Old Jul 30, 2015, 10:48 AM
3dFlyingMaster is offline
Find More Posts by 3dFlyingMaster
Joined Dec 2014
What did the magician say to the fisherman?
"Take a cod, any cod."
3dFlyingMaster is offline Find More Posts by 3dFlyingMaster
Old Jul 30, 2015, 02:23 PM
dll932 is offline
Find More Posts by dll932
Who, ME?
dll932's Avatar
Euclid Ohio
Joined May 2005
Unless you want to get scrod.
dll932 is offline Find More Posts by dll932
Old Jul 30, 2015, 02:35 PM
Chophop is offline
Find More Posts by Chophop
Don't axe me that again !
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
What's worse than shrimp on your piano ?
Crabs on your organ.
Chophop is offline Find More Posts by Chophop
Old Jul 30, 2015, 03:31 PM
Up&Away is online now
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Originally Posted by dll932 View Post
Some women can do that with pingpong balls.
And bananas...
Up&Away is online now Find More Posts by Up&Away
Old Jul 30, 2015, 07:40 PM
GWFAMI is offline
Find More Posts by GWFAMI
GWFAMI's Avatar
Kansas
Joined Jul 2005
I'm Back
Finally drove the wolves from the door and ready to start a new life studying for a PhD. Hope to get back into Rc and full size aircraft soon. In the meantime, here's a little something to contemplate.
High Flight, with FAA Supplement
Oh, I have slipped the surly bonds of earth(1),
And danced(2) the skies on laughter silvered wings;
Sunward I've climbed(3) and joined the tumbling mirth(4)
Of sun-split clouds(5) and done a hundred things(6)
You have not dreamed of Wheeled and soared and swung(7)
High in the sunlit silence(8). Hov'ring there(9)
I've chased the shouting wind(10) along and flung(11)
My eager craft through footless halls of air.
Up, up the long delirious(12), burning blue
I've topped the wind-swept heights(13) with easy grace,
Where never lark, or even eagle(14) flew;
And, while with silent, lifting mind I've trod
The high untrespassed sanctity of space(15),
Put out my hand(16), and touched the face of God.
NOTE:
1. Pilots must insure that all surly bonds have been slipped entirely before aircraft taxi or flight is attempted.
2. During periods of severe sky dancing, crew and passengers must keep seatbelts fastened. Crew should wear shoulderbelts as provided.
3. Sunward climbs must not exceed the maximum permitted aircraft ceiling.
4. Passenger aircraft are prohibited from joining the tumbling mirth.
5. Pilots flying through sun-split clouds under VFR conditions must comply with all applicable minimum clearances.
6. Do not perform these hundred things in front of Federal Aviation Administration inspectors.
7. Wheeling, soaring, and swinging will not be attempted except in aircraft rated for such activities and within utility class weight limits.
8. Be advised that sunlit silence will occur only when a major engine malfunction has occurred.
9. "Hov'ring there" will constitute a highly reliable signal that a flight emergency is imminent.
10. Forecasts of shouting winds are available from the local FSS. Encounters with unexpected shouting winds should be reported by pilots.
11. Pilots flinging eager craft through footless halls of air are reminded that they alone are responsible for maintaining separation from other eager craft.
12. Should any crewmember or passenger experience delirium while in the burning blue, submit an irregularity report upon flight termination.
13. Windswept heights will be topped by a minimum of 1,000 feet to maintain VFR minimum separations.
14. Aircraft engine ingestion of, or impact with, larks or eagles should be reported to the FAA and the appropriate aircraft maintenance facility.
15. Aircraft operating in the high untresspassed sanctity of space must remain in IFR flight regardless of meteorological conditions and visibility.
16. Pilots and passengers are reminded that opening doors or windows in order to touch the face of God may result in loss of cabin pressure
GWFAMI is offline Find More Posts by GWFAMI
Old Jul 31, 2015, 02:27 AM
teamlotus is offline
Find More Posts by teamlotus
Joined Nov 2007
Originally Posted by Up&Away View Post
And bananas...
And beer bottles...
teamlotus is offline Find More Posts by teamlotus
Old Jul 31, 2015, 02:17 PM
dll932 is offline
Who, ME?
dll932's Avatar
Euclid Ohio
Joined May 2005
Originally Posted by gwfami View Post
finally drove the wolves from the door and ready to start a new life studying for a phd. Hope to get back into rc and full size aircraft soon. In the meantime, here's a little something to contemplate.
High flight, with faa supplement
oh, i have slipped the surly bonds of earth(1),
and danced(2) the skies on laughter silvered wings;
sunward i've climbed(3) and joined the tumbling mirth(4)
of sun-split clouds(5) and done a hundred things(6)
you have not dreamed of wheeled and soared and swung(7)
high in the sunlit silence(8). Hov'ring there(9)
i've chased the shouting wind(10) along and flung(11)
my eager craft through footless halls of air.
i've topped the wind-swept heights(13) with easy grace,
where never lark, or even eagle(14) flew;
and, while with silent, lifting mind i've trod
the high untrespassed sanctity of space(15),
put out my hand(16), and touched the face of god.
Note:
5. Pilots flying through sun-split clouds under vfr conditions must comply with all applicable minimum clearances.
6. Do not perform these hundred things in front of federal aviation administration inspectors.
9. "hov'ring there" will constitute a highly reliable signal that a flight emergency is imminent.
10. Forecasts of shouting winds are available from the local fss. Encounters with unexpected shouting winds should be reported by pilots.
13. Windswept heights will be topped by a minimum of 1,000 feet to maintain vfr minimum separations.
14. Aircraft engine ingestion of, or impact with, larks or eagles should be reported to the faa and the appropriate aircraft maintenance facility.
15. Aircraft operating in the high untresspassed sanctity of space must remain in ifr flight regardless of meteorological conditions and visibility.
16. Pilots and passengers are reminded that opening doors or windows in order to touch the face of god may result in loss of cabin pressure
xlnt!
Old Jul 31, 2015, 03:58 PM
HaventFlownSince2014 is online now
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by teamlotus View Post
And beer bottles...
In Singapore, I once saw a woman that did this performance with baseballs
HaventFlownSince2014 is online now Find More Posts by HaventFlownSince2014
Latest blog entry: Giant 66% Cub
Joke Post your own jokes. Dtrimas Humor 21 Oct 05, 2011 08:29 PM
Post your maiden Voyage "JetiPro" Lv2Fly Foamies (Kits) 1 Jul 08, 2008 01:00 PM
The Blue Frog - Post your pictures & Feedback here! Hippo Foamies (Kits) 496 Feb 05, 2004 11:40 PM
Post your ideas for The E Zone here jbourke Site Chat 68 May 17, 2002 09:54 AM
Post your heli specs Dustin_v16 Electric Heli Talk 16 Feb 22, 2002 10:38 PM
