Old Mar 17, 2016, 10:41 PM
hellmansam is offline
Find More Posts by hellmansam
Australia, WA, Bunbury
Joined Dec 2010
Control horns on top of aileron/flaps ?
G'day all, I'm nearly finished assembling an ARF Phoenix 2000 minus a motor, for slope fun and am wondering if putting the control horns on top of the flaps and ailerons has any negative effects ? My thinking being to protect the servos from having the control horns snagging on stuff during landings/arrivals
hellmansam is offline Find More Posts by hellmansam
Old Mar 17, 2016, 11:21 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
You can always use servo fairings to streamline the servo arms.
It's just a bit more difficult running the control rods topside from a servo on the underside. Otherwise, no big deal.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 17, 2016, 11:32 PM
tomleach is online now
Find More Posts by tomleach
tomleach's Avatar
United States, OR, Corvallis
Joined Mar 2007
You will want to check where the hingeline is though. If the hinges are on the top of the aileron/flap and you put the horns on top, they will need to be longer then if they were on the bottom of the surface to get the same amount of throw.
Generally, the surface is controlled from the opposite side of the hinge for best geometry.
If the surfaces are center hinged, then it doesn't matter
tomleach is online now Find More Posts by tomleach
Old Mar 17, 2016, 11:40 PM
Joined Dec 2010
Thanks guys , it's an EPO wing, centre hinges
Old Mar 17, 2016, 11:49 PM
tomleach's Avatar
Joined Mar 2007
no worries then, bury the servo, bring the control rod through the wing, pop it out the top to the control horns. Just make sure to miss any spars
I've added some pictures of my Mamba combat wing with the layout like you're proposing. Works great and all the delicate bits are buried.
Help! Control horn help! Aileron, elevator and rudder lengths King of Plane Classic Pattern Flying 5 Mar 11, 2016 03:18 PM
Discussion Aileron torque rods vs direct to a control horn kukailimoku Sailplane Talk 43 Oct 16, 2015 01:44 PM
Discussion 4-40 aileron/flap horns Ib Jensen Sailplane Talk 2 Jul 07, 2015 10:54 AM
For Sale G-10 control horns flap & aileron dhauch Aircraft - Sailplanes (FS/W) 7 Feb 06, 2013 09:04 PM
Question Ailerons, Flaps, and those ugly control horns markamerica Fuel Warbirds 4 Jan 31, 2006 01:50 PM
