Old Apr 17, 2014, 04:57 PM
Joined Dec 2011
Is it possible to do this?
I want to make my own battery from individual cells so I can have it just the size and voltage I need.
I also want to have as high voltage as a 12 cell lipo but using smaller cells, is that possible?
Basically I want to make a 12 cell LiPo battery that is much smaller than the ones I've seen so far.
Thanks for any help!
abcd123 is offline Find More Posts by abcd123
Old Apr 17, 2014, 05:32 PM
Joined Feb 2007
abcd123
The answer is technically yes but I would not recommend it. Accidentally touch the wrong terminals together and you could be in real trouble with a LiPo fire.
Do you have the facilities to balance charge a 12s LiPo ?
Why not use four 1000mAh 3s (or three 4s) with a series connector. That way each battery can be disconnected and charged (or even replaced) individually.
Quorneng is offline Find More Posts by Quorneng
Old Apr 18, 2014, 04:21 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
You want smaller. Smaller, as in what? Size, mah, weight?
Would you care to elaborate?
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Apr 18, 2014, 06:48 AM
United States, MN
Joined Feb 2011
Sure it's possible. Though very few chargers will charge 12s. Also there are not that many places that sell loose cells.
A quick search of Google found these instructions:
http://dream-models.com/electronics/...ng-a-LiPo-pack
Just how small are you looking for though? HobbyKing has 6s as small as 1300mah. No reason to build a pack if you can buy off the shelf.
grimbeaver is offline Find More Posts by grimbeaver
Old Apr 18, 2014, 11:18 AM
Thinking about flying
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Possible?
Yes.
Practical?
No.
Rhea is offline Find More Posts by Rhea
Old Apr 18, 2014, 11:24 AM
Joined Aug 2012
many online places to buy loose cells.. but the 12 cell battery charger is a rare breed.. I think you might wanta break it down to 6 cells or have a separate plug to charge 6 cells at a time..build what you want if you feel the need. Forget all those that kill ur dream..just do it have fun
tntpoof is offline Find More Posts by tntpoof
Old Apr 18, 2014, 10:00 PM
Joined Dec 2011
Ideally I'd like 500-900 mAh at 12 cell voltage that can deliver at least 10 amps, do you think this is possible?
Old Apr 18, 2014, 11:43 PM
USA, GA, Marietta
Joined Aug 2005
1S 850mah 20C $3.13usd ($3.13 * 12 = $37.56) + wire and connectors
http://www.hobbyking.com/hobbyking/s...idProduct=7649
4S 850mah 25C $9.28usd ($9.28 * 3 = $27.84) + wire and connector for a series connection
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Glen
Discussion Do folks really do this? SayCheeze Beginner Training Area (Aircraft-Electric) 18 Nov 19, 2013 09:49 PM
Help! This Dual RX Setup Possible? AEMontoya Radios 0 Nov 15, 2013 02:58 PM
Discussion Is this true? Certainly possible... agpilot24 Life, The Universe, and Politics 6 Oct 10, 2013 09:50 PM
Discussion a dx8 mix. Is this possible? onlinegamesnz Radios 7 Oct 09, 2013 02:52 AM
Help! Is this possible and how do I do it. JAM Batteries and Chargers 15 Mar 19, 2006 02:39 AM
