Old Oct 28, 2011, 03:08 PM
Jürgen Be is online now
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Volmer VJ22 "Sportsman" Amphibian, Video, free Plans
I want to present my latest model,
it`s a 1:10 scale Depron build Volmer VJ22 "Sportsman" Amphibian.
First vid is available in HD on Vimeo:
Volmer VJ22 (4 min 50 sec)
latest vid from last weekend, during a small "seaplane" meeting at Hagnau / Bodensee / Germany
http://www.rcmovie.de/video/a9160ba1...sman-Amphibian
Two sheet A0 plans are free download from:
http://www.vth.de/flugmodell-und-tec...ra-wasserflug/
also in A4 tiled plus a PDF file including lots of photos from the build up.
Complete article including instructions is available at VTH-Verlag ( in german language only )
http://shop.vth.de/fmt-extra-wasserflug.html
link to Volmer Aircraft
http://www.volmeraircraft.com/index.html
youtube vid of original VJ22
Volmer Sportsman Amphibian NZ (12 min 46 sec)
Jürgen Be is online now Find More Posts by Jürgen Be
Last edited by Jürgen Be; Jun 10, 2013 at 03:58 AM. Reason: Plans Link Update and Vid of Original Volmer
Old Oct 28, 2011, 03:17 PM
Jürgen Be's Avatar
Joined Oct 2008
Wingspan is 110cm
flying weight 410 - 440g
motor is a 2730-1700 ( HK / turnigy like )
ESC 18A Turnigy like
battery Lipo 2s 1050mAh
prop from APC 7 x 5 Slowfly
servos 5x 9g
Gear is functional and servo controlled ( see in Videos )
Jürgen
Old Oct 28, 2011, 05:44 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Jurgen
a very nice high quality build
please post more build details
thanks for sharing
David
how much is offline Find More Posts by how much
Old Oct 29, 2011, 08:33 PM
Fast Freddy is offline
Find More Posts by Fast Freddy
Madison, WI
Joined Feb 2004
Jurgen, Bravo! Beautiful model! I especially like the retractable landing gear, very nice!
Fast Freddy is offline Find More Posts by Fast Freddy
Old Oct 30, 2011, 03:39 AM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Very nice Job Jurgen real nice model and thanx for sharing the plan.
Greetz ,
Bart
Bart83 is offline Find More Posts by Bart83
Old Oct 31, 2011, 08:37 PM
Fred Sanford is offline
Find More Posts by Fred Sanford
Fred Sanford's Avatar
United States, MN, Bemidji
Joined May 2003
Jurgen
Great job on an overlooked design!
Fred Sanford is offline Find More Posts by Fred Sanford
Old Oct 31, 2011, 11:16 PM
Teambreen is offline
Find More Posts by Teambreen
United States, FL, Lake Wales
Joined Nov 2005
Very nice Job On a very unusual subject. Also thanks for sharing the plans I just down loaded them and they look really nice and fun to build by.
Teambreen is offline Find More Posts by Teambreen
Old Nov 01, 2011, 04:11 AM
Jürgen Be's Avatar
Joined Oct 2008
Thanks for the nice replys,nice that you like my version of the Volmer VJ22.
The model is built up completley from 3mm Depron and a few parts from balsa, lite ply, some CFK stuff and a bit of 6mm Depron.
Step by step building photos are in an additional PDF to free download. The file is called "Weitere Baustufenfotos" and contains 13 pages A4 with 8 photos each.
The wing is made from one piece 3mm Depron, bended over the nose. Rips and spar is 3mm Depron. Each wing has two aditional ribs from balsa and the stut mounts from 1mm ply. After servo install, the wing can be closed. Then the underside at the wingtip can also be closed with a part of 3mm Depron.
to be continued, tell me if your interested
Jürgen
Old Nov 01, 2011, 05:03 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
We are watching your building ,keep it coming . joe
cracksmeup is offline Find More Posts by cracksmeup
Old Nov 02, 2011, 01:08 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
a very nice design effort, there. I have been wanting to do something very similar for a while, but want to do a Thurston Teal, instead. The design concepts will work perfectly on the Teal.
