Old Dec 31, 2015, 09:09 PM
Av8er278 is offline
Find More Posts by Av8er278
United States, CA, Chula Vista
Joined Nov 2015
Servos for foamies
What kind of servos do you guys use?
Av8er278 is offline Find More Posts by Av8er278
Old Jan 01, 2016, 12:13 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
TowerPro MG90.
Now discontinued unfortunately
The new/replacement digital MG90D are terrible, just awefull (all 4 of them) . Not smooth , and long servo arms makes the travel even less smooth (jerky rotation)
So now I need to find a new (cheap) brand of Metal gear servo
For cheapy, light foamies
HXT900 , or HXT500 (sold by hoobyking, made by TowerPro)
1101 is offline Find More Posts by 1101
Old Jan 01, 2016, 12:14 AM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
I get all my servos from Headsup Hobby. Great prices and quality servos.
http://www.headsuphobby.com/SERVOS-ACCESSORIES_c61.htm
BHOFM is offline Find More Posts by BHOFM
Old Jan 03, 2016, 11:57 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
If you want cheap Tower pros will work. want better E-max not bad. If you like your bird use Hi-tech m/G servos. yes they cost more but very good. Really like you bird Dymond are fine.
dankar04 is online now Find More Posts by dankar04
Old Jan 03, 2016, 12:00 PM
Eagle2Nitro is offline
Find More Posts by Eagle2Nitro
Extremely Twisted
Eagle2Nitro's Avatar
United States, LA
Joined Apr 2014
Where can you get Tower Pros?
Eagle2Nitro is offline Find More Posts by Eagle2Nitro
Old Jan 03, 2016, 01:34 PM
Tucson, Az
Joined Feb 2007
Value Hobbies.
Old Jan 03, 2016, 08:32 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Headsup
Old Jan 16, 2016, 05:24 PM
kyflyer67 is offline
Find More Posts by kyflyer67
Joined Jun 2015
I've used a bunch of Tower Pro SG90 (9 gram) servos ordered from eBay for around $3 each and haven't had any problems with them.
kyflyer67 is offline Find More Posts by kyflyer67
Old Jan 17, 2016, 03:30 AM
1101 is offline
Joined Dec 2008
Be carefull where you get them. Ive been sold 2 lots of fakes. The fakes are crappy in comparison.
Old Jan 17, 2016, 06:20 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I buy them as HXT 500 and 900s from Hobby King, ten at a time. The gears in these are about twice as thick in these as other servos of the same size. You have to really work at it to strip them.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jan 17, 2016, 07:56 AM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
Hextronic (HXT) fan here as well - including their larger servos.
ahicks is online now Find More Posts by ahicks
Old Jan 17, 2016, 10:09 AM
poidogole is offline
Find More Posts by poidogole
Also known as tomorrow517
poidogole's Avatar
United States, TX, Plano
Joined Dec 2012
I usually buy mine from Heads Up RC. Great online service! Tower Pro are the cheaper ones. Spend a little more money.
poidogole is offline Find More Posts by poidogole
Old Jan 17, 2016, 10:23 AM
jammied is offline
Find More Posts by jammied
jammied's Avatar
United States, WY, Newcastle
Joined Apr 2011
I have been using the hxt 900 without any problems for a few years on a mus and a 450 class trainer. I also read somewhere that the other opies of the hxt are not as strong or as well built.
jammied is offline Find More Posts by jammied
Old Jan 17, 2016, 10:31 AM
Evenflow is offline
Find More Posts by Evenflow
Joined May 2015
For the twisted hobbys planes I would recommend to use a Hitec HS65hb or HS65mg on Ailerons and Futaba s3114 on elevator and rudder.
This combination survived over 500 flights with 3D abuse and still goes strong. Good positioning accuracy and position repeatability. I used it on the Crack Laser and MXS-c.
For the Edge 540 v3 I wanted to try cheaper servos. I bought the DS65hb. While okay on elevator and aileron it is not durable enough on rudder (with combined thrust vectoring control). I already replaced the gears two times.
Next time everything will be replaced by the Hitec/Futaba combination mentioned above.
Evenflow is offline Find More Posts by Evenflow
Old Jan 17, 2016, 11:15 AM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
http://www.hobbypartz.com/33p-solarservo-d650.html
http://www.hobbypartz.com/33p-solarservo-d654.html
For those of us who look for less expensive alternatives, I have been using these for some time with very good results.
Hope this helps.
Steve
sgomes is offline Find More Posts by sgomes
Wanted fomies near detroit brownegg24am Aircraft - Electric - Airplanes (FS/W) 0 May 16, 2015 11:26 AM
Question how would this work for a set up for a really heavy fomie swim93 Foamies (Scratchbuilt) 6 Mar 01, 2010 01:31 PM
Fomie for aerial photography spacecase Foamies (Kits) 3 Dec 13, 2004 09:07 PM
Yippee! build a fomie from scratch for a school project; Help Needed to Jarg Foamies (Kits) 3 Nov 09, 2004 03:04 PM
2 walmart fomies for free to two good homes flying_pig Foamies (Kits) 1 May 04, 2002 12:42 AM
