Old Jan 02, 2015, 08:14 AM
BenVK's Avatar
United Kingdom, England, Enfield
Joined Jan 2012
Anderson M5 Race won't turn at speed?
I picked up this new in the box Anderson M5 Race off ebay recently.
My first road bike...
Just finished converting it to brushless and tried it out this morning. It goes pretty well on a 4370kv motor and 2S but it just won't turn unless I slow it right down.
I noticed that the steering damper is pretty soft allowing the front wheel to move left and right without much pressure, could that be the problem?
Cheers and Happy New Year everyone!
Ben
BenVK is offline Find More Posts by BenVK
Old Jan 02, 2015, 09:18 AM
r46
huggin dat apex!
r46's Avatar
United Kingdom, London
Joined May 2005
Damper could be firmer maybe, what radio using?
That servo weak for job tbh
Here's it's spec
http://www.hobbyking.co.uk/hobbyking..._0_13s_60.html
r46 is offline Find More Posts by r46
Old Jan 02, 2015, 09:26 AM
BenVK's Avatar
Joined Jan 2012
It was the only spare servo I had laying around.
What spec servo should I be looking for?
Old Jan 02, 2015, 09:37 AM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
Along lines (but need to use an external bec for true 6v or 7.4v to get best from servo)
http://www.hobbyking.co.uk/hobbyking...g_0_07sec.html
Which radio you using?
Old Jan 02, 2015, 12:11 PM
BenVK's Avatar
Joined Jan 2012
Isn't that servo a bit OTT?
The damper shaft is moving at least 5mm by hand before the driving the current servo so I'll try and stiffen that up a bit first before buying another servo I think.
Using a Flysky GT2B radio.
Old Jan 02, 2015, 12:33 PM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
Never! that's a good starting point that spec servo, bike has weight so need good kg rate an speed. If was sr4 need to use higher kg an torquey servo. Gt2 is limited to adjustments, swith radio to a gt3b or c (still can use current reciever)
Old Jan 02, 2015, 02:52 PM
BenVK's Avatar
Joined Jan 2012
I still think the damper is pants but thanks for the advice.
Is there a big thread on these bikes like there is for the M5 Cross and SR4? I couldn't find one...
Would like to see what mods have been done to this bike. I'll be shortening the windshield on mine, it's too tall and I've scratched it all to hell anyway doing wheelies and flipping over..
Old Jan 02, 2015, 04:01 PM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
damper needs setting up forsure is been used on afew bikes including sr4 ' s with great success.
Has it got front brake?
Old Jan 02, 2015, 04:23 PM
BenVK's Avatar
Joined Jan 2012
Nah, no front brake.
I think it's going to take me awhile to learn how to control this bike. It's a completely different skill to motocross bikes.
Old Jan 02, 2015, 05:46 PM
Espa˝a, CL, ┴vila
Joined Sep 2008
Ben, you don't tell anything about if you're using the rear gyro or not.
The faster the bike, the bigger gyro effect and harder to make it turn. Remove all internals from rear wheel and you'll find current steering damper setting works without an issue.
Other tip, get the soft rear tyre and add some lead tape to rear wheel after gyro has been removed.
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Jan 02, 2015, 07:05 PM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
Here's two..
http://www.rcgroups.com/forums/showthread.php?t=1418852
http://www.rcgroups.com/forums/showthread.php?t=2021892
Old Jan 02, 2015, 07:49 PM
RC Motorcycles are fun Bobby
King of the hill's Avatar
Australia, NSW, Royal National Park
Joined Sep 2013
I'm using this damper on my SR4 - I've found I can totally change it's feel / set up by first changing to a thicker/ thinner oil or changing the spring tension inside the damper - harder / softer or you can change both for a full customized set up . Sometimes the factories forget to put any oil in dampers or shocks during production .
King of the hill is online now Find More Posts by King of the hill
Old Jan 03, 2015, 06:30 AM
BenVK's Avatar
Joined Jan 2012
Perfect, thanks!
Learnt a lot from reading those threads. I'll be removing the gyro once I've got the hang of controlling the bike but first I need to stiffen up the damper. There's also the option to change the rake of the front forks which I didn't notice before..
Old Jan 03, 2015, 10:09 AM
r46
huggin dat apex!
r46's Avatar
Joined May 2005
No worries!
Let me know when out next I come over with my nitro roadie
Old Jan 03, 2015, 02:35 PM
BenVK's Avatar
Joined Jan 2012
I'll be over the park tomorrow if the weather is good. Flying in the morning and running the bikes after that..
Was raining all day today so modified this M5. I adjusted the rake of the forks backwards for better turns (I hope), stiffened the damper, mounted some nylon rod for a wheelie bar, cut 25mm off the windshield and moved the rider forward.
What do you think? I much prefer the look of it this way..
Discussion Hubsan X4 won't turn on at all :( sad_muso Mini Multirotors 1 Jan 01, 2015 06:50 PM
Help! Model won't roll left on ailerons at speed. Vortrog Electric Plane Talk 16 Sep 30, 2014 01:48 AM
Discussion Anderson M5 Race Bike Derek Wythes Motorcycles 12 Dec 25, 2013 09:19 AM
Sold Anderson Racing M5 Race Bike RTR with Gyro reddyrightnow Cars - Motorcycles (FS/W) 0 Mar 22, 2011 08:18 PM
New Product Hot Racing Parts for Duratrax DX450/Anderson M5 slawsonb Motorcycles 3 Mar 15, 2010 10:02 AM
