Old Mar 19, 2015, 07:13 AM
United States, NY, Nyack
Joined Jan 2015
Originally Posted by Isoprop View Post
Have you tried your setup on the workbench?
There could be a problem with your wiring/cable. First try the cable without attaching anything to the video-out, but connected to external power. Start a recording and then when the LED is blinking, indicating the camera is recording, attach your monitor/vtx,
Yeah... I would also measure the output of the BEC. It may be just over the self protection threshold.
Voytech is offline Find More Posts by Voytech
Old Mar 19, 2015, 07:33 AM
Joined Jan 2015
So a quick update on something I discovered late last night as I was hooking up the cheap HK GPS OSD to my phantom. I use the Mobius for FPV and I could swear I saw somewhere that it is not possible to use it with video out when in photo mode. (Edit... I was wrong: http://www.rcgroups.com/forums/showp...ostcount=11843 )
However my discovery was that in photo mode the latency of the video out is reduced significantly. I will have to test that further though.
Old Mar 19, 2015, 01:27 PM
BigTradioman's Avatar
United Kingdom, Harpenden
Joined Oct 2009
Originally Posted by mandis View Post
help please. i'm having a problem with my mobius camera. i can have a live feed to my vtx using the internal battery. but once i attach a external power source(bec, usb, etc) the video turns off and it goes to charging mode. what could be the problem?
TIA
Mandis
Hi Guys, this is weird but I am having the same issue. I have a mobius standard lens working just fine with the external power supply coming from a MFD AP. A brand new Wide Angle Mobius arrived today and I loaded up the same parameters as the narrow lens Mobius and plugged it into the same leads on the plane and it will not power up??? Same lead, same AP, same profile, but will not power up.
EDIT
EDIT
I found the fault by a long process of elimination. It was a faulty wired USB video and power cable. Power was getting to the plug but not from the plug to the camera.
BigTradioman is offline Find More Posts by BigTradioman
Old Mar 20, 2015, 10:36 AM
Joined Jan 2006
mobius camera problem (1 min 36 sec)
here's a short video of my mobius camera having issue when connected to external power source
anyone know what the soultion is?
mandis is offline Find More Posts by mandis
Old Mar 25, 2015, 09:52 AM
stevea3342's Avatar
United States, CT, Bridgeport
Joined May 2012
It seems like we should be about due for a new improved Mobius right? It's been out for quite a while in terms of a normal electronics life cycle. Maybe 1080p 60fps or stabilization or 2/4k? Less latency? I don't think we can have all of these in small package but there are areas for improvement.
stevea3342 is offline Find More Posts by stevea3342
Old Mar 25, 2015, 08:34 PM
Design > Build > Fly
Qrome's Avatar
Arizona, USA
Joined Feb 2005
You should post this on the main Mobius thread -- I would love to see what Tom would have to say.
Qrome is offline Find More Posts by Qrome
Old Yesterday, 08:27 AM
Joined Jan 2015
Last I heard the focus was on 1080p60, although no confirmed info from the source.
Old Yesterday, 08:48 AM
Joined Mar 2015
Mobius cam on FPV Racer
Follow The Leader - FPV Racing Practice (1 min 37 sec)
ChrisBoerema is offline Find More Posts by ChrisBoerema
Old Yesterday, 09:07 AM
I am flying wild :-)
wildflyer1de's Avatar
Germany, BY, M
Joined Jan 2012
quad racing into sunset with the mobius:
Tank Trap Quad Racing 2015 (3 min 45 sec)
wildflyer1de is online now Find More Posts by wildflyer1de
Old Yesterday, 06:58 PM
United States, SC, Moncks Corner
Joined Dec 2013
A Möbius with remote shutter or video control.
Railrode1 is online now Find More Posts by Railrode1
Old Yesterday, 08:57 PM
Australia, TAS, Deal Island
Joined Feb 2014
Originally Posted by railrode1 View Post
a möbius with remote shutter or video control.
remote shutter +1
crankster is online now Find More Posts by crankster
Old Today, 01:51 PM
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
Hi Guys,
I am about to get my first mobius cam and was wondering if I should go for the Lens B or Lens C?
I'm more into panoramic stuff rather than racing, will be used to get some good shots rather than fast motion stuff
Any input here?
jkishan16 is online now Find More Posts by jkishan16
Old Today, 02:40 PM
Joined Jan 2015
When I bought the B, the C wasn't yet available. If I had to get it again, I'd choose the C I think. B is good, but even after very lengthy adjustment, the corners are still soft. C supposedly fixes that issue.
Discussion Question about using computer monitors for FPV Koo FPV Talk 3 Oct 29, 2014 09:43 AM
Discussion FPV'ing successfully using tricopter/tcopters - tell us how you did it? shauntot FPV Talk 7 Apr 24, 2013 02:55 PM
Discussion OT, for those still on the fence about GoPro cams for your FPV needs. bgnome Dock Talk 9 Sep 19, 2012 12:59 PM
Discussion FPV cam your daughter would approve: Barbie Cam Steph280 FPV Talk 14 Aug 12, 2010 10:09 PM
Discussion Building Clear Canopy's for your FPV cams... IamLegend FPV Talk 2 Nov 16, 2007 02:50 PM
