Old Sep 13, 2014, 06:35 PM
dbaya's Avatar
United States, CA, Union City
Joined Mar 2004
KST DS225MG Sero arm slipping
I installed KST DS225MG servo on my new Tanga. I was centering servo and checking my linkages. I noticed when I pushed the control surfaces, they would not stay centered. Felt something was slipping. What I think I am seeing is the plastic servo arms are slipping on the splined output shaft. Has anyone noticed this or can verify this???
I tried some servo old Hitec servo arms that fit a HS-65HB. Hitec arms seem to not slip.
dbaya is offline Find More Posts by dbaya
Old Sep 13, 2014, 06:37 PM
dbaya's Avatar
Joined Mar 2004
I should mention. The servo seem to be very smooth and quiet
Old Sep 16, 2014, 09:59 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
It could be a fluke, or did all of the supplied arms slip?
If a fluke, ask the vendor to get you some more arms Aloft?
Was this for the flaps?
R,
Target
target is offline Find More Posts by target
Old Sep 17, 2014, 01:59 AM
Marco Generali - italsoaring
snoze88's Avatar
Cremona, Italy
Joined Nov 2010
It happens on older ds225 (produced more than 5/6 months ago).
The teeth of the servo arm are a bit tight and became loosen when it's pushed in place.
I've told about that at kst and now the material and the mold of the arm has been updated
I suggest you to go with the metal arm ones instead
snoze88 is offline Find More Posts by snoze88
Old Sep 18, 2014, 09:43 AM
dbaya's Avatar
Joined Mar 2004
Thank you for the input. No fluke. It happened on all the wing control surfaces. I did get them from Aloft. If he does have the new type and I ask, they will probably be here the next day.
Old Sep 18, 2014, 04:29 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Please keep us updated, Dominic.
Thanks.
R,
Target
Old Sep 18, 2014, 05:20 PM
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
All the nylon servo arms of the early KST servos were a bit loose, the metal arm is tight and the nylon arms can be tightened with chip bag material.
Harri Pihl is online now Find More Posts by Harri Pihl
Discussion New KST 8mm thick servo kcaldwel Hand Launch 238 Aug 05, 2014 12:32 PM
For Sale rx esc battery sero repl parts lla Aircraft - Electric - Power Systems (FS/W) 0 Dec 24, 2013 10:30 AM
Found Need a servo arm set and screw for a KST-DS09A micro servo agarchitect Aircraft - General - Radio Equipment (FS/W) 1 Jul 27, 2013 08:38 PM
Wanted Cirrus CS-30 BB Sero Arms and screws SpiritQuest Aircraft - General - Radio Equipment (FS/W) 2 Mar 12, 2011 06:11 PM
A/r Arm slip sliding away.....? foss1997 Micro Helis 10 Nov 06, 2003 09:09 PM
