Old Feb 15, 2016, 12:49 PM
JackJones is offline
Find More Posts by JackJones
Joined Feb 2016
Help!
DIY Flight Controller and u-Blox M8Q GPS problems
I am working on a custom flight controller, with integrated GPS module. It's u-blox MAX-M8Q module and external antenna is connected via U.FL antenna connector. Antena connection is designed as shown in u-blox datasheet for active antenna. 10 ohm resistor in series with 27nH inductor connected from VCC_RF power pin to RF_IN, and 47pF capacitor in parallel.
First, I noticed that in same occasions, when I use active Taoglas AP25 antenna, GPS module hangs on startup, like in some reset state. No communication in or out, TIMEP pin in weak pullup.
With some other active antennas (AP17, AGGP25) this does not happen. However, I also seem to get pretty weak signal, and it has difficulties to get a lock. CNO is usually in some 20-30 dB range, hardly ever goes over 30. It is a bit better when using large active patch antenna (black thingy on image ), I can get a lock on satellites, cno go over 40.
Should there be a DC blocking capacitor before RF_IN pin? I am using 3.3V for power supply.
I also have Lora 433Mhz module near ublox module, along with several switching power supplies. Could that be the cause of interference to module or gps antenna?
JackJones is offline Find More Posts by JackJones
Old Feb 16, 2016, 01:14 AM
KiwiDavid is offline
Find More Posts by KiwiDavid
Joined Jun 2011
Hi,
I don't think you need an input capacitor as this module senses remote antenna current (for opens or shorts) by using the drop across the 10R resistor.
It will go in to a protection mode if the current goes too high.
Keep the antenna away from other digital circuitry and also any transmitting antennas. Just remember that these devices are working with signals between about -135dBm and -165dBm. In comparison a microvolt (uV) is -120dBm. System noise will be your biggest problem.
Any dielectric patch antenna is designed for a certain ground plane size which affects the gain and the center frequency. The magnetic mount antenna (auto type) should be designed to go on the car body or rear parcel tray - i.e. large ground plane. In free air it may be somewhat off tune. With a good view of the sky and away from noise sources you should be seeing 40+dB CN ratios.
Good luck.
Cheers,
David
KiwiDavid is offline Find More Posts by KiwiDavid
Old Feb 16, 2016, 02:46 AM
bluegoose is offline
Find More Posts by bluegoose
Joined Dec 2013
It maybe worth having at look at their UBLOX reference designs, having worked on GPS/GSM trackers a while back. They do have some PCB layouts which may help on any issues that may be from noise / crosstalk
https://www2.u-blox.com/images/distr...1-cs-10020.pdf
bluegoose is offline Find More Posts by bluegoose
Old Feb 16, 2016, 02:37 PM
Joined Feb 2016
That makes sense. I'll try to shield antenna from electronics and see if it helps. Thanks.
Interesting, I'll have a look.
Help! CRIUS CN-06 V3.1 U-blox GPS (Time-out Errors) =Alkon= Multirotor Electronics 4 Jun 15, 2015 03:39 PM
For Sale V521 Personal GPS Tracker With U-blox-7 Mini GPS uuustore1 FPV Equipment (FS/W) 11 Dec 01, 2014 09:56 PM
Sold HK Pilot Mega V2.5 Controller U-BLOX & NEO 6M GPS empiguy63 Aircraft - Electric - Multirotor (FS/W) 1 Jan 16, 2014 01:30 PM
Sold CRIUS MultiWii SE/Crius I2C-GPS NAV Module/u-blox NEO-6M GPS/CRIUS CO-16 OLED HansAuf Aircraft - Electric - Multirotor (FS/W) 7 Jun 06, 2013 07:11 AM
