Old Sep 07, 2001, 09:15 PM
viperjet is offline
Find More Posts by viperjet
lakehead,ca. u.s.a.
Joined Sep 2001
klingberg wing
I'm building a 100 inch klingberg wing ,
i figure it will come out to 6.5lbs to7.0 lbs.Anyone got any suggestions about motor
gear ratio,and prop.Any suggestions would be greatly appreciated. THANKS ALL
AL
viperjet is offline Find More Posts by viperjet
Old Sep 11, 2001, 08:13 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Re: klingberg wing
You're going to need about 300 - 320 watts at the prop. This is not my kind of model at all, but if I had one myself I would be thinking of something like two Speed 600 8.4v (most likely the 'Race' versions) on 2.5:1 gearboxes with 10x6 props. I would have each motor 'see' 10 cells and decide if I had 10 or 20 cells when I knew which way the weight was going.
I don't know the US motors too well, so I couldn't recommend which motor would be best if you only wanted one motor. If I was using my usual German stuff, I would be thinking of going at the very least to a geared Ultra 930-7.
ChrisP is offline Find More Posts by ChrisP
Old Sep 12, 2001, 07:13 AM
Regecide is offline
Find More Posts by Regecide
What's a Member??
Sydney,Australia
Joined Mar 2000
You got any picture of your wing?
Alex
Regecide is offline Find More Posts by Regecide
Old Sep 12, 2001, 05:00 PM
viperjet is offline
lakehead,ca. u.s.a.
Joined Sep 2001
klingberg wing
chrisp, thanks for the input. twin motors are out! it's already
setyup for a single motor. I'm will give your suggestions some
real thought.
Alex no pic's yet it's about 70 percent complete.
thank's guy's Al
Old Sep 12, 2001, 09:10 PM
Adam Neat is offline
Find More Posts by Adam Neat
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
What makes you think it will be so heavy? I thought the Klingberg wings had a very light wing loading. How much area will it have? Are you wanting something high performance or do you want to get to altitude in a reasonable ammount of time and search for thermals?
Adam
Adam Neat is offline Find More Posts by Adam Neat
Old Sep 14, 2001, 03:42 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Re: klingberg wing
real thought.
Al
OK, if you're stuck with just one motor and you need, say , 300-320 watts, you should be searching for a motor that will pull something like 30-35A on 12 cells. At an efficiency of 65-70% this would give you what you are looking for. This is only a tad above what you could get out of a Speed 700 9.6v, but it's so close it might be well worth looking at as a low cost option.
Graupner has a 2.7:1 (?) gearbox for this motor, so it would be easy to find a suitable set up. I have Speed 700's in two models and they pull like a Kenworth truck, only smoother !
I really think I would give this a try.
Lots of luck !
Chris
PS - I presume it's a pusher. Make sure the prop blades cannot fold further inboard than straight back or you risk shaking the model apart when one blade unfolds under power and the other not !
Old Sep 14, 2001, 08:26 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Al, isn't that the answer you were looking for? Do you think you'll have it ready for <a href=http://www.dvrc.org/events/efly01/efly01.htm target=blank>the Devil Mt. meet</a> in a couple of weeks, I hope so? It may be worth calling Kirk to see if he has one of these gearboxes. Good luck, see you in a few! Bring your entire airforce down with you.
Greg
<img src=http://www.dvrc.org/events/efly01/Image5.gif>
GregG is offline Find More Posts by GregG
Old Sep 14, 2001, 12:56 PM
viperjet is offline
lakehead,ca. u.s.a.
Joined Sep 2001
adam, the klingberg wing is 41/2lbs asa gider .Add 21/2 lbs batteries'plus motor &gb plus esc . = 7lbs+
chris thanks for the info. I have a speed 700 9.6 v bb .
according to NC catalog the GB's they have won't fit the
BB motors . IFi can go to the 700 ican save some weight
in batteries. thanks for the info and feedback it's greatly
appreciated. Al
Old Mar 12, 2005, 09:24 AM
Brianswood is offline
Find More Posts by Brianswood
Joined Mar 2005
Klingberg
Are there any of these left? I would like to find a 100" plans or kit.
Brian
Brianswood is offline Find More Posts by Brianswood
Old May 06, 2015, 05:52 PM
rev.iain is offline
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
100" Klingberg E-Sailplane
I thought I would resurrect this thread which obviously was started in the dark and distant days of brushed motors.
I have a KW 100" which I plan to use as an e-soarer for sport flying only, unless it proves to be competitive, which I doubt , but we shall see.
I think about 400-500W should be adequate, and I am looking toward a Hacker A30 geared in a tractor configuration, on 4S with a 16" folder to provide "GO".
I have chosen the tractor configuration for two reasons; the first is ease of launching, no prop to slice unwary hands at launch. Secondly I think the power system will replace some of the lead required for balance.
If anyone has any experience with a similar set-up I would be pleased to hear any useful comments.
Iain
rev.iain is offline Find More Posts by rev.iain
FS - Assembled Klingberg Wing & Larry Jolly "Flinger" HLG kit Shreve Aircraft - Sailplanes (FS/W) 14 Nov 14, 2003 05:37 AM
Klingberg Wing kit price info seanm Aircraft - Sailplanes (FS/W) 4 Aug 13, 2003 10:16 PM
Looking for someone to build my Klingberg Wing 100 for me Aten W Arthog Thermal 0 Jun 20, 2003 06:46 PM
Klingberg wing airfoil? Thomas B Modeling Science 3 Feb 24, 2003 05:48 PM
50% Klingberg wing heimer Electric Sailplanes 2 Jul 25, 2001 03:19 PM
