Old Jun 20, 2015, 11:12 AM
fairweatherflyer is offline
Find More Posts by fairweatherflyer
fairweatherflyer's Avatar
United Kingdom, England, Glastonbury
Joined Aug 2014
Build Log
Peter Rake - Sopwith 1 & 1/2 Strutter
Having a crack at building this. Haven't built for an age, so hoping it will turn out OK and with 2 pairs of wings and not 4 for one side (oh well, if that happens I'll just have to do another one! Slightly confused at first having cut out the ribs and realising there appeared to be no top spars. Thanks JIMA and others for putting me right on this. Incidently weighed the paper templates that I peeled off the parts after cutting them - a little over 6g so far and some like fus.sides still have template on. Have had a few snags sourcing bass wood, but that should be resolved now - seems to be used by lots of crafters and makers of dolls houses.
fairweatherflyer is offline Find More Posts by fairweatherflyer
Old Jun 20, 2015, 12:45 PM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
You had me worried then, I thought I'd missed the spars from the top wing. Then I realised what you meant. Top surface spars are a pet hate of mine because they show where no spar should be visible. For some reason I find slight elliptical dihedral less offensive on the eye than a visible top spar.
At this size, and bigger, not having a top spar has never proved a problem on my models. However, don't let that stop you if you feel the need for them. I promise not to be offended.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Jun 20, 2015, 01:07 PM
Joined Aug 2014
Hi Pete,
I'm more than happy to make as is. Ribs look much tidier, and probably stronger without being notched for top spars and underside spars are plenty deep enough. Sorry to have given you a fright! contemplating cutting ply parts out next without splitting it and some look a bit fiddly. Whilst on about ribs though - is it possible to iron on rib tapes over wing covering as you would solar tex on a larger model or does it look odd at this scale and not work with the lighter weight coverings? - probably getting rather ahead of myself here.
Many thanks for your input and interesting to hear your thoughts on this.
Vic
Old Jun 20, 2015, 10:25 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Welcome aboard Vic. Nice to see you found our forum.
It is very possible to simulate rib tapes on a model this size. Many have done it before. It is never too soon to be planning ahead and asking questions. One we may ask you before advising too much further on rib tapes is what you intend to use for covering.
Jim
JIMA is offline Find More Posts by JIMA
Old Jun 21, 2015, 03:40 AM
Norfolk, England
Joined Sep 2001
At this size and, as Jim suggests, depending on covering choice, that micro masking tape makes pretty good rib tapes. Or just narrow strips cut from the cheap cream coloured stuff.
You can, of course use strips of covering ironed/doped on but it would be very subtle at the thickness we're talking here.
Pete
Old Jun 21, 2015, 11:53 AM
Joined Aug 2014
covering
Hello Jim & Pete
Well, as no progress again today, it looks as if I have plenty of time to think about covering. Would like to use the lightest weight, heatshrink, iron on adhesive covering that I can find. So far think the best might be SoLite - but not sure if this comes in likely possible finishing colours of PC10,12 or linen. Any suggestions gratefully received as only covering material I'm familiar with is solartex which is probably going to be too heavy.
Regards to all
Vic
Old Jun 21, 2015, 01:15 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Coverlite/litespan
portablevcb is offline Find More Posts by portablevcb
Old Jun 22, 2015, 11:01 AM
Joined Aug 2014
have found the following re covering materials
re weights of covering material.
Litespan 30g per sq m (all others are weighted to in g per sq metre.)*
Polyester supershrink gloss 60-80g (as on Blackburn models)
Polyester supershrink matt 60-75g
Profilm/Oracover - haven't been able to find a weight for this
Solarfilm 55-60g
Solar tex 85-98g
Solite 20g.**
*requires balsaloc adhesive.
**rather opaque looking
Old Jun 22, 2015, 11:03 AM
Joined Aug 2014
Litespan looking most favourable for reasons of colour range and weight etc.
Old Jun 22, 2015, 12:36 PM
Norfolk, England
Joined Sep 2001
Litespan is what I use on most of my models, even bigger ones than this.
Rather than apply Balsaloc to the framework I apply it in a thin coat to the entire sheet of Litespan using a sponge. Allow it to dry and then use like any other iron on covering. It doesn't add enough weight to cause problems.
I've seen reports of something called Mod Podge being a good, cheaper alternative to Balsaloc, but haven't tried it yet.
So-Lite is just too prone to puncture for my liking and the more normal heat shrink coverings are a bit aggressive. Avoid Solartex like the plague. Great stuff to use but WAY too heavy.
Pete
Old Jun 23, 2015, 05:57 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Pete - have you found Solite more puncture prone than Litespan? In my limited experience I have found the opposite - though that might be because the aggressively sharp and stiff reed type of grass stalks up at t'Moor can puncture the the Litespan as it seems a little more brittle (for want of a better word) than the Solite which has some elasticity....
If flying off nice green soft grass, it wouldn't be a problem.
Colonel Blink is online now Find More Posts by Colonel Blink
Old Jun 23, 2015, 07:02 AM
Joined Aug 2014
cutting ply
A lovely grass landing strip awaits it!
Scale wise the plans are about 1:10.5 - Pete I'm sure can chip in if this is not so.
My most immediate problem is cutting the ply parts neatly. Has anyone tried a bandsaw? have some thin circular rings on 1/32 and some formers on 1/8th.
Many thanks
Vic
Old Jun 23, 2015, 07:45 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Yes, a bandsaw works fine. Just get a fine tooth blade for it.
For a some of the parts a coping saw might be an even better choice. Buy or make a cutting block for it (block of wood with a small hole it in to fit the blade).
charlie
Old Jun 23, 2015, 12:38 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I cut 1/32 ply with scissors and/or a hobby knife.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jun 23, 2015, 12:41 PM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Larry
Me too. Even 1mm but they are my scissors, not the kitchen ones.
Sopwith Mike is online now Find More Posts by Sopwith Mike
Build Log Dan`s Rake Sopwith 1 1/2 Strutter Build Log Dan Parson Scale Kit/Scratch Built 250 Sep 27, 2011 09:18 PM
Discussion Peter Rake's Sopwith 1.5 Strutter -but brushless parf Scale Kit/Scratch Built 8 Jan 11, 2010 05:47 AM
Build Log Manzano Laser Cut Rake Sopwith 1 1/2 Strutter Build Log JMBRAD Scale Kit/Scratch Built 133 Oct 08, 2009 08:01 AM
Peter Rake Sopwith 1 1/2 Strutter JIMA Scale Kit/Scratch Built 241 Jun 24, 2005 10:59 PM
