Old May 31, 2014, 10:17 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by ApexAero View Post
Nice! My build turn coming up again!
Thanks Tom. It flies really good. I'm tempted to build another one and make it pretty. Looking forward to your next design/ build.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 01, 2014, 05:05 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I`ve got a decent video uploading to youtube now. I need to shorten it a little, then I`ll add a link. It was a little buys at the field today, but I think the vid is better than #1 overall.
Got in 5 or 6 more flights today in about 3.5 hrs at the field. I`ve increased the timer to 3.5min so my flights are about 4 min long. with plenty of full stick. I may try some 5ah cells next time out.
Right now it`s 11.5lbs AUW, and is easy to fly and land. I don`t think another pound of lipos would hurt it`s flight characteristics much at all and could give 5min flights for sure.
Old Jun 01, 2014, 06:09 PM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Lee, I'm thinking of a serious H32 bashing from a slightly damaged airframe.
I need to repair the wings so a bit of trailing edge thinning work, swoopy tip work all the way around, gear doors. I'm thinking of cutting the hump off under the rudder, make it round again for a thinner fin and fillet. Best part is trying a 12s 70mm monster fan. If it comes in at 8-9lb with a Little power it should be a burner!
waiting on that vid!
ApexAero is offline Find More Posts by ApexAero
Old Jun 01, 2014, 06:25 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Sounds like fun Tom. You might also think about making the intakes a little smaller to reduce drag. With 300+ efflux it should be very fast for sure.
I started building another fuselage for the Mini Spot that would hold 12s, but then the wings not quite big enough.
I`ve found a set of wings in my stash that should work well, so I need to build a fuselage for that wing. It won`t be pretty, but should get the job done.
The video edit is processing right now. You Tube is pretty busy on Sun PM. But I`ll post it asap.
I thought on the PC it would be better, but there`s a big gas motor running and hogging the runway so it wasn`t as good as i`d hoped. Lots of wind noise too.
I`ll post it for the hard core edf watchers like me.
Old Jun 01, 2014, 06:57 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Not sure it was worth the 5 hr wait, but here`s the edited video
Cheap Trick EDF (4 min 6 sec)
Old Jun 02, 2014, 12:00 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
This would have been a better video, but the camera angle was low.
CT 6/1/14 (4 min 37 sec)
Old Jun 02, 2014, 07:19 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I know the videos aren`t very good at all. It`s about as good as my current set up will deliver. I`m going to see if I can upgrade stuff. I like a good video and want to deliver some eventually.
Old Jun 02, 2014, 06:44 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Not that bad, I had a couple turn out like it, I can still hear and see the speed and a silhouette!
I need to make a habu fuse look like this!
Old Jun 02, 2014, 07:44 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
apex....what fuse is that! sexy!
corsair nut is online now Find More Posts by corsair nut
Old Jun 03, 2014, 10:13 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
I think it is/was an Eliminator, this is from a 2007 post
Old Jun 04, 2014, 03:10 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
i was gunna say it looked like a eliminator....
Wanted Sniper XL Fuselage Useable......repairable damage OK Knife Liddle Aircraft - Electric - Jets (FS/W) 3 Mar 26, 2013 11:14 PM
For Sale Super Sniper 90 RTF LPU txshan130 Aircraft - Electric - Jets (FS/W) 4 Mar 22, 2013 09:01 PM
Sold Het Super Sniper XL Brickyard Aircraft - Electric - Jets (FS/W) 11 Mar 17, 2013 11:32 PM
Sold Super Sniper 90 XL V2 Hossinarizona Aircraft - Electric - Jets (FS/W) 4 Feb 08, 2013 03:35 PM
Sold Super Sniper XL V2 Hossinarizona Aircraft - Electric - Jets (FS/W) 4 Feb 08, 2013 03:34 PM
