Old Apr 21, 2015, 04:09 PM
Im_not_Honeydew is offline
Find More Posts by Im_not_Honeydew
Barely off the runway.
Joined Apr 2015
Help!
Using a patch with a cloverleaf?
Hello,
Can I use a 900MHz patch antenna to receive video when I have a Left-Hand polarised 900MHz (cloverleaf) antenna transmitting video?
Thanks .
Im_not_Honeydew is offline Find More Posts by Im_not_Honeydew
Old Apr 21, 2015, 05:18 PM
bigbird327 is offline
Find More Posts by bigbird327
Joined Sep 2014
Yes; as long as the patch is also LHCP.
bigbird327 is offline Find More Posts by bigbird327
Old Apr 21, 2015, 07:00 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Not entirely true, if you use a linear patch antenna it has no polarization, it's linear.
There will be a 3db loss but other wise it will work fine.
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Apr 22, 2015, 03:09 AM
Joined Apr 2015
Can I get a circular polarised patch antenna?
Old Apr 22, 2015, 03:23 AM
EpicRC is offline
Find More Posts by EpicRC
How far does it go?
EpicRC's Avatar
Australia, WA, York
Joined May 2012
yes, but a helical is better
EpicRC is offline Find More Posts by EpicRC
Latest blog entry: 450 pics
Old Apr 22, 2015, 10:40 AM
Joined Apr 2015
Wait, so having circular TX and helical RX is better than having them both circular?
Old Apr 22, 2015, 10:55 AM
schumixmd is online now
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Helical is Curcular polarization.
Having circular polarization on both ends is better than only one end, but still you can combine linear polarization with circular.
3db loss theoretically is half the range.
schumixmd is online now Find More Posts by schumixmd
Old Apr 22, 2015, 11:02 AM
smoothvirus is online now
Find More Posts by smoothvirus
smoothvirus's Avatar
United States, VA, Franconia
Joined Sep 2010
Helical antennas are circularly polarized, just like your cloverleaf antenna is. The helical antennas typically have more gain than the patch antennas so you can get more range.
If you watch this video it will help clear up a lot of the antenna mystery:
FPV Antennas 101 - Polarization, Diversity & Gain Patterns (27 min 56 sec)
smoothvirus is online now Find More Posts by smoothvirus
Old Apr 22, 2015, 11:03 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No, 3dB loss is half the power. 6dB loss is half the range.
The problem with mixing CP and linear antennas is that you lose all the multi-path rejection
benefits you normally get by combining CP antennas.
Daemon is online now Find More Posts by Daemon
Old Apr 22, 2015, 11:32 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
Right Daemon, my mistake, thanks for correction.
Old Apr 22, 2015, 01:03 PM
Joined Apr 2015
Well, I've found a circular polarsied patch antenna, but it is 8dB compared to the 5dB of my current video RX cloverleaf. Is this increase worth the multipath rejection as Daemon said?
P.S. the video cleared some stuff up, thanks!
Old Apr 22, 2015, 11:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Cloverleaf should be 1.25dbic, not 5dbic.
In general, I find that if you mount a linear patch about 4" off the ground and use the stock antenna (not a cloverleaf) video works pretty well. However, using a cloverleaf on transmitter and receiver works even better in most cases.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 23, 2015, 02:01 PM
Joined Apr 2015
Is using a cloverleaf for video TX and helical for RX better than cloverleaf for both? Or, as you said in a previous post, a skew wheel for TX would work better than a cloverleaf when you're using a helical for RX?
Old Apr 23, 2015, 10:12 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
With a helical, any CP TX antenna will do. Skew wheel, cloverleaf, it really doesn't matter mch. just don't mix and match linear and circular. While it works, it is just not very efficient.
-Alex
Old Apr 24, 2015, 12:16 PM
Joined Apr 2015
Alright, I'll stick with my 900MHz cloverleaf for TX and attempt to make a 900MHz helical. Thanks guys!
Discussion Patch 14dbi + Cloverleaf on tx is ok? cabecinhas FPV Talk 7 Dec 16, 2012 07:48 PM
Wanted Patch antenna - 1280Mhz and/or cloverleaf/vee antenna - 1280Mhz sn0wL FPV Equipment (FS/W) 0 Jul 30, 2012 01:44 AM
For Sale 900MHz IBCrazy Cloverleaf Pair + Vee/Patch, 200mW Tx chatch15117 FPV Equipment (FS/W) 3 Jan 04, 2012 10:41 PM
Discussion Patch & Vee vs Helix & Cloverleaf octane81 FPV Talk 5 Aug 06, 2011 03:56 AM
Discussion Cloverleaf antenna with a patch antenna AmiFish FPV Talk 8 Jul 17, 2011 10:28 PM
