Old Jul 08, 2015, 02:35 PM
victoras_h is offline
Find More Posts by victoras_h
United States, TX, Irving
Joined Jun 2010
Has anyone tried to use a Saito FG11 on the Meridian? Would it fit?
victoras_h is offline Find More Posts by victoras_h
Old Jul 08, 2015, 09:49 PM
PontiusPilate is online now
Find More Posts by PontiusPilate
amo ludibria ventis
PontiusPilate's Avatar
United States, VA, Chantilly
Joined Oct 2010
I talked to the designer of the plane and the 10cc and FG11 engines (same guy), he said the Meridian is great with this engine. However, it might be smaller than the 10cc. I think the more appropriate engine for 4-stroke would be the FG 14. That's what this guy is using.
Hangar9 Meridian 10cc ARF SAITO FG-14 First flight (4 min 14 sec)
PontiusPilate is online now Find More Posts by PontiusPilate
Old Jul 09, 2015, 06:38 AM
larryoakley is offline
Find More Posts by larryoakley
Joined Mar 2012
I always was afraid of those canopy magnets, reason why I installed screws on the sides to avoid a canopy loose in mid air like the guy in the video
larryoakley is offline Find More Posts by larryoakley
Old Jul 09, 2015, 08:04 AM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
This guy went with a FG-17 and several good build ideas.
Hanger 9 Meridian with Saito FG 17 gas (2 min 40 sec)
jwellsy is offline Find More Posts by jwellsy
Old Jul 09, 2015, 08:16 AM
amo ludibria ventis
Joined Oct 2010
The fg 17 is discontinued no?
Old Jul 09, 2015, 01:17 PM
Joined Mar 2012
I have a Saito 100 in my Meridian and had to install a 13x10 prop only because of the prop clearance, also all my takeoff and landings have to be with some flaps to avoid the prop hitting the ground, can't imagine a nose wheel brake with that FG-17
Old Jul 10, 2015, 02:34 PM
airoscar is offline
Find More Posts by airoscar
Canada
Joined Aug 2014
https://www.youtube.com/watch?v=yWvPcAmxlwc
Hi, newbie to fuel powered airplanes here.
I been contemplating building a Meridian with gas engine, but have sen lots complaint about the EVO 10cc engine carb.
Do these small 4 stroke engines have the same sort of issue or are they pretty friendly to tune and reliable to run?
Also, would much modification required to the airframe to fit a Saito 14?
Thx. Oscar
airoscar is offline Find More Posts by airoscar
Old Jul 10, 2015, 02:47 PM
teckbot is offline
Find More Posts by teckbot
Build to fly, fly to fix
Canada, QC, Pointe-Claire
Joined Jun 2011
Thx. Oscar
Oscar, you will only hear from complaining people. The 10cc works just fine, and with the Meridian, it is a great combo.
teckbot is offline Find More Posts by teckbot
Old Jul 10, 2015, 02:56 PM
airoscar is offline
Canada
Joined Aug 2014
That's true consider the number of these engines that are out there in service.
In regards to the nose gear, could someone link me to the "beefy" landing gears/upgrades?
Thanks. Oscar
Old Jul 10, 2015, 03:57 PM
teckbot is offline
Joined Jun 2011
Thanks. Oscar
If you can land an airplane reasonably well, you will land the Meridian like a pro. It is very forgiving, and the flaps work effectively. I think we ditched the nose wheel wheel pants and maybe put one size larger wheel, because of our grass field.
In any case, this is not a plane that requires overthinking or modifications. We had engine out (early times) situation about 40 feet up and half way down the runway, and still have time to glide to go around and perfect landing.
It's not the sexiest, fastest, most aerobatic plane out there. But it is a great fun flyer and a great transition plane on the way to bigger planes.
Old Jul 10, 2015, 04:56 PM
seldredge is online now
Find More Posts by seldredge
United States, CA, La Honda
Joined May 2014
Thanks. Oscar[/QUOTE]
Fults has a strong landing gear that would work on the front. After my first few flights and a few bad landings I ordered one. The landing gear itself did not bend, but with a side-loaded touch down or hit on the nose, the metal linkage rod would bend slightly, causing the wheel to go out of alignment. This would require an equally bad landing in the other direction to recenter.
I learned to land the plane well enough quickly enough that I didn't install the Fults. During the build, however, I did reinforce the landing box area of the main gear with some epoxy and some carbon pieces. And I use Dubro 3-inch low bounce tires on the mains, but not the nose. I bent the main landing gear a few times learning, but did nothing to the plane. Plane will essentially land itself if you let it. Leave a little power on. A little wind helps too.
I did my Meridian with an E-Flite Power 60 motor and a 5300 mAh battery. Will go vertical out of sight, which I try not to do. I can fly 10-15 minutes, depending on prop, which is longer than I can focus usually.
Note: On page 22 of this thread, a larryoakley post, you'll see a nose strut with suspension on (in answer to my question like yours).
seldredge is online now Find More Posts by seldredge
Old Jul 10, 2015, 05:34 PM
airoscar is offline
Canada
Joined Aug 2014
Thanks. Oscar
Note: On page 22 of this thread, a larryoakley post, you'll see a nose strut with suspension on (in answer to my question like yours).[/QUOTE]
Could you tell me which model and size of Fults landing gear you ordered?
I don't have a plane so I can't really measure and tell.
Old Jul 10, 2015, 06:07 PM
Joined May 2014
I ordered Fults Dual Strut Nose Gear, Model RF36J. Adjustable length, heavy duty. I think I looked at the model just below it because it looked like it would work, but after measuring on my plane, I found it wouldn't. Too short on one one dimension.
Would be fairly easy to install as part of the build process because motor box/mounts wouldn't be in the way.
Old Jul 10, 2015, 07:24 PM
airoscar is offline
Canada
Joined Aug 2014
Thanks! : ) i'll add this to my list of things to order.
Old Yesterday, 07:46 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Yes, but the FG-21 that replaced it uses the FG-17 crankcase. Total weight including muffler & ignition system is 31.2 oz vs. 27.2 oz for the FG-17. That's a 26% increase in displacement for only a 15% increase in weight.
Joel
turboparker is offline Find More Posts by turboparker
Discussion Hangar 9 P51 Sport 40 ARF SimAndy Fuel Warbirds 46 Sep 25, 2013 09:25 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 11, 2012 10:33 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 17, 2012 12:02 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 10:07 PM
Sold Hangar-9 Twist 60 with JBA-15 Gas Engine - $200 waynemia Aircraft - Fuel - Airplanes (FS/W) 4 Apr 29, 2012 05:05 PM
