Old Jan 30, 2014, 05:20 PM
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
New Product
DJI Lightbridge HD Video + Digital Link
More info from this thread
http://bbs.5imx.com/BBS/forum.php?mo...extra=page%3D1
Feature list
HD downlink 1080P 30 FPS
One single 2-way digital communication link
Encrypted data
2 radio controllers can be used pilot-camera man
HDMI input / A/V input (not sure if it can switch between the two like iOSD MKII)
HDMI output / USB for iOS and android (no mention of RCA output)
Built in OSD
Waypoint navigation and telemetry to phone or tablet
100mw 1 mile range with 5dbi omni, 3 miles with 14dbi directional
4000mAh ground station battery to give 4.5 hours of use, can also charge your phone or tablet through USB
Translation of the post
This post last edited by Royal at 2014-1-30 13:32 Griffin
DJI Lightbridge is DJI upcoming 2.4G full high-definition digital video transmission system, the maximum transmission 1920 * 1080p @ 30fps full HD video data, measured the effective transmission distance up to 1.7km , is a professional aerial photography and FPV enthusiasts essential artifact!
First, the characteristics
· 2.4G Full HD digital transmission
- Digital video transmission, input supports up to 1920 * 1080 @ 60fps , output up to 1920 * 1080 @ 30fps ;
· distance
- Use 2.4G RF technology, transmitting power 100mw (CE and FCC certification);
- Ground terminal with 5dbi omni-directional antenna (standard), measured the effective transmission distance of 1.7km (1.05mile);
- Ground terminal with 14dbi directional antenna (optional), measured the effective transmission distance up to 5km (3.1mile);
• Multiple video input and output formats
- AV input;
- HDMI input;
- USB 2.0 Full HD video output: IOS, Android and other mobile phones, tablet PCs do monitor via USB connection using;
- HDMI HD video output;
· Built-in remote link
- Downlink and uplink remote video link system while working at 2.4Ghz;
- Ground terminal via remote control coach to get the remote control port data sent to the client through the sky uplink, downlink synchronization with the video link, without disturbing each other;
- Ground terminal controller supports two simultaneous input Lu Yao, were used as aircraft control and PTZ control, the sky receives transmitted to the master via DBUS;
• Immunity
- Uplink frequency hopping (FHSS) + Spread Spectrum (DSSS) technology, high transmission stability, strong anti-jamming capability;
- Downlink MIMO multiple antenna technology and using OFDM modulation, with advanced algorithms to effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system;
- Real-time monitoring of each downlink channel interference state, dynamically select the best channel operation (up to 8 image transmission channels);
- Same time and can support up to eight devices simultaneously sets Lightbridge;
• Low latency
- 80ms maximum delay systems; • OSD function
- Built-in OSD function, with NAZAV2, WKM, A2 use when no external IOSD, information overlay function can be realized;
• Bundled flight controllers
- Equipment must NAZA V2, WKM, A2 used in conjunction with the master;
• Multi-slave mode and Information Security
- End single sky and simultaneously work with multiple ground terminal (only one ground terminal to transmit control data, the device can only receive the rest of the video);
- Data encryption transmission, only after the ground terminal on the frequency authorized to receive video data to ensure information security;
• Large capacity battery and the external charging
- Built-in 4000mAh high capacity ground terminal battery, the device can work for 4.5 hours;
- Standard charger or 3s-6s battery can be charged, charging only 1.5h;
- Battery power LED visual indication;
- Through the USB external mobile devices, providing the charging function for mobile devices, an external device to extend the use of time;
Second, Specifications
Video Input HDMI, AV, DVSB
Supported formats (HDMI) 720P50; 720P60; 1080I50; 1080I60; 1080P25; 1080P30; 1080P50; 1080P60;
Supported formats (AV) PAL25; NTSC30
RF parameters 2.405 ~ 2.4835GHz, comply with CE, FCC certification
Interface (ground side) LED lights; power switch; charging port; USB 2.0; HDMI; remote control inputs (two Luyao controller input)
Interface (Sky end) LED lights; DBUS; HDMI; AV; DVSB; keys for frequency
Material Aluminum
Power supply (ground terminal) DC power input 11 ~ 26V; built-in lithium battery; Consumption: 6W (no external USB device), 8W (external USB device)
Power (Sky end) DC power input 11 ~ 26V; Power consumption: 8W
Dimensions (ground side) 125 * 89 * 20 (mm)
Dimensions (Sky end) 67 * 47 * 20 (mm)
Weight (ground side) 360g
Weight (Sky end) 70g
Performance than several million existing digital image transmission system, price to be determined, is expected to price and A2 considerable time to market is expected about a month;
later specific price and time to market for ten days ~ ~ ~ ~ ~ announced
DJI Happy New Year, MasterCard wishful! !
