Old Jul 02, 2015, 11:25 AM
AnotherMember is offline
Find More Posts by AnotherMember
Joined Jun 2015
Learning how to really FLY a done in manual mode
So many drones have technology now that allows unskilled "pilots" (actually joystick pushers), to operate a drone sometimes with disaster just an electronic glitch away.
The vast majority of lost drones and crashes are probably by such wanna be pilots.
Real pilots who can proficiently FLY their drone not only outbound, but also inbound and at 90 degrees without the aid of a compass, GPS or other electronic automated guidance system are far less likely to lose their drones.
That said, I am a quad beginner. But I recognize the situation and have committed myself to learning to fly FIRST with absolutely no onboard navigation assistance. In other works, training my brain to control the quad fully manually.
Having flown RC for years (but not recently), I might have a very slight advantage over the newcomer. But I would not say it's a great advantage. I have found that learning yo control the quad is a new learning curve and although I probably got hovering and outbound control down faster, I still have a long way to go on the 90 degree and inbound control.
That said, my approach is just to go slow. I don't have an actual training plan that will help me learn the inbound and 90 angle moves. I just keep pushing the envelope a little more and more.
The Question:
So I was wondering if there was a technique to practice that to help quickly develop the flying inbound (head first) and flying at right angles?
Or is it just a matter of pushing the envelope until it clicks?
AnotherMember is offline Find More Posts by AnotherMember
Old Jul 02, 2015, 12:49 PM
fradioflyer is offline
Find More Posts by fradioflyer
United States, VA, Quinton
Joined Feb 2015
I picked up this hobby myself 8-9 months ago and I'm pretty sure I found a training regimen online... I think it was for RC helicopters, actually. I can't find the link now, but it was basically this-
Hover, truly keep it in it's place, nose-out.
Hover, in place, nose-in.
Hover and Pirouette (30+ seconds per turn) without loosing altitude.
Fly out and back, in a straight line, nose-out.
Fly out and back, in a straight line, nose-in.
Repeat for left and right, straight line.
Fly a box pattern, nose-out, clockwise.
Fly a box pattern, nose-out, counter-clockwise.
Repeat for nose-in.
Fly the box pattern, but yaw to the forward direction, stop and hover at each corner.
... then remove the stops and basically do circles, then figure-8s.
I started in the winter, with a toy, a Syma X5C, flying these patterns in the garage. I didn't move to the next one until I'd mastered the one before it. I crashed that little thing a LOT!
It took me 3 weeks or a little more to get through all those steps. Then I bought a CX-20 in February and went through the same motions outside.. getting used to the power difference of "this is definitely not a toy!".
fradioflyer is offline Find More Posts by fradioflyer
Old Jul 02, 2015, 12:59 PM
Karolien is offline
Find More Posts by Karolien
Joined Jun 2015
As far as I know, if there are no special RC aircrafts, every rc pilot are stick pushers since they use transmitters.
Real pilots sit in the aircraft and are educated and have pilot qualification. If we remove electronic automated guidance I don't think any aircraft could be flown.
No self leveling, no gyro? Good luck.
The Question:
Start from scratch, hovering in different positions, and then, what's worked for me: I started to fly in circles in different directions and in different engels while I played with the aileron and rudder.
Karolien is offline Find More Posts by Karolien
Old Jul 02, 2015, 01:06 PM
waltr is online now
Find More Posts by waltr
Team AlienWarpSquad
United States, PA, Doylestown
Joined Jan 2014
Self-leveling uses the Accelerometer not the Gyro. In Acro or Rate mode the Gyro is ALWAYS in use. This is just to stabilize motors from the RC TX control inputs NOT to fly for you.
I for one of many here fly only Rate mode on LOS Aerobatic and FPV copters. It is just lots and lots and lots of practice and tends to require lots of broken props and sometimes broken frames etc.
Rate mode gives the pilot the most connected flying as the copter does only exactly what the pilot commands. If the pilot makes a mistake then the copter crashes.
waltr is online now Find More Posts by waltr
Old Jul 02, 2015, 01:32 PM
Karolien is offline
Joined Jun 2015
Thanks for the correction. Stabilize the motors, stabilisation is great many times.
