Old Oct 10, 2014, 06:23 AM
Thanks Hugo.
Will try building some this weekend
chilau is offline Find More Posts by chilau
Old Oct 10, 2014, 08:11 AM
Also
Was wondering wether to go with a sma t or soldered splice t.
Do you have any advice on your soldered spliced t joint to minimize impedance changes of the cable.
Old Oct 10, 2014, 08:04 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
If 1.2Ghz use SMA, for higher freq. a splice is needed or use 50ohm coaxes and use a gamma match like Alex.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Oct 14, 2014, 09:41 AM
Hi Hugo
Just wondering if your spacing of 152mm is for 1280MHz.
I will go with 1/4 and 3/4 750hm coax.
My calcs seem too long though for 1280 compared to yours.
1/4 = 58.5 x 0.7 = 40.95
3/4 = 175.5 x 0.7 = 122.85
122.85 + 40.95 = 163.8mm
This is without the length of the sma tee as well.
Are you using slightly different lengths to factor in effect of connectors etc. I don't have access to any test equipment so can only go by calculated lengths.
If I solder the 1/4 and 3/4 75ohm coaxes straight to the antennas and measure between ground elements I get close to 152mm spacing.
Chi
Old Oct 14, 2014, 09:57 AM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Where did you get 152mm?
I use 164mm just like your calculations.
-Hugo
Old Oct 14, 2014, 10:06 AM
Originally Posted by Hugeone View Post
The staked fans use the 75/100/50 coaxial transforming/phasing method as described by OMM here
Mine is 1/4-3/4 instead of 3/4-5/4 for less coax loss and it place the antennas 152mm apart for a nice 4.5db gain.
-Hugo
Not sure if these were for 1280.
Also I want to check if it is ok if I solder the 1/4 and 3/4 75ohm lengths directly to the antennas or do I need to have the feed point in line with the ground plane of the antennas.
Old Oct 14, 2014, 10:22 AM
I can fix that.
United States, PA, Mountain Top
Joined May 2006
Hi Hugo,
Can you, or anyone else, post a sample NEC file that can simulate two antennas like this? Just put two dipoles on each end. I am more interested in how to set up the simulation.
Thanks!
-Ken
solomonx is offline Find More Posts by solomonx
Old Oct 14, 2014, 03:31 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Must made a typo...
The fan omni antenna have no ground plane, so I'm not sure of what you mean.
-Hugo
Old Oct 19, 2014, 10:25 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I believe you are referring to the location of the 75 ohm match, correct? If so, they can be anywhere in the system so long as you place the tee at a multiple of 1/2 wavelength (accounting for velocity factor) away from the splice so for RG316/RG179 it would be:
.69 * n/2 * wavelength of frequency
where n = 0, 1, 2, 3, ect.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Oct 19, 2014, 10:27 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The above stated, you can also use a stub tune method (use a Smith Chart) or you can use a single section of coaxial cable right at the tee. Remember that the antennas are 50 ohms and so are the feedlines. This means you have a perfect 50 ohms right up until you hit the tee point. It becomes 25 ohms there.
-Alex
Discussion Lawmate 1.2ghz and CP antennas? Does it work. airbagit13 FPV Talk 23 May 20, 2011 06:58 AM
Question upgrade from fp to cp kkfd Electric Heli Talk 2 Apr 08, 2011 07:28 PM
Sold 2 New - TrueRC 900mAh 11.1V 3S1P (Blade CP) SOLD simages Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 17, 2008 02:16 PM
New 11.1V 15C 2200mAh packs from TrueRC supi7 Batteries and Chargers 17 Nov 30, 2005 04:55 AM
F/S New powerfull cells and packs from TrueRC supi7 Product Announcements 8 Oct 06, 2005 11:47 PM