If I understand this correctly, it should be priced similar to the A2 $1300
Moe
Edit..
This should give is an idea of how the HD interface looks with OSD
Taken from this video
http://v.youku.com/v_show/id_XNjY3OTg0ODM2.html
Updates
DJI Promo
DJI Lightbridge 2.4ghz HD FPV Transmitter & Receiver (1 min 41 sec)
Unboxing
DJI LightBridge HD Downlink Unboxing by AerialMediaPros.com (7 min 10 sec)
Bench test with Android
DJI Lightbridge Full HD Video Downlink (7 min 49 sec)
First impressions
DJI Lightbridge Initial Flight Test with Empire Hobby and Zebraworkz (7 min 5 sec)
Chinese Review?
DJI Lightbridge Preview on a Phantom Quadcopter in China - EXCLUSIVE demo (2 min 13 sec)
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Jan 30, 2014, 05:27 PM
User Registered
United States, NC, Kernersville
Joined May 2012
I see DJI wants more of my money!!
freqdrive is offline Find More Posts by freqdrive
Old Jan 30, 2014, 07:25 PM
sdaudet's Avatar
France, IdF, Paris
Joined Jan 2011
hey i want it ....
sdaudet is offline Find More Posts by sdaudet
Old Jan 30, 2014, 08:10 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That transceiver on the plane looks pretty beastly (big/heavy) but if it delivers
on the 80mS max latency claim, then I'm interested. As with any digital video link,
what I want to see is how well it degrades and recovers when the signal
is weak/blocked/etc..
Daemon is online now Find More Posts by Daemon
Old Jan 30, 2014, 08:35 PM
mkmkmk13's Avatar
Joined May 2007
It's meant to replace your vtx, rc rx, osd, hdmi adapter and it has a fan and sma connectors
I think that's pretty good
Old Jan 30, 2014, 08:46 PM
skidding in the sky
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
So it starts, Digi signals for the masses (well almost)
WitnessOnly is offline Find More Posts by WitnessOnly
Old Jan 30, 2014, 10:06 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, I know what it replaces. That's why I said transceiver.
It must be pictured massively out of scale relative to the ground unit
if it's only 70g (2.5oz).
Old Jan 30, 2014, 10:09 PM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
So the Chinese finally figured out how to ripoff/reverse engineer Amimon's wireless video MIMO technology?
philthyy is offline Find More Posts by philthyy
Old Jan 31, 2014, 05:14 AM
Joined Jan 2014
Hmmm just in time but pity about the high price?
Phantom 2 is offline Find More Posts by Phantom 2
Old Jan 31, 2014, 06:18 AM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
Lets see a sample video with a latency test. Then more of us will be interested.
Martin Y is offline Find More Posts by Martin Y
Latest blog entry: Flyfly Fox Glider
Old Jan 31, 2014, 10:52 AM
Joined Nov 2005
DJI is an absolute hack company with zero morals and zero understanding of how to conduct business. Want proof? Here ya go:
http://www.suasnews.com/2014/01/2719...rs-taylor-llp/
Old Jan 31, 2014, 11:01 AM
mkmkmk13's Avatar
Joined May 2007
Good job, this has been discussed in many threads
PLEASE KEEP IT ON TOPIC
*Added a new picture to the first post
Old Jan 31, 2014, 03:42 PM
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
HD FPV?
Can't Wait! (0 min 3 sec)
-Blues
Blueshy is online now Find More Posts by Blueshy
Old Jan 31, 2014, 05:13 PM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
Do a video of a digital stopwatch. The watch itself and the monitor beside it. That will lets us know if we will want it for fpv.
Old Feb 02, 2014, 10:45 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
I'm not sure it is intended for FPV video.. it is intended for multicopter operators, for which the latency does not matter as much as the details.
schumixmd is offline Find More Posts by schumixmd
Discussion DJI Lightbridge any info? yawdamper Multirotor Talk 3854 Today 10:55 PM
Discussion DJI New A2 Flight Controller and DJI 900 MHZ Data Link dulanto Multirotor Electronics 1 Feb 01, 2014 03:31 AM
Discussion DJI New A2 Flight Controller and DJI 900 MHZ Data Link dulanto Multirotor Talk 0 Oct 12, 2013 09:14 AM
Sold DJI S800 V2 with DJI CASE + DJI WOOKONG-M + DATA LINK 900 Mhz helderscordeiro Aircraft - Electric - Multirotor (FS/W) 6 Nov 06, 2012 06:08 PM
Sold DJI S800 V2 with DJI CASE + DJI WOOKONG-M + DATA LINK 900 Mhz !!FINAL PRICE REDUCTION helderscordeiro Aircraft - Electric - Multirotor (FS/W) 7 Nov 06, 2012 06:02 PM
