Old Aug 02, 2014, 05:49 AM
Germany, NRW, Cologne
Joined Aug 2014
Help!
First mini DLG build
Hi guys,
while making holidays on the countryside, i spend my time at home to build my first selfmade mini dlg (700mm wingspan), because my parents would support me less, if i don't 'flower out' my ideas and build them myself. This will be my first f3k too, and because i always have been fascinated by the tranquility of throwing and sailing, i decided to build my own.
So i start to make it the beginner way, and started to construct the wing out of one block of balsa (1000x100x4) using the modified AG35-38 variation.
Because i wanted to make it to axed (without aileron) i decided to add dihedral to stabilize it.
Now the question, your help appreciated:
How would you connect in this case both wings, because i couldn't find a conclusion from other threads.
I tried with normal white wood glue, but it even couldn't hold the own weight of the wing. Do i use the wrong one?
In this case, i will not build a detachable plane, so that the whole wing will be automatically sticked to the fuselage. Maybe Epoxy? Should be a light connection, which is able to take dihedral, the lift of the wing and the centrifugal force of the launch.
Greetings, Attenbach
see original thread for photos here http://http://www.rcgroups.com/forum....php?t=2217767
attenbach is offline Find More Posts by attenbach
Old Aug 03, 2014, 04:27 AM
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
You can get a very nice/complete plan for the wood-build Mimi 1m glider if you e-mail the guy at f3k.nl
There are some construction tips you can use for your airplane.
sp00fman is offline Find More Posts by sp00fman
Old Aug 03, 2014, 07:24 PM
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
Attenbach, welcome to the DLG addiction
Typically the wing center joint is first glued end to end, then wrapped with a layer of light fiberglass cloth and epoxy or CA. You can see what I mean here.
As Spoofman suggested, look at the Mimi plans and thread. You can also look at Mark Drela's Apogee plans. The Apogee is not a DLG, but a lot of good building advice can be found there.
If your wing is not removable, you can design your pod to provide a lot of support for that center wing joint. something like this:
JimZinVT is online now Find More Posts by JimZinVT
Old Aug 04, 2014, 04:48 AM
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Don't mind if i steal your pod idea.
You have a few days headstart, better hurry
Is it based on some sort of template or are you just freehand shaping it?
Old Aug 04, 2014, 11:06 AM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
You can steal it....it's not mine!
I start with 2 rectangle halves, cut dihedral angles in the top edge (back half), glue them together, then shape.
Ryan has a method where he builds the pod right on the boom. I'll post a link & pictures when I get home tonight.
Old Aug 04, 2014, 05:54 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
I just posted some info and a photo over on the "in the bag" thread about Ryan's lost foam on the boom method.
Help! First Mini DLG build attenbach Multi Task F3X 2 Aug 02, 2014 05:55 AM
Question First dlg; mini (1m) mini or full? joe_crash Hand Launch 1 Jun 09, 2014 04:23 PM
Discussion First Mini Build on a Mini Dragon UBF Frame bubba121887 Scratchbuilt Multirotors 0 Jun 05, 2014 10:43 PM
Discussion First DLG, thinking of Super Mini Topsky HugoCraft Hand Launch 9 Jan 12, 2014 03:02 AM
Discussion topsky mini first DLG light weight mods bsovermars Hand Launch 0 Dec 05, 2013 03:46 PM
