Old Jul 07, 2013, 08:59 AM
stawel is offline
Find More Posts by stawel
Joined Jan 2013
IMAX B6 charger (original and clone) - open source firmware
Hi guys,
If someone is interested in an open software firmware
for the IMAX B6 charger:
https://github.com/stawel/cheali-charger
But still:
It's an early version, not everything is implemented yet,
so if your charger works perfectly fine, don't use it.
But if you have calibration issues, you can try it out.
Let me know what you think
and as always: Have fun!
Paweł
stawel is offline Find More Posts by stawel
Old Jul 07, 2013, 11:28 PM
Treeline is offline
Find More Posts by Treeline
Joined Oct 2010
I've got a Hobbyking Quattro 4x6 that is off it's trigger points when charging different types of batteries.
It does have the capability of changing set points for each of the four positions, but it's still not right because then you can only charge the one kind of battery on that position.
The firmware is similar to the IMAX B6 other than the Quattro is a four port charger, so is there a similar firmware update available for the Quattro line of charger? It looks like everyone and their brother makes a similar charger, including Hitec itself, so I'd think there would be a solution out there somewhere.
http://www.hobbyking.com/hobbyking/s...dProduct=10327
Treeline is offline Find More Posts by Treeline
Old Jul 08, 2013, 08:48 AM
stawel is offline
Joined Jan 2013
I've watched: https://www.youtube.com/watch?v=ZVHvun0fmFI
It seems to me that it's compatible witch the BC6
(the software is based on the BC6 schematics).
So, cheali-charge should work on it,
even if not we can try to add the support.
If you want to do that please create a separate forum thread
where we can discuss the details,
you'll have to do some measurements, to be sure,
you have only four trials
I'm little worried about the fans
(on the imax B6 there are no fans).
Old Oct 19, 2013, 03:08 PM
njozsef is offline
Find More Posts by njozsef
Joined Oct 2009
Yes, there is a lot of imax fans.
Just keep secrets.
njozsef is offline Find More Posts by njozsef
Old Oct 20, 2013, 11:13 AM
njozsef is offline
Joined Oct 2009
working on Turnigy MAx200W and Mega400x2
working on Turnigy MAx200W (same as GTPOWER a6-10) and
Mega400x2 working (coming soon)
Turnigy Accucell6 working (coming soon)
Old Oct 20, 2013, 10:39 PM
htuong95 is offline
Find More Posts by htuong95
htuong95's Avatar
United States, CA, Sacramento
Joined Sep 2003
Waiting patiently on the Accucell 6 firmware.
htuong95 is offline Find More Posts by htuong95
Old Oct 21, 2013, 01:09 AM
njozsef is offline
Joined Oct 2009
Please visit the https://github.com/stawel/cheali-charger
I have old 5A version accucell6 (tested, work)
The new 6A version I do not know.
The new version I not found ISP pads. This is a small problem.
old version.
new version: where is ISP pads???
ISP
Old Oct 21, 2013, 02:08 AM
feket663 is online now
Find More Posts by feket663
Hungary, Szabolcs-Szatmar-Bereg, Csenger
Joined Aug 2010
Thanks for sharing this wonderful project! I always wanted internal resistance meter my cheap Imax B6, and now realized.
feket663 is online now Find More Posts by feket663
Old Oct 21, 2013, 02:40 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
VERY interested ... I'm no good at programming or that stuff - so will be a happy receiver of firmware.
The biggest interest to me as my two B6 clones work fine - is the IR addition to the chargers ... something that I have been looking into more and more recently. If it works and saves me buying another machine - marvellous !
Question : I was led to believe that the Accucel 6 was basically same as the clone B6 ... but I see here that they are treated separately in the firmware stakes ... ?
Nigel
solentlife is online now Find More Posts by solentlife
Old Oct 21, 2013, 03:11 AM
njozsef is offline
Joined Oct 2009
Nigel
Pawel is mainly due to the default calibration data. Therefore, different firmwares.
Old Oct 21, 2013, 08:42 AM
d3nys is offline
Find More Posts by d3nys
Joined Jun 2007
This is great. I'll try to flash my older version of Accucell-6. Which version should I choose? The B6-clone or B6-original? Thanks.
d3nys is offline Find More Posts by d3nys
Old Oct 21, 2013, 09:21 AM
RC Aerobat is offline
Find More Posts by RC Aerobat
RC Aerobat's Avatar
Australia, SA, Adelaide
Joined Jul 2013
It would have been good but unfortunately I broke my B6 (clone I think) by accidentally shorting the battery charge lead banana plug on the balance socket for a second while I didn't realise a battery was plugged in.
RC Aerobat is offline Find More Posts by RC Aerobat
Old Oct 21, 2013, 09:55 AM
njozsef is offline
Joined Oct 2009
Please wait.
AC6 calibration progress "charge current value" not enough for 1000mA reference measuring.
Pawel working this problem.
or compile own firmware:
orig forum: https://groups.google.com/forum/#!to...er/iC1KwQuzUlM
Old Oct 21, 2013, 03:28 PM
njozsef is offline
Joined Oct 2009
logview support all cargers.
serial port patch
serial interface (please off external temp sensor if serial port active)
info: http://www.rcgroups.com/forums/showthread.php?t=1046318
http://www.hobbyking.com/hobbyking/s...20hobby%20king
Old Oct 22, 2013, 12:50 AM
serjuro is offline
Find More Posts by serjuro
serjuro's Avatar
Romania, Europe
Joined Aug 2009
Hi guys, having a old PCB Accucel 6 on wich I shorted the positive output lead to the input ground source, I wait for the FW to try to bring the charger back to life ...
serjuro is offline Find More Posts by serjuro
