Old Jan 02, 2015, 12:33 PM
Windy Heap's Avatar
Joined Apr 2014
I think I've seen 2 boats for $99 at banggood. apply coupons for cheaper.
I got a green and an orange to bash around and chase with the wife.
Windy Heap is online now Find More Posts by Windy Heap
Old Jan 11, 2015, 03:23 PM
cbear's Avatar
jacksonville florida
Joined Feb 2005
is there anywhere to buy these in the usa,??
cbear is online now Find More Posts by cbear
Old Jan 12, 2015, 08:14 AM
Louisville, KY
Joined Jun 2006
Looks like Banggood's US Warehouse has them.
https://us.banggood.com/Wholesale-Wa...sa-906673.html
Sympster is offline Find More Posts by Sympster
Old Jan 14, 2015, 12:03 PM
Flyin' Ryan
theimacman's Avatar
United States, IL, Champaign
Joined May 2012
Here is my review:
Feilun - FT009 High Speed RC Boat - Review and Maiden Run (17 min 34 sec)
theimacman is online now Find More Posts by theimacman
Old Jan 15, 2015, 09:41 AM
Ondahelipad's Avatar
United States, FL, Summerfield
Joined May 2014
Repaint/split hull from deck plate
Does anyone have a technique on how to split the top -deck piece from the hull.
I tried removing the 4 screws holding the deck plate to the hull but both halves are still firmly together.
Ondahelipad is offline Find More Posts by Ondahelipad
Old Jan 21, 2015, 04:34 PM
Australia, NSW, Tabulam
Joined Nov 2014
Can you dropin a 3s lipo in stock trim?
James Lee is offline Find More Posts by James Lee
Old Jan 22, 2015, 10:29 AM
Joined Jan 2014
Can't it's glued.
nirklir is offline Find More Posts by nirklir
Old Jan 22, 2015, 10:30 AM
Joined Jan 2014
Nope.
2s only, you can upgrade the propeller for more speed.
Old Jan 22, 2015, 09:39 PM
Joined May 2014
Originally Posted by nirklir View Post
Can't it's glued.
Thanks. I wasn't sure. Looks like I'll just use more masking tape for the Airbrush deck repaint.
Old Jan 22, 2015, 09:42 PM
Joined May 2014
Nope.
Try to find a threaded prop for that shaft .
I had to make a custom shaft that extended a few mm to get a dog lug on the shaft and then a non threaded prop of larger size. It works great.
Old Jan 24, 2015, 01:27 AM
Joined Nov 2014
My mate bought 2,we are in Australia and his is called a Atomic Lighning bolt,his boats go great and are quite fast.I found a FT009 on ebay and it looked exactly the same for half the price so I bought one but his are way faster.Im hoping it is just the prop as everything else looks the same.I doubt mine would have a higher turn motor.Atleast I hope not.Has anyone tried a rebuildable 27 turn stock motor or similar?I have many from my past car racing,hoping the ESC can handel it,might try that next.
Old Yesterday, 10:11 AM
Australia, VIC, Melbourne
Joined May 2014
This Worked.......RE-Sealing hull
I just did it ....... now....the top is a U shape .facing down over a backward L shape on the bottom facing out...
pullup on the narrow sides near the back till u see a space(IF YOU cannot...STOP Now...You Boat is not leaking Yet) than carefully pry open with a thin tool first the while keeping split with a thin long rod right across pulling it along as you go ...danger the front on mine would not separate due to the glued rods x3 in the fount .......have a look first...so just leave it and go as far as you can on the rest ...gap fill from out side if ness later
This Worked........(just run a bead of no more gaps .along the U and rejoin to reseal the boat) is water clean up ...white and reopen-able....I hope ha ha.. have fun
Shaky Shot is offline Find More Posts by Shaky Shot
Old Yesterday, 10:27 AM
Joined May 2014
This Worked.......Re-Sealing-the Stuffing box(Brass Tube)
my green boat is now water tight,,,,,after scraping off with a knife, the lid to fit the seal and bending up a bit, the closing hooks (careful not to melt seal) with heat and pressure
splitting the cases (top/bottom) and resealing with no more gap sealer ...worked great .....see above
and also replacing the prop shaft /stuffing box (brass tube) for a better fitting one with water cooler added (was needed for higher rev's on green s3 mod only)
and getting ride of NEARLY all the prop shaft slack (fowrd/ backward movement) had to add a washer to motor end and spacer as required at prop ends.....of stock
to help keep grease in
now using a bit of plastic tube with the edge slightly angled (to help get on) with a tight fit on prop shaft/stuffing box tube , and a syringe to force grease up the prop shaft from the prop end after removing it
most of the noise is gone and no more leak into the boats though there
good luck have fun
Old Today, 08:08 AM
Joined Jan 2015
are there any aftermarket receiver that is compatible with the stock transmitter?
Erikjann2015 is offline Find More Posts by Erikjann2015
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 9 Dec 14, 2013 10:48 PM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 09:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 10:02 AM