Old Jul 02, 2015, 02:31 PM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
The Question:
1 week practice (6 min 47 sec)
This is how i practice. It's getting late, but if you want i can list down the exercises. Tho they're essentially the same ones you do when practicing on a helicopter.
Hajile is offline Find More Posts by Hajile
Old Jul 02, 2015, 02:51 PM
jbrumberg is online now
Find More Posts by jbrumberg
Childlike Activity for Adults
jbrumberg's Avatar
United States, MA, Cummington
Joined Dec 2012
http://www.rcgroups.com/forums/showthread.php?t=2448591
This was a recent thread that has some decent information about learning basic piloting and orientation skills.
Learning to pilot a multi-rotor well takes a lot of practice and then more practice.
Good Luck=
JB
jbrumberg is online now Find More Posts by jbrumberg
Old Jul 02, 2015, 02:59 PM
Joined Jun 2015
Are you a "real" pilot?
The context was actually limited to RC quads in this forum.
Old Jul 02, 2015, 08:14 PM
AnthonysQuad is offline
Find More Posts by AnthonysQuad
Happy Holidays
AnthonysQuad's Avatar
Joined Jan 2013
Well if u lose orientation slowly throttle up and if it goes left turn left and if it goes right turn rightthis will make it fly back towards u.
AnthonysQuad is offline Find More Posts by AnthonysQuad
Old Jul 02, 2015, 08:31 PM
67walkon is offline
Find More Posts by 67walkon
Joined Nov 2014
Fly a little one like one of the Hubsans. Crash it a lot. Fly it nose out, nose in and sideways. Suddenly, it just clicks.
I went through 3 little ones. Broke one pretty bad and kept it for parts. Lost one outside in a tall tree. Still have the 3d one after more than a year. I haven't crashed it in a long, long time and it's still fun to fly.
I've had a Blade 350QX3 AP for about 7 months. It's a piece of cake to fly and I feel safe with gps disabled. But it's kind of boring, so I'm looking at something like the new Walkera 250 Racing Drone.
It no longer matters to me which way the quad is facing. I think your brain just figured it out at some point.
67walkon is offline Find More Posts by 67walkon
Old Jul 02, 2015, 10:15 PM
Oldgazer is offline
Find More Posts by Oldgazer
FA3PR9WM79
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
The Question:
I was ahead of the game because I've been flying helis since 1990.
Try here: http://www.helifreak.com/forumdisplay.php?f=242
Oldgazer is offline Find More Posts by Oldgazer
Old Jul 03, 2015, 08:45 AM
Joined Jun 2015
This is what I was thinking too.
Waiting for the light bulb.
Old Jul 03, 2015, 10:30 AM
tm22721 is online now
Find More Posts by tm22721
United States, VA, Stanley
Joined Dec 2014
The problem with manual flying (non-FPV) is NOT LOSING TRACK OF the drone's orientation. This is most difficult at > 100 feet unless you have 20/20 vision which many of us DO NOT. So for me, autonomous/auto mode is THE ONLY WAY TO FLY. Pixhawk is a savior.
tm22721 is online now Find More Posts by tm22721
Old Jul 03, 2015, 10:58 AM
waltr is online now
Team AlienWarpSquad
Joined Jan 2014
LOS and orientation just requires lots and lots and lots of practice. This means hundreds of hours flying and years of practice. After this you will know the orientation from what stick movement you input without really being able to see the copter well and even with no orientation markings like colored props..
Old Jul 03, 2015, 11:43 AM
jbrumberg's Avatar
Joined Dec 2012
^^^^^ I agree.
Discussion Manual/Rate Mode - how HugoBlast Multirotor Beginner 20 Jul 20, 2015 04:30 AM
Discussion 200qx learn how 2 Fly Gimbal Guy Mini Multirotors 0 Jun 24, 2015 10:10 AM
Discussion Naza V2 - Learning to Fly in Manual Mode - Best Beginner Settings? Arshish Maneckji Multirotor Talk 1 Dec 26, 2014 04:59 PM
Help! URGENT!! How to put Manual mode in Wookong M, I think it's broken... yomismamente Multirotor Talk 6 Mar 25, 2014 05:09 AM
News How Santa Really Getís it Done in 2013 Sleepyc Multirotor Talk 11 Dec 19, 2013 08:58 PM
