This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Feb 03, 2016, 03:28 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I have several models running with A123s, and they're mostly propped to draw between 35A and 45A -- i.e. up to 18C. The only thing to watch out for is that when they're empty, they're really empty; there's no chance of a short burst of power like you can get with LiPos by resetting the throttle if you let them run until lvc kicks in.
abenn is offline Find More Posts by abenn
Old Feb 03, 2016, 11:34 AM
ignernt_dweeb is online now
Find More Posts by ignernt_dweeb
United States, TX, Floresville
Joined Apr 2015
Originally Posted by i_r_beej View Post
I'll say. I read the first page, skipped to the last and now I'm ready to pee my pants in terror! just got my first LiPo battery and wondering if I should just take it back to the store and get a NiMh instead!
Just kidding. But still... Jeez.
If you do pee your pants, make darned sure you don't have a LiPo in your front pocket.
ignernt_dweeb is online now Find More Posts by ignernt_dweeb
Old Feb 03, 2016, 12:50 PM
CraigHB is offline
Find More Posts by CraigHB
crash tested
CraigHB's Avatar
United States, NV, Reno
Joined Dec 2014
Originally Posted by vollrathd View Post
The 2500 Mah A123 spec sheet indicates they are rated for 70 Amp or 28 C discharge.
I guess it varies depending on the make then. The ones I looked up were 10C which would be 25 Amps. I have no idea who is the original maker of the A123 battery. Also their original application. Just about all round cells have one other than RC use. For example 18650s were originally designed for laptop computer battery packs, but now they are used in lots of different devices.
CraigHB is offline Find More Posts by CraigHB
Old Feb 03, 2016, 01:15 PM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
A123 'cells' were produced by A123 Systems, Inc.
The idiots at A123 Systems managed to 'kill' the company. They were to be used in automobiles and electric storage facilities and the like.
The cells are still available. I've used nothing but them in all of my planes weighing 3 lb. or more since 2006, and continue to do so.
The C rate on A123 cells is 15C. The best static amp draw, for good flight times, 6 to 7 minutes depending on flying style and airframe, is around 35 amps, which yields approximately 100 watts in per cell.
Ken Myers is online now Find More Posts by Ken Myers
Old Feb 03, 2016, 05:17 PM
vollrathd is online now
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
Here is where I've been buying my A123's. They are an authorized USA reseller of these cells. These are the new 2500 Mah type "B" A123 cells. Kind of expensive at $20.10 each. But their price drops to $9.30 if you buy 10 or more cells.
http://www.a123batteries.com/product-p/anr26650m1-b.htm
I just received an order for (39) 2500 Mah A123's for my electric conversion of a 50 cc 95 inch wingspan model. The supplier is in Michigan, USA. The A123's showed up two days after the order was placed.
FYI, for those trying to solder to these cells, it takes a 100 Watt temperature regulated Weller Soldering iron, along with some Home Depot Oatey H-20 water soluble paste flux to solder to these cells.
As for how long these cells last, a fellow club member has a two cell A123 2300 Mah pack that was purchased in 2009. It is used in his turbine powered jet. The shrink wrap on the pack was "Sunburned" to where it was an obvious different color that part of the pack that was hidden from sunlight.
I just ran a discharge test on that pack at 15 Amps. It's voltage was a percent or so less than a brand new pack, and it's ampere hour capacity was also within a few percent of a brand new pack. He put it back into his turbine model.
vollrathd is online now Find More Posts by vollrathd
Old Feb 03, 2016, 08:13 PM
i_r_beej is online now
Find More Posts by i_r_beej
United States, OR, Portland
Joined May 2008
My pants are Nomex.
i_r_beej is online now Find More Posts by i_r_beej
Old Yesterday, 05:46 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by diablo2112 View Post
Cost me about $200 to build myself, with a bulk purchase of 18650 cells off eBay. ......................
Which ones are they?
I see that ebay offers many different brands.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Today, 04:00 PM
diablo2112 is online now
Find More Posts by diablo2112
AMA Member since 1986
Joined Jul 2007
I bought these about 18 months ago, a bulk purchase of 120 cells for $180. The seller is no longer on eBay. Here's the details on the cells. I haven't had to make any more packs, so haven't done the research to find another supplier.
These were 18650 Li-Mn cells rated at 2200 mAhr. These cells are labelled as "INR" which I believe is a newer Li-Ni-Co-Mn chemistry. They retain the safety characteristics of traditional Li-Mn cells, while being capable of higher discharge rates (up to 5C). Samsung manufactures these cells, and I suspect these were Samsung cells labelled for off-brand sale.
Here's many more details on how I made the 11S10P pack for those that are interested.
https://endless-sphere.com/forums/vi...hp?f=3&t=59735
diablo2112 is online now Find More Posts by diablo2112
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 27 Aug 27, 2014 07:26 AM
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 10:46 PM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 01:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 09:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 11:00 PM
