM
CaptDH is offline
CaptDH's Avatar
Joined Oct 2002
Pat,
Ultracal 30...Sent you some info....
Making an Ultra Cal Canopy Mold for Kawasaki Ki 100 Part 1 Jan 22 20166 (21 min 22 sec)
Old Apr 17, 2016, 05:40 PM
CaptDH is offline
CaptDH's Avatar
Joined Oct 2002
Hull is layed up and curing in the California sun for a few days.
DH
Old Apr 18, 2016, 07:57 PM
Joined Apr 2007
Watched the video tutorial and it was very interesting. Are you using gel coat as a base for the cloth and resin? From the top the hull kinda has a pt boat shape. Looks great.
Old Apr 19, 2016, 09:14 AM
CaptDH is offline
CaptDH's Avatar
Joined Oct 2002
First hull is having some gel coat curing issues in the corners. May need to lay up another..
Old Apr 24, 2016, 09:58 PM
Subdave is online now
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
It's about dam time.
Color me watching!opc orn:
Subdave is online now Find More Posts by Subdave
Old Apr 25, 2016, 10:59 AM
Subdave's Avatar
Rochester NY
Joined Mar 2005
I actually found the 3D cad of the boat you sent me years ago.
Any thoughts on the foils?
The only thing on the Ultra Cal it's so darn heavy.
Steve does not call it stone for nothing. Dave
Actually I take back the CAD comment. It was a different hydrofoil. Ha!
Old Apr 25, 2016, 11:26 AM
CaptDH is offline
CaptDH's Avatar
Joined Oct 2002
Ultracal is heavy but very cost effective and fun to work with. As for the foils, A combination of sheet brass and urethane foils that key into the brass. We need some adjustment so I plan to make everything removable with hardware.
DH
Old Apr 25, 2016, 03:14 PM
Subdave's Avatar
Rochester NY
Joined Mar 2005
You know I am nuts about all things hydrofoil.
My second love after subs.
Yours looks similar to my PT50.
I like the twin rudders better though.
My ultimate build would be to do a water jet foil.
Check out this bad boy!
Tested by the Canadians in the late 60's.
It hit 63 knots.
Old Apr 25, 2016, 03:28 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
No, this!
Old Apr 25, 2016, 03:31 PM
CaptDH is offline
CaptDH's Avatar
Joined Oct 2002
Pat, You're halfway there.......Get on it!
Build Log First Scratch Build - 1:20 Art of Kinetik Hedonist - modern wood motor yacht B_Honeydew Scale Boats 12 Jun 06, 2016 07:02 PM
Discussion Scratch build 70"-84" Gee Bee R3 rubber wheel Giant Scale Airplanes 2 Nov 14, 2015 08:31 PM
Build Log Valmet L-70 Vinka Scratch build (1.45m / 57") tuootal Scale Kit/Scratch Built 41 Mar 24, 2015 01:25 PM
Build Log Laddie's Shearwater build marc2turbo Waterplanes 7 Apr 06, 2014 03:36 PM
Build Log 1/32 PHM hydrofoil build, here we go SilentHunter Scale Boats 205 Nov 01, 2009 08:24 PM