Thanks for the nudge...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Nov 12, 2011, 06:22 PM
Jürgen Be's Avatar
Joined Oct 2008
Build of the fus:
Foamparts made from 3mm Depronand the bulkheads were cut out in one piece, cut in two just before glueing to the bottom and keel. Then applied the upper parts and the ply braces
Old Nov 12, 2011, 06:34 PM
Jürgen Be's Avatar
Joined Oct 2008
Next the fus sides are prepared, positons of bulkheads and base drawn to the sideparts. First glued to the bulkheads below the plybraces. Then to the front and back. Next the bottom behind the step and upper front of the fus are closed.
Old Nov 13, 2011, 03:06 PM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Hey Jürgen,
Wonderful Plane. I really like this one and definitely want to build one. I have a couple questions for you if you don't mind.
I have never built a plane from Depron before and noticed the curvature of the wing and wing tip. How did you do that?
How did you vacuum form the plastic around foam without it melting?
I have no problem buying the magazine with the instructions to this however, I have no knowledge of the German language. Do you plan to translate the instructions in English for those of us that are not bilingual or is there a way we can work something out so that I can build and enjoy one of these?
Is there a kit version so we don't have to mess with vacuum forming and all the cutting and just enjoy the build? If not, have you considered making kits to sell for those of us less talented, capable or patient?
Did you cut each part by hand or did you use a machine to cut them out?
Sorry for all the questions, I am just very interested in building this plane.
Thanks in advance,
Orion
Orion Pax is offline Find More Posts by Orion Pax
Old Nov 13, 2011, 09:05 PM
Jürgen Be's Avatar
Joined Oct 2008
Orion,
no trouble about any question
Nice that you like this model of the Volmer VJ22, but no, there is kit version and I do not plan to do one. I think that it is not very hard to build, because I kept the construction strait forward. The step by step building you can see on the additional photos in the PDF. No really need in the magacine, if you can`t read it. There are no more photos from building in and give the words to an online translator, I think will give no good results:-)
The plastic parts, like canopy and side windows are made without vacuumforming. You can make this parts very easy and without any hightech machines. Just have a closer look to your oven, protective gloves
........styrofoam,..... I give an idea later, it´s late in the night right now in Germany and I just wanted to do a short answer.
Depron parts are all cut by hand, using a sharp hobbyknife, or cutter.
Bending Depron, curving is also easy to do, if you practise on som scrap material.
I think that there will be no worry for you in building a model, if you don`t loose your patience with the new material Depron.
I will tell you more about soon.........
Jürgen
Old Nov 13, 2011, 09:55 PM
Orion Pax's Avatar
Joined Dec 2006
Jürgen
Thank you for your reply. I look forward to more details.
I didn't see a recommended CG, locations for the ESC, RX or Lipo, water proofing if any or the size wheels that you used.
I do enjoy the looks of this plane and I have tons of extra motors, escs and servos. My buddy and I are thinking about building a pair of these. Looks like an absolute fun plane to build and fly so I look forward to your help and thank you for taking the time to design this plane and your generosity to share it with us.
Orion
Sold *LOOK* Out of Production Sportsman Aviation Waco .30 ARf NIB $135.00 FREE SHIPPING! stevster Aircraft - Fuel - Airplanes (FS/W) 1 May 09, 2011 01:16 AM
Discussion Depron Twinkle - the original parky amphibian - *FREE PDF PLANS* theKM Foamies (Scratchbuilt) 16 Oct 04, 2008 09:12 AM
Any Loehning Amphibian Plans ??? Biper/Piper Waterplanes 2 Nov 02, 2005 06:24 PM
Question Does anyone out there have 3-Views or plans for a GRUMMAN WIDGEON amphibian?? rcminiman Scale Kit/Scratch Built 26 Jun 18, 2005 10:52 PM
Plans for a Lake Amphibian? Rick_the_Jeeper Waterplanes 16 Jul 28, 2004 01:10 AM
