Old Feb 27, 2016, 05:10 PM
goofyfoot2001 is offline
Find More Posts by goofyfoot2001
goofyfoot2001's Avatar
Joined Feb 2016
Motor weirdness cleanflight
This is my first build and after finaly getting this tbs powercube to arm, the motors initially seems to run at the same level according to cleanflight.
If I say, push the stick for forward, the motors dont return to where they were but remain going forward until I pull back and the stick. Is this normal?
Also, if I do some moving around of throttle roll etc, the motora seem to not go back to centering of rpm when you think you're back to center.
Hope this is coherent.
goofyfoot2001 is offline Find More Posts by goofyfoot2001
Old Feb 28, 2016, 03:20 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
confusing to understand what you are trying to say here
are you talking about when the aircraft is flying? Sounds like normal motor activity for acro mode. If you want self-level when you centre the sticks, you need to go to horizon mode.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Discussion Weird cleanflight behaviour cc3d Northstarrocks Multirotor Electronics 0 Dec 18, 2015 12:46 PM
Discussion Help with Tuning Cleanflight and Weird Crash Problem PaulHilgeman Multirotor Electronics 0 Oct 13, 2015 10:38 AM
Discussion Weird Motor Sync Issue With CW Motors redstars Multirotor Electronics 0 Sep 09, 2015 02:36 PM
Question Naze32/Cleanflight Odd Beep Code/Cut Motors zanthor Multirotor Electronics 9 Mar 30, 2015 10:35 PM
Help! Naze32/Cleanflight beeper acting weird while plugged into USB? xoxota Multirotor Electronics 0 Jan 11, 2015 08:25 PM
