Old Oct 16, 2006, 05:36 PM
United States, LA, Lake Charles
Joined Sep 2006
Help!
mino IFO elevons and flying
Should the elevons on my mini move independent of each other? What is the basic approach to flying or where is a previous thread that will teach the basics of an IFO?
Thank you from a newbie IFO'er
MikeK0416 is offline Find More Posts by MikeK0416
Old Oct 16, 2006, 07:52 PM
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yes the elevons are independent, they both move up to gain altitude, down to drop altitude. When looking from the back of the plane the right elevon should move up and the left down when the stick is pushed right, this will turn the plane to the right(when facing the back of the plane) When the stick is pushed left the left elevon will raise and the right goes down, this turns ya left. Feel free to ask any questions here and somebody will answer them.
Adam
Atom1025 is offline Find More Posts by Atom1025
Old Oct 16, 2006, 08:28 PM
Joined Sep 2006
I must have the receiver hooked up wrong. When I move the right stick up they don't both move up - one goes up and one goes down.
Old Oct 16, 2006, 08:46 PM
Bethpage Grumman, New York, United States
Joined Nov 2002
Are you using the mixing or elevon mode in the TX or an external mixer?
mike glass is offline Find More Posts by mike glass
Old Oct 16, 2006, 09:10 PM
Joined Sep 2006
basic Tx (eflite 6 channel) and an Esky 6 chann receiver, brushless motor with a feigao esc
Old Oct 16, 2006, 10:30 PM
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yes you must have elevon/aileron mixing turned on.
Also when you push down on the stick both surfaces should go up and when you press up on the stick both surfaces will go down. To gain altitude you press down on the stick and to come down you press up on the stick.
Sounds crazy, I know. But thats how it is. Have you tried a simulator at all? Even a videogame will help, with the controls.
Old Oct 17, 2006, 09:24 AM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
http://www.rcgroups.com/forums/showt...&highlight=ifo
http://www.rcgroups.com/forums/showt...ight=ifo+owner
Also, Mini-IFO knows a lot about the thing (almost as much as me!)
madsci_guy is offline Find More Posts by madsci_guy
Old Oct 17, 2006, 09:38 AM
Joined Sep 2006
great - thanks for the links. I must not have the servos plugged into the correct Rx channels
Old Oct 17, 2006, 10:18 AM
Joined Sep 2006
discovered the problem. The ESC goes to channel 3, one servo to channel 1 and the other to channel 6. I have no clue why these specific channels but it worked.
Old Oct 17, 2006, 02:37 PM
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
That's very odd - possibly you have elevon and flaperon mixing switched on.
I don't know that transmitter, but there's usually some + or - type settings in the elevon mixing menu that will reverse a servo. You'd normally expect to use channels 1 and 2 for elevons (but if it works, there's no need to play with it unless you want to!)
Get FMS (a free simulator) here:
http://n.ethz.ch/~mmoeller/fms/index_e.html
RobinBennett is offline Find More Posts by RobinBennett
Yippee! Mini Ifo: House Flying SOOKOOL Parkflyers 9 Apr 30, 2004 11:35 AM
IFO (indoor flying object) rob251 Scratchbuilt Indoor and Micro Models 1 Oct 21, 2003 02:42 PM
